#include<reg52.h>//電機(jī)定位(原點(diǎn)幾度比如,45度,75度,105度,190度)
sbit dula=P2^6;//數(shù)碼管段選
sbit wela=P2^7;//數(shù)碼管位
sbit jia_key=P3^6;///加速鍵
sbit jian_key=P3^7;//減速鍵
sbit zf_key=P3^5;//正反轉(zhuǎn)鍵
bit flag=0;//正反轉(zhuǎn)標(biāo)志位
uchar num=0,show_num=2,maichong=4,table_begin=0;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code table1[]={0x01,0x02,0x04,0x08,0x04,0x02,0x01};//電機(jī)正反轉(zhuǎn)I/O口電平對(duì)應(yīng)表
void delay(uchar i)
uchar j,k;
for(j=i;j>0;j--)
for(k=125;k>0;k--);
void display() //顯示函數(shù)
dula=0;
P0=table[show_num];
dula=1;
dula=0;
wela=0;
P0=0xfe;
wela=1;
wela=0;
delay(5);
P0=table[0];
dula=1;
dula=0;
P0=0xfd;
wela=1;
wela=0;
delay(5);
void key() //按鍵掃描
if(jia_key==0)
delay(5);
if(jia_key==0)
num++;
if(num==4)
num=3;
while(jia_key==0);
if(jian_key==0)
delay(5);
if(jian_key==0)
if(num!=0)
num--;
num=0;
while(jian_key==0);
if(zf_key==0)
delay(5);
if(zf_key==0)
flag=~flag;
while(zf_key==0);
void dispose() //根據(jù)速度標(biāo)識(shí)進(jìn)行數(shù)據(jù)處理
switch(num)
case 0: show_num=2;
maichong=5;
break;
case 1: show_num=4;
maichong=4;
break;
case 2: show_num=6;
maichong=3;
break;
case 3: show_num=8;
maichong=2;
break;
if(flag==0)
table_begin=0;
table_begin=4;
void qudong() //電機(jī)驅(qū)動(dòng)傳送數(shù)據(jù)
uchar i,j;
for(j=0+table_begin;j<4+table_begin;j++)
P1=table1[j];
for(i=0;i<maichong;i++)
display();
key();
dispose();
qudong();
程序這樣的找書上,正反轉(zhuǎn),加減速正常。還有些程序看不懂。現(xiàn)在的問(wèn)題想按鍵點(diǎn)動(dòng)定位,比如按一下按鍵走一步。按另一個(gè)按鍵定位在35度,在按這個(gè)鍵走70度。請(qǐng)教怎樣編程程序
