查看: 18984|回復(fù): 27
L297,L298驅(qū)動步進(jìn)電機(jī)原理圖proteus仿真+程序 LCD顯示速度
ID:262 發(fā)表于 2016-8-15 14:40 | 顯示全部樓層 |閱讀模式
L297,L298驅(qū)動步進(jìn)電機(jī)的原理圖,親測可用
L297,L298驅(qū)動步進(jìn)電機(jī)的51單片機(jī)程序如下:
  1. #include "AT89X51.h"
  2. int delay();
  3. void inti_lcd();
  4. void show_lcd(int);
  5. void cmd_wr();
  6. void ShowState();
  7. void clock(unsigned int Delay) ;
  8. void DoSpeed();       //計算速度
  9. //正轉(zhuǎn)值
  10. #define RIGHT_RUN 1
  11. //反轉(zhuǎn)值
  12. #define LEFT_RUN 0
  13. sbit RS=0xA0;
  14. sbit RW=0xA1;
  15. sbit E=0xA2;
  16. char SpeedChar[]="SPEED(n/min):";
  17. char StateChar[]="RUN STATE:";
  18. char STATE_CW[]="CW";
  19. char STATE_CCW[]="CCW";
  20. char SPEED[3]="050";
  21. unsigned int RunSpeed=50;                //速度
  22. unsigned char RunState=RIGHT_RUN;  //運行狀態(tài)
  23. main()
  24. {
  25.
  26.         /*定時器設(shè)置*/
  27.         TMOD=0x66;            //定時器0,1都為計數(shù)方式;方式2;
  28.         EA=1;                        //開中斷
  29.
  30.         TH0=0xff;                //定時器0初值FFH;
  31.         TL0=0xff;
  32.         ET0=1;
  33.         TR0=1;
  34.
  35.         TH1=0xff;                //定時器1初值FFH;
  36.         TL1=0xff;
  37.         ET1=1;
  38.         TR1=1;
  39.
  40.         IT0=1;                        //脈沖方式
  41.         EX0=1;                        //開外部中斷0:加速
  42.         IT1=1;                        //脈沖方式
  43.         EX1=1;                        //開外部中斷1:減速
  44.
  45.     inti_lcd();
  46.     DoSpeed();
  47.     ShowState();
  48.     while(1)
  49.     {
  50.       clock(RunSpeed);
  51.       P0_1=P0_1^0x01;
  52.     }
  53.
  54. }
  55. //定時器0中斷程序:正轉(zhuǎn)
  56. void t_0(void) interrupt 1
  57. {
  58.         RunState=RIGHT_RUN;
  59.     P0_0=1;
  60.     P1=0x01;
  61.     cmd_wr();
  62.     ShowState();
  63. }
  64. //定時器1中斷:反轉(zhuǎn)
  65. void t_1(void) interrupt 3
  66. {
  67.         RunState=LEFT_RUN;
  68.     P0_0=0;
  69.     P1=0x01;
  70.     cmd_wr();
  71.     ShowState();
  72.
  73. }
  74. //中斷0:加速程序
  75. void SpeedUp() interrupt 0
  76. {
  77.        if(RunSpeed>=12)
  78.           RunSpeed=RunSpeed-2;
  79.        DoSpeed();
  80.        P1=0x01;
  81.        cmd_wr();
  82.        ShowState();
  83.
  84. }
  85. //中斷1:減速程序
  86. void SpeedDowm() interrupt 2
  87. {
  88.
  89.     if(RunSpeed<=100)
  90.         RunSpeed=RunSpeed+2;
  91.     DoSpeed();
  92.     P1=0x01;
  93.     cmd_wr();
  94.     ShowState();
  95.
  96. }
  97. int delay()         //判斷LCD是否忙
  98. {
  99.     int a;
  100. start:
  101.
  102.     RS=0;
  103.     RW=1;
  104.     E=0;
  105.     for(a=0;a<2;a++);
  106.     E=1;
  107.     P1=0xff;
  108.     if(P1_7==0)
  109.        return 0;
  110.     else
  111.        goto start;
  112. }
  113. void inti_lcd()  //設(shè)置LCD方式
  114. {
  115.    P1=0x38;
  116.    cmd_wr();
  117.    delay();
  118.    P1=0x01;     //清除
  119.    cmd_wr();
  120.    delay();
  121.    P1=0x0f;
  122.    cmd_wr();
  123.    delay();
  124.    P1=0x06;
  125.    cmd_wr();
  126.    delay();
  127.    P1=0x0c;
  128.    cmd_wr();
  129.    delay();
  130. }
  131. void cmd_wr()           //寫控制字
  132. {
  133.    RS=0;
  134.    RW=0;
  135.    E=0;
  136.    E=1;
  137. }
  138. void show_lcd(int i)   //LCD顯示子程序
  139. {
  140.    P1=i;
  141.    RS=1;
  142.    RW=0;
  143.    E=0;
  144.    E=1;
  145. }
  146. void ShowState()    //顯示狀態(tài)與速度
  147. {
  148.     int i=0;
  149.     while(SpeedChar[i]!='\0')
  150.     {
  151.        delay();
  152.        show_lcd(SpeedChar[i]);
  153.        i++;
  154.     }
  155.
  156.     delay();
  157.     P1=0x80 | 0x0d;
  158.     cmd_wr();
  159.     i=0;
  160.     while(SPEED[i]!='\0')
  161.     {
  162.        delay();
  163.        show_lcd(SPEED[i]);
  164.        i++;
  165.     }
  166.     delay();
  167.     P1=0xC0;
  168.     cmd_wr();
  169.     i=0;
  170.     while(StateChar[i]!='\0')
  171.     {
  172.        delay();
  173.        show_lcd(StateChar[i]);
  174.        i++;
  175.     }
  176.     delay();
  177.     P1=0xC0 | 0x0A;
  178.     cmd_wr();
  179.     i=0;
  180.     if(RunState==RIGHT_RUN)
  181.         while(STATE_CW[i]!='\0')
  182.         {
  183.           delay();
  184.           show_lcd(STATE_CW[i]);
  185.           i++;
  186.         }
  187.     else
  188.        while(STATE_CCW[i]!='\0')
  189.         {
  190.           delay();
  191.           show_lcd(STATE_CCW[i]);
  192.           i++;
  193.         }
  194. }
  195. void clock(unsigned int Delay)   //1ms延時程序
  196. {  unsigned int i;
  197.    for(;Delay>0;Delay--)
  198.     for(i=0;i<124;i++);
  199.
  200. }
  201. void DoSpeed()
  202. {
  203.     SPEED[0]=(1000*6/RunSpeed/100)+48;
  204.     SPEED[1]=1000*6/RunSpeed%100/10+48;
  205.     SPEED[2]=1000*6/RunSpeed%10+48;
  206. }
附:Proteus仿真文件,及KEIL仿真原代碼及HEX文件,C語言編的.
步進(jìn)電機(jī)控制,LCD顯示.zip
45.22 KB, 下載次數(shù): 414, 下載積分: 黑幣 -5
參與人數(shù) 2黑幣 +10 收起 理由
fcj1208 + 5 很給力!
非典型理工男 + 5 絕世好帖!
相關(guān)帖子
ID:100826 發(fā)表于 2016-8-16 10:37 | 顯示全部樓層
正好用得上   謝謝分享
ID:138443 發(fā)表于 2016-10-3 11:37 | 顯示全部樓層
太好了,學(xué)習(xí)學(xué)習(xí),謝謝51hei
ID:186356 發(fā)表于 2017-4-5 16:50 | 顯示全部樓層
好資料啊,學(xué)習(xí)學(xué)習(xí),51黑有你更精彩
ID:190929 發(fā)表于 2017-4-24 21:02 | 顯示全部樓層
有幫助,謝謝你
ID:187393 發(fā)表于 2017-5-1 16:41 | 顯示全部樓層
正在研究中~ 很棒
ID:198594 發(fā)表于 2017-5-24 10:42 | 顯示全部樓層
大神,這里的按鍵要不要寫程序控制
ID:217601 發(fā)表于 2017-7-6 12:01 | 顯示全部樓層
謝謝樓主,非常感謝
ID:74944 發(fā)表于 2018-1-7 20:10 | 顯示全部樓層
謝謝樓主啊
ID:275915 發(fā)表于 2018-1-14 18:19 | 顯示全部樓層
好東西啊
ID:284543 發(fā)表于 2018-2-20 23:07 | 顯示全部樓層
我也想下載這個啊,就是下載不到
ID:294460 發(fā)表于 2018-4-20 22:36 | 顯示全部樓層
想問一下,a4988怎么畫
ID:329839 發(fā)表于 2018-5-14 19:32 | 顯示全部樓層
挺好的!
ID:332020 發(fā)表于 2018-5-19 10:33 | 顯示全部樓層
樓主是作者本人嗎
ID:336561 發(fā)表于 2018-5-23 15:43 | 顯示全部樓層
給力,謝謝樓主。
ID:360974 發(fā)表于 2018-6-28 16:45 | 顯示全部樓層
很給力
ID:441039 發(fā)表于 2018-12-6 18:03 | 顯示全部樓層
源代碼是錯的呀怎么回事
ID:465819 發(fā)表于 2019-1-10 14:35 | 顯示全部樓層
好帖子啊
ID:466233 發(fā)表于 2019-1-11 00:56 | 顯示全部樓層
不錯很好
ID:466655 發(fā)表于 2019-3-6 13:12 | 顯示全部樓層
感謝你的分享 但是沒有積分下載 只能看看你的代碼片段了
ID:52542 發(fā)表于 2019-4-17 00:13 | 顯示全部樓層
下載下來看看,學(xué)習(xí)一下。
ID:52542 發(fā)表于 2019-4-17 00:14 | 顯示全部樓層
ID:526735 發(fā)表于 2019-6-1 13:50 | 顯示全部樓層
樓主的貢獻(xiàn)很大啊
唯美生活 發(fā)表于 2019-4-17 00:14
要不我?guī)湍阆拢?/td>
ID:582548 發(fā)表于 2019-8-30 18:25 | 顯示全部樓層
非常完美
ID:61950 發(fā)表于 2019-8-31 11:49 來自觸屏版 | 顯示全部樓層
網(wǎng)上找了好多,就沒把42電機(jī)轉(zhuǎn)起來
ID:642925 發(fā)表于 2019-11-16 11:14 來自觸屏版 | 顯示全部樓層
有人能教教我嗎?我照這個電路給L297的clock入
ID:642925 發(fā)表于 2019-11-16 11:15 來自觸屏版 | 顯示全部樓層
我用這個電路給L297的clock輸入脈沖,電機(jī)不轉(zhuǎn)啊,求教
