用51單片機實現的ADC0809數字電壓表的PROTEUS仿真圖:
本實例為AD轉換,運用AD芯片將電壓模擬量轉換成數字量,然后顯示在數碼管上。
ADC0809數字電壓表51單片機程序:
- #include<reg52.h>
- #include"common.h"
- #include"delay.h"
- uint8 smg_du[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit oe = P1^0; //輸出使能
- sbit eoc = P1^1; //結束轉換
- sbit st = P1^2; //開始信號
- sbit clk = P1^3; //時鐘信號
- void smg_display(uint8 dat)
- uint8 i;
- dat = (uint16)dat * 50 / 255;
- for(i=0;i<3;i++)
- P0 = 0x00;
- switch(i)
- case 0:
- P0 = smg_du[dat%10];
- P2 = 0xf7;
- break;
- case 1:
- P0 = smg_du[dat/10%10] + 0x80;
- P2 = 0xfb;
- break;
- case 2:
- P0 = smg_du[dat/100];
- P2 = 0xfd;
- break;
- delay1ms(5);
- void main()
- TMOD = 0x02; //定時器中斷方式2 自動重裝8位定時器
- TH0 = 0; //定時256us
- TL0 = 0;
- EA = 1;
- ET0 = 1;
- TR0 = 1;
- P1 = 0x3f; //通道3
- while(1)
- st = 0;
- st = 1;
- st = 0; //開始轉換標志
- while(!eoc ); //等待轉換完成
- oe = 1;
- smg_display(P3);
- oe = 0;
- void timer0() interrupt 1
- clk = ~clk;
ADC0809數字電壓表全部資料下載:
19 ADC0809模數轉換與顯示電壓.rar
(48.42 KB, 下載次數: 168)
2016-4-18 18:03 上傳
