查看: 32031|回復: 53
單片機控制步進電機protues仿真
單片機控制步進電機protues仿真
仿真原理圖
程序如下:
  1. #include "reg52.h"
  2. int delay();
  3. void inti_lcd();
  4. void show_lcd(int);
  5. void cmd_wr();
  6. void ShowState();
  7. void clock(unsigned int Delay) ;
  8. void DoSpeed();       //計算速度
  9. //正轉值
  10. #define RIGHT_RUN 1
  11. //反轉值
  12. #define LEFT_RUN 0
  13. sbit RS=0xA0;
  14. sbit RW=0xA1;
  15. sbit E=0xA2;
  16. char SpeedChar[]="SPEED(n/min):";
  17. char StateChar[]="RUN STATE:";
  18. char STATE_CW[]="CW";
  19. char STATE_CCW[]="CCW";
  20. char SPEED[3]="050";
  21. unsigned int RunSpeed=50;                //速度
  22. unsigned char RunState=RIGHT_RUN;  //運行狀態
  23. main()
  24. {
  25.
  26.         /*定時器設置*/
  27.         TMOD=0x66;            //定時器0,1都為計數方式;方式2;
  28.         EA=1;                        //開中斷
  29.
  30.         TH0=0xff;                //定時器0初值FFH;
  31.         TL0=0xff;
  32.         ET0=1;
  33.         TR0=1;
  34.
  35.         TH1=0xff;                //定時器1初值FFH;
  36.         TL1=0xff;
  37.         ET1=1;
  38.         TR1=1;
  39.
  40.         IT0=1;                        //脈沖方式
  41.         EX0=1;                        //開外部中斷0:加速
  42.         IT1=1;                        //脈沖方式
  43.         EX1=1;                        //開外部中斷1:減速
  44.
  45.     inti_lcd();
  46.     DoSpeed();
  47.     ShowState();
  48.     while(1)
  49.     {
  50.       clock(RunSpeed);
  51.       P0=0x01;
  52.     }
  53.
  54. }
  55. //定時器0中斷程序:正轉
  56. void t_0(void) interrupt 1
  57. {
  58.         RunState=RIGHT_RUN;
  59.     P0=1;
  60.     P1=0x01;
  61.     cmd_wr();
  62.     ShowState();
  63. }
  64. //定時器1中斷:反轉
  65. void t_1(void) interrupt 3
  66. {
  67.         RunState=LEFT_RUN;
  68.     P0=0;
  69.     P1=0x01;
  70.     cmd_wr();
  71.     ShowState();
  72.
  73. }
  74. //中斷0:加速程序
  75. void SpeedUp() interrupt 0
  76. {
  77.        if(RunSpeed>=12)
  78.           RunSpeed=RunSpeed-2;
  79.        DoSpeed();
  80.        P1=0x01;
  81.        cmd_wr();
  82.        ShowState();
  83.
  84. }
  85. //中斷1:減速程序
  86. void SpeedDowm() interrupt 2
  87. {
  88.
  89.     if(RunSpeed<=100)
  90.         RunSpeed=RunSpeed+2;
  91.     DoSpeed();
  92.     P1=0x01;
  93.     cmd_wr();
  94.     ShowState();
  95.
  96. }
  97. int delay()         //判斷LCD是否忙
  98. {
  99.     int a;
  100. start:
  101.
  102.     RS=0;
  103.     RW=1;
  104.     E=0;
  105.     for(a=0;a<2;a++);
  106.     E=1;
  107.     P1=0xff;
  108.     if(P1^7==0)
  109.        return 0;
  110.     else
  111.        goto start;
  112. }
  113. void inti_lcd()  //設置LCD方式
  114. {
  115.    P1=0x38;
  116.    cmd_wr();
  117.    delay();
  118.    P1=0x01;     //清除
  119.    cmd_wr();
  120.    delay();
  121.    P1=0x0f;
  122.    cmd_wr();
  123.    delay();
  124.    P1=0x06;
  125.    cmd_wr();
  126.    delay();
  127.    P1=0x0c;
  128.    cmd_wr();
  129.    delay();
  130. }
  131. void cmd_wr()           //寫控制字
  132. {
  133.    RS=0;
  134.    RW=0;
  135.    E=0;
  136.    E=1;
  137. }
  138. void show_lcd(int i)   //LCD顯示子程序
  139. {
  140.    P1=i;
  141.    RS=1;
  142.    RW=0;
  143.    E=0;
  144.    E=1;
  145. }
  146. void ShowState()    //顯示狀態與速度
  147. {
  148.     int i=0;
  149.     while(SpeedChar[i]!='\0')
  150.     {
  151.        delay();
  152.        show_lcd(SpeedChar[i]);
  153.        i++;
  154.     }
  155.
  156.     delay();
  157.     P1=0x80 | 0x0d;
  158.     cmd_wr();
  159.     i=0;
  160.     while(SPEED[i]!='\0')
  161.     {
  162.        delay();
  163.        show_lcd(SPEED[i]);
  164.        i++;
  165.     }
  166.     delay();
  167.     P1=0xC0;
  168.     cmd_wr();
  169.     i=0;
  170.     while(StateChar[i]!='\0')
  171.     {
  172.        delay();
  173.        show_lcd(StateChar[i]);
  174.        i++;
  175.     }
  176.     delay();
  177.     P1=0xC0 | 0x0A;
  178.     cmd_wr();
  179.     i=0;
  180.     if(RunState==RIGHT_RUN)
  181.         while(STATE_CW[i]!='\0')
  182.         {
  183.           delay();
  184.           show_lcd(STATE_CW[i]);
  185.           i++;
  186.         }
  187.     else
  188.        while(STATE_CCW[i]!='\0')
  189.         {
  190.           delay();
  191.           show_lcd(STATE_CCW[i]);
  192.           i++;
  193.         }
  194. }
  195. void clock(unsigned int Delay)   //1ms延時程序
  196. {  unsigned int i;
  197.    for(;Delay>0;Delay--)
  198.     for(i=0;i<124;i++);
  199.
  200. }
  201. void DoSpeed()
  202. {
  203.     SPEED[0]=(1000*6/RunSpeed/100)+48;
  204.     SPEED[1]=1000*6/RunSpeed%100/10+48;
  205.     SPEED[2]=1000*6/RunSpeed%10+48;
  206. }
步進電機控制,LCD顯示.zip
97.86 KB, 下載次數: 554, 下載積分: 黑幣 -5
protues仿真
參與人數 5黑幣 +73 收起 理由
YD丶小Y + 5
baobaobao123 + 5 回帖助人的獎勵!
Dushu + 8 很給力!
nbp + 5 絕世好帖!
收藏收藏13 分享淘帖 頂6 踩
ID:156333 發表于 2017-1-3 17:06 | 只看該作者
厲害了我的哥
ID:165363 發表于 2017-2-20 08:31 | 只看該作者
謝謝分享
ID:185466 發表于 2017-4-1 21:46 | 只看該作者
謝謝樓主分享
ID:217754 發表于 2017-7-14 20:20 | 只看該作者
謝謝分享。。學習了。。
ID:65063 發表于 2017-8-2 14:52 | 只看該作者
謝謝樓主分享
ID:239826 發表于 2017-10-16 10:28 | 只看該作者
感謝樓主。。。! 謝謝了
ID:245650 發表于 2017-11-3 13:57 | 只看該作者
謝謝分享
謝謝分享
ID:262541 發表于 2017-12-16 23:53 | 只看該作者
謝謝樓主分享
ID:263915 發表于 2017-12-19 20:29 | 只看該作者
謝謝樓主分享
ID:75137 發表于 2017-12-27 13:17 | 只看該作者
感謝樓主分享
ID:268814 發表于 2017-12-29 13:00 | 只看該作者
很強,正好缺少這方面的資料,感謝樓主
ID:273151 發表于 2018-1-8 12:54 | 只看該作者
感謝
ID:184780 發表于 2018-1-9 09:00 | 只看該作者
這個好東西,不錯,謝謝了。等下試驗一下
ID:281533 發表于 2018-2-1 18:28 | 只看該作者
謝謝分享,正在學習這個
ID:289877 發表于 2018-3-13 23:16 | 只看該作者
太好了,多謝
ID:289877 發表于 2018-3-13 23:17 | 只看該作者
多謝分享,好東西
ID:289877 發表于 2018-3-13 23:42 | 只看該作者
好東西值得學習!
ID:282517 發表于 2018-4-17 11:52 | 只看該作者
最近看了你那個基于Protues的步進電機的程序,我發現那個里邊有個main.hex    而燒錄moter.hex的就不能用了。這是怎么回事兒啊
ID:312613 發表于 2018-4-20 19:01 | 只看該作者
給力,謝謝老哥
ID:310363 發表于 2018-4-20 20:24 | 只看該作者
好東西,值得學習一下。
ID:313702 發表于 2018-4-28 10:29 | 只看該作者
謝謝分享
ID:324146 發表于 2018-5-7 13:26 | 只看該作者
一直在找這個,下載下來看看怎么樣
ID:324052 發表于 2018-5-7 22:44 | 只看該作者
感謝分享
ID:330767 發表于 2018-5-15 20:40 | 只看該作者
very godd
ID:317269 發表于 2018-5-16 14:25 | 只看該作者
非常棒的入門程序,  很滿意。
ID:336044 發表于 2018-5-22 21:18 | 只看該作者
謝謝你的分享
ID:338470 發表于 2018-5-25 23:54 | 只看該作者
厲害!
ID:338578 發表于 2018-5-26 10:55 | 只看該作者
謝謝分享。。。。。。。
ID:347020 發表于 2018-6-7 16:44 | 只看該作者
我正在 發愁呢 謝謝你了
ID:281881 發表于 2018-6-10 02:51 | 只看該作者
代碼形成hex文件后仿真不運行,不知何原因?
ID:281881 發表于 2018-6-10 03:34 | 只看該作者
main.hex可以,    而燒錄moter.hex的就不能用了。這是怎么回事兒啊
ID:347821 發表于 2018-6-10 07:46 | 只看該作者
厲害厲害
ID:252860 發表于 2018-9-12 16:21 | 只看該作者
謝謝分享
ID:324611 發表于 2018-9-27 09:53 | 只看該作者
謝謝分享。
ID:403330 發表于 2018-9-27 19:29 | 只看該作者
好像還不錯哦。!
ID:463652 發表于 2019-1-7 12:41 | 只看該作者
謝謝分享。!
ID:383856 發表于 2019-1-15 19:55 | 只看該作者
謝謝分享
ID:505832 發表于 2019-4-6 17:15 | 只看該作者
謝謝樓主分享
