不過(guò)按鍵反應(yīng)比較慢點(diǎn)~!里面有一個(gè)圖形溫度計(jì)還有時(shí)鐘可調(diào)等等!
我個(gè)人感覺(jué)很經(jīng)典。
2016-8-20 21:42 上傳
2016-8-20 21:44 上傳
12864時(shí)鐘 圖形溫度計(jì)的全部資料下載:
12864 圖形溫度計(jì) ds1302 ds18b20 矩陣鍵盤.rar
(81.58 KB, 下載次數(shù): 137)
2016-8-20 21:45 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
部分程序源碼預(yù)覽:
- //南陽(yáng)理工學(xué)院
- //12864+圖形溫度計(jì)+ds1302+ds18b20+矩陣鍵盤
- //此程序如果要在硬件電路上實(shí)現(xiàn)要改一些地方!
- //不曾努力,就沒(méi)有資格說(shuō)失敗!
- #include "ds18b20.h"
- #include "12864.h"
- #include "1302.h"
- #include "key.h"
- #include "zifu.h"
- bit flagg=0;
- uchar ip;
- main()
- uchar i;
- systemtime realtime;
- choose12864(2);
- init12864();
- clear12864();
- play8(0,0,0,shu2); //屏,列,頁(yè),地址
- play8(0,1,0,shu0);
- play16(0,4,0,nian);
- play16(1,0,0,yue);
- play16(1,4,0,ri);
- play16(0,2,1,shi);
- play16(0,6,1,fen);
- play16(1,2,1,miao);
- play16(1,0,2,xing);
- play16(1,2,2,qi);
- vertical(3,63,63);
- vertical(3,63,62);
- vertical(3,63,58);
- vertical(3,63,57);
- for(i=0;i<7;i++)
- dot(57+i,3);
- dot(57+i,63);
- for(i=0;i<12;i++)
- dot(59,8+5*i);
- for(i=0;i<7;i++)
- if(i<4)
- play16(0,i*2,3,ming+i*32);
- if(i>=4)
- play16(1,(i-4)*2,3,ming+i*32);
- init_ds1302();
- init_time();
- do
- gettime(&realtime);
- play8(0,2,0,(shu0+16*datastring[0]));
- play8(0,3,0,(shu0+16*datastring[1]));
- play8(0,6,0,(shu0+16*datastring[2]));
- play8(0,7,0,(shu0+16*datastring[3]));
- play8(1,2,0,(shu0+16*datastring[4]));
- play8(1,3,0,(shu0+16*datastring[5]));
- play8(0,0,1,(shu0+16*datastring[6]));
- play8(0,1,1,(shu0+16*datastring[7]));
- play8(0,4,1,(shu0+16*datastring[8]));
- play8(0,5,1,(shu0+16*datastring[9]));
- play8(1,0,1,(shu0+16*datastring[10]));
- play8(1,1,1,(shu0+16*datastring[11]));
- play16(1,4,2,(yi+32*(datastring[12]-1)));
- gettemperature();
- if(flag)
- play8(0,0,2,fu);
- play8(1,6,3,fu);
- else
- clear8(6,4,0);
- play8(1,6,3,zheng);
- play8(0,4+flag,2,dian);
- play8(0,5+flag,2,C);
- play8(0,0+flag,2,(shu0+16*temp[0]));
- play8(0,1+flag,2,(shu0+16*temp[1]));
- play8(0,2+flag,2,xiao);
- play8(0,3+flag,2,(shu0+16*temp[2]));
- change();
- keyscan();
- switch(sum)
- case 0:ip=ds1302_year;flagg=1;break;
- case 1:ip=ds1302_month;flagg=1;break;
- case 2:ip=ds1302_week;flagg=1;break;
- case 3:ip=ds1302_day;flagg=1;break;
- case 4:ip=ds1302_hour;flagg=1;break;
- case 5:ip=ds1302_minute;flagg=1;break;
- case 6:ip=ds1302_second;flag=1;break;
- default:break;
- if(flagg==1)
- keyscan();
- if(sum==7)
- set(ip,1);
- sum=0xff;;
- else if(sum==8)
- set(ip,0);
- sum=0xff;
- while(1);
