1】
* @file Project/STM32F4xx_StdPeriph_Templates/main.c
* @author MCD Application Team
* @version V1.3.0
* @date 13-November-2013
* @brief Main program body
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t uwTimingDelay;
RCC_ClocksTypeDef RCC_Clocks;
int main(void)
/* SysTick end of count event each 10ms */
RCC_GetClocksFreq(&RCC_Clocks);
SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
Delay(5);
while (1)
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds.
* @retval None
void Delay(__IO uint32_t nTime)
uwTimingDelay = nTime;
while(uwTimingDelay != 0);
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
if (uwTimingDelay != 0x00)
uwTimingDelay--;
2】
* @file Project/STM32F4xx_StdPeriph_Templates/main.h
* @version V1.3.0
* @brief Header for main.c module
* @attention
* <h2><center>© COPYRIGHT 2013 STMicroelectronics</center></h2>
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __MAIN_H
#define __MAIN_H
#include "stm32f4xx.h"
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
void TimingDelay_Decrement(void);
#endif /* __MAIN_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
3】
* @file Project/STM32F4xx_StdPeriph_Templates/stm32f4xx_it.c
* @version V1.3.0
* @brief Main Interrupt Service Routines.
* This file provides template for all exceptions handler and
* peripherals interrupt service routine.
* @attention
#include "stm32f4xx_it.h"
#include "main.h"
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/* Cortex-M4 Processor Exceptions Handlers */
* @brief This function handles NMI exception.
* @param None
* @retval None
void NMI_Handler(void)
* @brief This function handles Hard Fault exception.
* @param None
* @retval None
void HardFault_Handler(void)
/* Go to infinite loop when Hard Fault exception occurs */
while (1)
* @brief This function handles Memory Manage exception.
* @param None
* @retval None
void MemManage_Handler(void)
/* Go to infinite loop when Memory Manage exception occurs */
while (1)
* @brief This function handles Bus Fault exception.
* @param None
* @retval None
void BusFault_Handler(void)
/* Go to infinite loop when Bus Fault exception occurs */
while (1)
* @brief This function handles Usage Fault exception.
* @param None
* @retval None
void UsageFault_Handler(void)
/* Go to infinite loop when Usage Fault exception occurs */
while (1)
* @brief This function handles SVCall exception.
* @param None
* @retval None
void SVC_Handler(void)
* @brief This function handles Debug Monitor exception.
* @param None
* @retval None
void DebugMon_Handler(void)
* @brief This function handles PendSVC exception.
* @param None
* @retval None
void PendSV_Handler(void)
* @brief This function handles SysTick Handler.
* @param None
* @retval None
void SysTick_Handler(void)
TimingDelay_Decrement();
