很久以前測試過的超聲波測距,用MSP430F149+超聲波測距+LCD1602/LCD12864顯示
2017-5-18 22:54 上傳
12864液晶顯示代碼:
- #include <msp430x14x.h>
- #define RISE 1
- #define FALL 0
- #define DataIn P4DIR=0x00 //數據口方向設置為輸入
- #define DataOut P4DIR=0xff //數據口方向設置為輸出
- #define MCU_Data P4IN
- #define LCD_Data P4OUT
- #define CMDOut P6DIR|=0xfc //P6口的低23456位設置為輸出
- #define RS_H P6OUT|=BIT2 //P6.2
- #define RS_L P6OUT&=~BIT2 //P6.2
- #define RW_H P6OUT|=BIT3 //P6.3
- #define RW_L P6OUT&=~BIT3 //P6.3
- #define EN_H P6OUT|=BIT4 //P6.4
- #define EN_L P6OUT&=~BIT4 //P6.4
- #define PSB_RST_H P6OUT|=BIT5+BIT6 //P6.5 P6.6為高
- unsigned int TA_Overflow_Cnt;//TA溢出次數存放變量
- unsigned long int Period;//脈寬存放結果變量
- unsigned long int S;
- unsigned int distance;
- unsigned int RiseCapVal;//上升沿時刻捕獲值存放變量
- unsigned char Edge=1;//當前觸發沿
- const unsigned char hang1[]={"<<超聲波測距儀>>"};
- const unsigned char hang2[]={"距離:"};
- const unsigned char hang3[]={"米"};
- unsigned char disbuff[4]={"0.00"};
- void Write_Cmd(unsigned char cmd);
- void Write_Data(unsigned char dat);
- void Init_Lcd(void);
- void Disp_HZ(unsigned char addr,const unsigned char * pt,unsigned char num);
- void init_clk();
- void init_timerA();
- void init_IO();
- void display_juli();
- 函數名稱:Delay_1ms
- 功 能:延時約1ms的時間
- void Delay_1ms(void)
- unsigned char i;
- for(i=150;i>0;i--) _NOP();
- 函數名稱:Delay_Nms
- 功 能:延時N個1ms的時間
- 參 數:n--延時長度
- void Delay_Nms(unsigned int n)
- unsigned int i;
- for(i=n;i>0;i--) Delay_1ms();
- 函數名稱:Write_Cmd
- 功 能:向液晶中寫控制命令
- 參 數:cmd--控制命令
- unsigned char lcdtemp=0;
- RS_L;
- RW_H;
- DataIn;
- do //判忙
- EN_H;
- _NOP();
- lcdtemp = MCU_Data;
- EN_L;
- while(lcdtemp & 0x80);
- DataOut;
- RW_L;
- LCD_Data = cmd;
- EN_H;
- _NOP();
- EN_L;
- 函數名稱:Write_Data
- 功 能:向液晶中寫顯示數據
- 參 數:dat--顯示數據
- unsigned char lcdtemp = 0;
- RS_L;
- RW_H;
- DataIn;
- do //判忙
- EN_H;
- _NOP();
- EN_L;
- DataOut;
- RS_H;
- RW_L;
- LCD_Data = dat;
- EN_H;
- _NOP();
- EN_L;
- 函數名稱:Ini_Lcd
- 功 能:初始化液晶模塊
- CMDOut; //液晶控制端口設置為輸出
- PSB_RST_H; //設置并行顯示方式;
- Delay_Nms(500);
- Write_Cmd(0x30); //基本指令集
- Delay_1ms();
- Write_Cmd(0x02); // 地址歸位
- Delay_1ms();
- Write_Cmd(0x0c); //整體顯示打開,游標關閉
- Delay_1ms();
- Write_Cmd(0x01); //清除顯示
- Delay_1ms();
- Write_Cmd(0x06); //游標右移
- Delay_1ms();
- Write_Cmd(0x80); //設定顯示的起始地址
- // Write_Cmd(0x01);
- Disp_HZ(0x80,hang1,8);
- Disp_HZ(0x91,hang2,3);
- Disp_HZ(0x96,hang3,1);
- 函數名稱:Disp_HZ
- 功 能:控制液晶顯示漢字
- 參 數:addr--顯示位置的首地址
- pt--指向顯示數據的指針
- num--顯示字符個數
- unsigned char i;
- Write_Cmd(addr);
- for(i = 0;i < (num*2);i++)
- Write_Data(*(pt++));
- //初始化系統時鐘函數
- void init_clk()
- unsigned char i;
- BCSCTL1&=~XT2OFF;//打開XT振蕩器
- BCSCTL2|=SELM_2+SELS;//MCLK 8M and SMCLK 8M
- do
- IFG1 &= ~OFIFG;//清除振蕩錯誤標志
- for(i=0;i<0xff;i++) _NOP();//延時等待
- while((IFG1 & OFIFG) != 0);//如果標志為1繼續循環等待
- IFG1&=~OFIFG;
- //初始化定時器A函數
- TACTL |= TASSEL_2+MC_2+TAIE+TACLR+ ID_3;//SMCLK,連續計數,中斷允許,計數器清零
- TACCTL1 |= CAP+CM_1+CCIS_0+SCS+CCIE;//捕獲模式,上升沿捕獲,CCI1A輸入,同步捕獲,中斷允許
- //初始化端口函數
- void init_IO()
- P1DIR |= BIT1;//P1.1輸出
- P1DIR &=~ BIT2;//P1.2輸入
- P1SEL |= BIT2;//P1.2第二功能,捕獲輸入
- //P2DIR |= 0xff; //設置P2口方向為輸出
- P4DIR |= 0xff;
- P6DIR |= 0xfc;
- P1OUT &=~BIT1;
- Delay_Nms(1000);
- if(S/100)
- disbuff[0]=S/100+'0';
- disbuff[2]=S/10%10+'0';
- disbuff[3]=S%10+'0';
- else if(S/10)
- disbuff[2]=S/10+'0';
- disbuff[0]='0';
- else
- disbuff[0]='0';
- disbuff[2]='0';
- void main()
- WDTCTL = WDTPW + WDTHOLD;//停狗
- init_IO();
- Init_Lcd();
- init_timerA();
- TACCTL1 |= CAP+CM_1+CCIS_0+SCS+CCIE;//改為上升沿捕獲
- _EINT();
- while(1)
- P1OUT |= BIT1;
- Delay_Nms(10);
- P1OUT &=~BIT1;
- Delay_Nms(80);
- //P2OUT = 0x00;
- P6OUT &= ~BIT1;
- display_juli();
- Disp_HZ(0x94,disbuff,2);
- if(S<10)
- //P2OUT = 0xff;
- P6DIR |= BIT1;
- P6OUT |= BIT1;
- //定時器A服務程序
- #pragma vector=TIMERA1_VECTOR
- __interrupt void Timer_A(void)
- switch(TAIV)
- case 2 :if(Edge==RISE)
- RiseCapVal = TACCR1;
- TACCTL1 |= CAP+CM_2+CCIS_0+SCS+CCIE;//改為下降沿捕獲
- //TACCTL1 |= CAP+CM_1+CCIS_0+SCS+CCIE;//改為上升沿捕獲
- Edge = FALL;//下降沿捕獲標志
- else
- _DINT();
- Period = TACCR1-RiseCapVal;
- S=(Period*17)/100;
- TACCR1 = 0;
- TACCTL1|= CAP+CM_1+CCIS_0+SCS+CCIE;//改為上升沿捕獲
- Edge = RISE;//上升沿捕獲標志
- _EINT();
- break;
- case 4 : break;
- case 10: TA_Overflow_Cnt++;break;
1602液晶顯示代碼:
以上2個代碼下載,如有錯誤請指教:
MSP430 超聲波.rar
(43.44 KB, 下載次數: 79)
2017-5-18 20:42 上傳
