* @file Project/Template/main.c
* @author MCD Application Team
* @version V3.0.0
* @date 04/06/2009
* @brief Main program body
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "misc.h"
#include "stm32f10x_conf.h"
#include "stdio.h"
#include "stdlib.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define SYSCLK_FREQ_HSE
#define TIMx_PRE_EMPTION_PRIORITY 1
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
#define CONTROL_PORT GPIOE
#define AXIS_PULSE_1 GPIO_Pin_0
#define AXIS_PULSE_2 GPIO_Pin_2
#define AXIS_PULSE_3 GPIO_Pin_4
#define AXIS_PULSE_4 GPIO_Pin_6
#define AXIS_DIR_1 GPIO_Pin_1
#define AXIS_DIR_2 GPIO_Pin_3
#define AXIS_DIR_3 GPIO_Pin_5
#define AXIS_DIR_4 GPIO_Pin_7
#define AXIS_LMTPOS_1 GPIO_Pin_8
#define AXIS_LMTNEG_1 GPIO_Pin_9
#define AXIS_LMTPOS_2 GPIO_Pin_10
#define AXIS_LMTNEG_2 GPIO_Pin_11
#define AXIS_LMTPOS_3 GPIO_Pin_12
#define AXIS_LMTNEG_3 GPIO_Pin_13
#define AXIS_LMTPOS_4 GPIO_Pin_14
#define AXIS_LMTNEG_4 GPIO_Pin_15
#define AXIS_HOME_1 GPIO_Pin_0
#define AXIS_HOME_2 GPIO_Pin_1
#define AXIS_HOME_3 GPIO_Pin_2
#define AXIS_HOME_4 GPIO_Pin_3
#define POSITIVE 1
#define NEGATIVE -1
#define CW 0
#define CCW 1
typedef struct {
//! What part of the speed ramp we are in.
u8 run_state ;
//! Direction stepper motor should move.
u8 dir ;
//! Peroid of next timer delay. At start this value set the accelration rate.
s32 step_delay;
//! What step_pos to start decelaration
u32 decel_start;
//! Sets deceleration rate.
s32 decel_val;
//! Minimum time delay (max speed)
s32 min_delay;
//! Counter used when accelerateing/decelerateing to calculate step_delay.
s32 accel_count;
} speedRampData;
#define T1_FREQ 1000000
#define SPR 1600
// Maths constants. To simplify maths when calculating in AxisMoveRel().
#define ALPHA (2*3.14159/SPR) // 2*pi/spr
#define A_T_x100 ((long)(ALPHA*T1_FREQ*100)) // (ALPHA / T1_FREQ)*100
#define T1_FREQ_148 ((int)((T1_FREQ*0.676)/100)) // divided by 100 and scaled by 0.676
#define A_SQ (long)(ALPHA*2*100000*100000) //
#define A_x20000 (int)(ALPHA*20000) // ALPHA*20000
// Speed ramp states
#define STOP 0
#define ACCEL 1
#define DECEL 2
#define RUN 3
s32 steps[4]={150000, 150000, 150000, 150000};//運動距離
u32 accel[4]={10000,10000, 10000, 10000};//加速度
u32 decel[4]={10000, 10000, 10000, 10000};//減速度
u32 speed[4]={10000, 10000, 10000, 10000};//速度
s32 stpdecel[4]={65000, 65000, 65000, 65000};//急停減速度
u8 addr485=0;
u8 LmtSnsPos[4]={1,1,1,1};//正限位電平
u8 LmtSnsNeg[4]={1,1,1,1};//負(fù)限位電平
u8 HomeSns[4]={1,1,1,1};//回零電平
s32 position[4]={0,0,0,0};//當(dāng)前位置
s32 HomePos[4]={0,0,0,0};//
s32 SoftLmtPos[4]={0x7fffffff, 0x7fffffff, 0x7fffffff, 0x7fffffff};
s32 SoftLmtNeg[4]={0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff};
u16 AxisPulsePin[4]={AXIS_PULSE_1, AXIS_PULSE_2, AXIS_PULSE_3, AXIS_PULSE_4};
u16 AxisDirPin[4]={AXIS_DIR_1, AXIS_DIR_2, AXIS_DIR_3, AXIS_DIR_4};
u16 LmtPosPin[4]={AXIS_LMTPOS_1, AXIS_LMTPOS_2, AXIS_LMTPOS_3, AXIS_LMTPOS_4};
u16 LmtNegPin[4]={AXIS_LMTNEG_1, AXIS_LMTNEG_2, AXIS_LMTNEG_3, AXIS_LMTNEG_4};
u16 HomePin[4]={AXIS_HOME_1, AXIS_HOME_2, AXIS_HOME_3, AXIS_HOME_4};
u16 AddrPin[4]={GPIO_Pin_7, GPIO_Pin_6, GPIO_Pin_15, GPIO_Pin_14};
GPIO_TypeDef *AxisLmtPosPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisLmtNegPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisPulsePort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *AxisDirPort[4]={GPIOE, GPIOE, GPIOE, GPIOE};
GPIO_TypeDef *HomePort[4]={GPIOC, GPIOC, GPIOC, GPIOC};
GPIO_TypeDef *AddrPort[4]={GPIOC, GPIOC, GPIOB, GPIOB};
uint32_t AxisEXTILine[4]={EXTI_Line0, EXTI_Line1, EXTI_Line2, EXTI_Line3};
uint8_t AxisEXTIPinSource[4]={GPIO_PinSource0, GPIO_PinSource1, GPIO_PinSource2, GPIO_PinSource3};
bool bLmtPos[4]={FALSE, FALSE, FALSE, FALSE};
bool bLmtNeg[4]={FALSE, FALSE, FALSE, FALSE};
bool bStopCmd[4]={FALSE, FALSE, FALSE, FALSE};
bool bEmgStopping[4]={FALSE, FALSE, FALSE, FALSE}; //是否碰限位急停
bool bEnableSoftLmt[4]={FALSE, FALSE, FALSE, FALSE};
bool bHomeOK[4]={FALSE, FALSE, FALSE, FALSE};
bool bZeroCapture[4]={FALSE, FALSE, FALSE, FALSE};
s32 ZeroDir[4]={POSITIVE, POSITIVE, POSITIVE, POSITIVE}; //回零方向
s32 ZeroOffset[4]={1000, 1000, 1000, 1000}; //零點偏移
u32 ZeroBackDistance[4]={6400, 6400, 6400, 6400}; //回零回退距離
u8 ZeroStep[4]={0, 0, 0, 0};
u32 HomeFastSpeed[4]={10000, 10000, 10000, 10000};//回零快搜速度
u32 HomeSlowSpeed[4]={2000, 2000, 2000, 2000};//回零慢搜速度
speedRampData srd[4];
enum
IDEL,
FASTSEEK,
FASTSEEKSTOP,
FASTSEEKBACK,
SLOWSEEK,
SLOWSEEKSTOP,
MOVETOZERO
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void NVIC_Configuration(void);
void Timer_Init(void);
void EXTILine_Config(void);
void GPIO_Configuration(void);
int fputc(int ch, FILE *f);
u8 MotionStatus[4]={0, 0, 0, 0};//是否在運動?0:停止,1:運動
bool bDataOK;
USART_InitTypeDef USART_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
uint8_t RxBuffer[12];
uint8_t RxCounter;
void AxisMoveRel(u32 axis, s32 step, u32 accel, u32 decel, u32 speed);
void AxisMoveAbs(u32 axis, s32 step, u32 accel, u32 decel, u32 speed);
u32 sqrt(u32 x);
void LimitDetect(u8 axis);
void USART_Configuration(void);
void AxisHome(u8 axis);
#define EnableHomeCapture1 EXTI->IMR |= GPIO_Pin_0
#define DisableHomeCapture1 EXTI->IMR &=~GPIO_Pin_0
#define EnableHomeCapture2 EXTI->IMR |= GPIO_Pin_1
#define DisableHomeCapture2 EXTI->IMR &=~GPIO_Pin_1
#define EnableHomeCapture3 EXTI->IMR |= GPIO_Pin_2
#define DisableHomeCapture3 EXTI->IMR &=~GPIO_Pin_2
#define EnableHomeCapture4 EXTI->IMR |= GPIO_Pin_3
#define DisableHomeCapture4 EXTI->IMR &=~GPIO_Pin_3
void EnableHomeCapture(u8 axis) {EXTI->IMR |=HomePin[axis];}
void DisableHomeCapture(u8 axis) {EXTI->IMR &=~HomePin[axis];}
* @brief Main program.
* @param None
* @retval : None
int main(void)
/* Setup STM32 system (clock, PLL and Flash configuration) */
u8 axis=0;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
for(axis=0; axis<4; axis++)
GPIO_InitStructure.GPIO_Pin = AxisPulsePin[axis];
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(AxisPulsePort[axis], &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = AxisDirPin[axis];
GPIO_Init(AxisDirPort[axis], &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=LmtPosPin[axis];
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
GPIO_Init(AxisLmtPosPort[axis], &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=LmtNegPin[axis];
GPIO_Init(AxisLmtNegPort[axis], &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=HomePin[axis];
GPIO_Init(HomePort[axis], &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=AddrPin[axis];
GPIO_Init(AddrPort[axis], &GPIO_InitStructure);
Timer_Init();
EXTILine_Config();
NVIC_Configuration();
// AxisMoveRel(1, 550000, 25000, 25000, 50000);
// AxisMoveRel(2, 550000, 32000, 32000, 40000);
// AxisMoveRel(3, 550000, 20000, 20000, 60000);
// AxisMoveRel(4, 550000, 30000, 30000, 45000);
while (1)
LimitDetect(1);
LimitDetect(2);
LimitDetect(3);
LimitDetect(4);
AxisHome(1);
AxisHome(2);
AxisHome(3);
AxisHome(4);
USART_SendData(USART1, (uint8_t) ch); /*發(fā)送一個字符函數(shù)*/
/* Loop until the end of transmission */
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)/*等待發(fā)送完成*/
return ch;
// GPIO_InitTypeDef GPIO_InitStructure;
// /* GPIOA Configuration:TIM2 Channel1, 2, 3 and 4 as alternate function push-pull */
// GPIO_InitStructure.GPIO_Pin =AXIS_PULSE_1 | AXIS_PULSE_2 |AXIS_PULSE_3 | AXIS_PULSE_4 | AXIS_DIR_1 | AXIS_DIR_2 | AXIS_DIR_3 | AXIS_DIR_4;
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
// GPIO_Init(CONTROL_PORT, &GPIO_InitStructure);
// GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
// GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
// GPIO_Init(MACHINPUT_PORT, &GPIO_InitStructure);
void Timer_Init(void)//定時器配置
uint16_t PrescalerValue;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
TIM_TimeBaseStructure.TIM_Period =65535;
TIM_TimeBaseStructure.TIM_Prescaler =0; //1 MHz
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
PrescalerValue=(uint16_t) ((SystemFrequency_SysClk / 2) / 1000000) - 1;
TIM_PrescalerConfig(TIM2, PrescalerValue, TIM_PSCReloadMode_Immediate);
TIM_PrescalerConfig(TIM3, PrescalerValue, TIM_PSCReloadMode_Immediate);
TIM_PrescalerConfig(TIM4, PrescalerValue, TIM_PSCReloadMode_Immediate);
TIM_PrescalerConfig(TIM5, PrescalerValue, TIM_PSCReloadMode_Immediate);
/* Output Compare Active Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Active;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 10;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
TIM_OC1Init(TIM4, &TIM_OCInitStructure);
TIM_OC1Init(TIM5, &TIM_OCInitStructure);
TIM_ClearFlag(TIM2, TIM_FLAG_Update);
TIM_ClearFlag(TIM3, TIM_FLAG_Update);
TIM_ClearFlag(TIM4, TIM_FLAG_Update);
TIM_ClearFlag(TIM5, TIM_FLAG_Update);
/* TIM IT enable */
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
TIM_ITConfig(TIM5, TIM_IT_Update, ENABLE);
void NVIC_Configuration(void)//中斷向量配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
//設(shè)置向量表的位置和偏移
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); //向量表位于RAM
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); //向量表位于FLASH
#endif
/* Enable the TIM2 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
/* Enable the USART1 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; //使能按鍵所在的外部中斷通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //先占優(yōu)先級4位,共16級
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //先占優(yōu)先級0位,從優(yōu)先級4位
NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
void EXTILine_Config(void)//外部中斷配置
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, AxisEXTIPinSource[0]);
EXTI_InitStructure.EXTI_Line = AxisEXTILine[0] | AxisEXTILine[1] | AxisEXTILine[2] | AxisEXTILine[3];
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
void LimitDetect(u8 axis)//限位開關(guān)檢測,axis參數(shù)是軸號
if(GPIO_ReadInputDataBit(AxisLmtPosPort[axis-1], LmtPosPin[axis-1]))
if(LmtSnsPos[axis-1]==0)
bLmtPos[axis-1]=FALSE;
bLmtPos[axis-1]=TRUE;
if(GPIO_ReadInputDataBit(AxisLmtNegPort[axis-1], LmtNegPin[axis-1]))
if(LmtSnsNeg[axis-1]==0)
bLmtNeg[axis-1]=FALSE;
bLmtNeg[axis-1]=TRUE;
void AxisHome(u8 axis)//軸回零程序,axis參數(shù)是軸號
axis--;
switch(ZeroStep[axis])
case IDEL:
break;
case FASTSEEK:
if(!MotionStatus[axis])
if(bZeroCapture[axis])
ZeroStep[axis]=FASTSEEKBACK;
bZeroCapture[axis]=FALSE;
AxisMoveRel(axis+1, (position[axis]-HomePos[axis]+ZeroBackDistance[axis])*ZeroDir[axis]*-1, accel[axis], decel[axis], HomeFastSpeed[axis]);
ZeroStep[axis]=IDEL;
break;
case FASTSEEKSTOP:
break;
case FASTSEEKBACK:
switch(axis)
case 0:
EnableHomeCapture1;
break;
case 1:
EnableHomeCapture2;
break;
case 2:
EnableHomeCapture3;
break;
case 3:
EnableHomeCapture4;
break;
AxisMoveRel(axis+1, 0x7FFFFFFF*ZeroDir[axis], accel[axis], decel[axis], HomeSlowSpeed[axis]);
ZeroStep[axis]=SLOWSEEK;
break;
case SLOWSEEK:
ZeroStep[axis]=MOVETOZERO;
AxisMoveRel(axis+1, (position[axis]-HomePos[axis]+ZeroOffset[axis])*ZeroDir[axis]*-1, accel[axis], decel[axis], HomeFastSpeed[axis]);
break;
case SLOWSEEKSTOP:
break;
case MOVETOZERO:
position[axis]=0;
break;
void AxisMoveAbs(u32 axis, s32 step, u32 accel, u32 decel, u32 speed)//絕對運動,axis參數(shù)是軸號,step是目標(biāo)位置,accel是加速度,decel是減速度,speed是速度
//! Number of steps before we hit max speed.
u32 max_s_lim;
//! Number of steps before we must start deceleration (if accel does not hit max speed).
u32 accel_lim;
float ftemp=0.0;
step=step-position[axis-1];
if(step <0)
return;
return;
srd[axis-1].dir = CCW;
GPIO_ResetBits(AxisDirPort[axis-1], AxisDirPin[axis-1]);
step =-step;
return;
return;
srd[axis-1].dir = CW;
GPIO_SetBits(AxisDirPort[axis-1], AxisDirPin[axis-1]);
if(step == 1)
// Move one step...
srd[axis-1].accel_count = -1;
// ...in DECEL state.
srd[axis-1].run_state = DECEL;
// Just a short delay so main() can act on 'running'.
srd[axis-1].step_delay = 1000;
switch(axis)
case 1:
TIM2->CCR1=10;
TIM2->ARR=10;
break;
case 2:
TIM3->CCR1=10;
TIM3->ARR=10;
break;
case 3:
TIM4->CCR1=10;
TIM4->ARR=10;
break;
case 4:
TIM5->CCR1=10;
TIM5->ARR=10;
break;
MotionStatus[axis-1] = 1;
switch(axis)
case 1:
TIM_Cmd(TIM2, ENABLE);
break;
case 2:
TIM_Cmd(TIM3, ENABLE);
break;
case 3:
TIM_Cmd(TIM4, ENABLE);
break;
case 4:
TIM_Cmd(TIM5, ENABLE);
break;
// Only move if number of steps to move is not zero.
else if(step != 0)
// Refer to documentation for detailed information about these calculations.
// Set max speed limit, by calc min_delay to use in timer.
// min_delay = (alpha / tt)/ w
srd[axis-1].min_delay = T1_FREQ/speed/2;
// Set accelration by calc the first (c0) step delay .
// step_delay = 1/tt * sqrt(2*alpha/accel)
// step_delay = ( tfreq*0.676/100 )*100 * sqrt( (2*alpha*10000000000) / (accel*100) )/10000
srd[axis-1].step_delay = ((long)T1_FREQ*0.676* sqrt(2000000 / accel))/1000/2;
// Find out after how many steps does the speed hit the max speed limit.
// max_s_lim = speed^2 / (2*alpha*accel)
max_s_lim = speed*speed/(2*accel);
// If we hit max speed limit before 0,5 step it will round to 0.
// But in practice we need to move atleast 1 step to get any speed at all.
if(max_s_lim == 0){
max_s_lim = 1;
// Find out after how many steps we must start deceleration.
// n1 = (n1+n2)decel / (accel + decel)
if((accel+decel)>step)
// accel_lim = step*decel/(accel+decel);
ftemp=(float)decel/(float)(accel+decel);
accel_lim = (float)step*ftemp;
accel_lim = step/(accel+decel)*decel;
// We must accelrate at least 1 step before we can start deceleration.
if(accel_lim == 0){
accel_lim = 1;
// Use the limit we hit first to calc decel.
if(accel_lim <= max_s_lim){
srd[axis-1].decel_val = accel_lim - step;
else{
srd[axis-1].decel_val =-(s32)(max_s_lim*accel/decel);
// We must decelrate at least 1 step to stop.
if(srd[axis-1].decel_val == 0){
srd[axis-1].decel_val = -1;
// Find step to start decleration.
srd[axis-1].decel_start = step + srd[axis-1].decel_val;
// If the maximum speed is so low that we dont need to go via accelration state.
if(srd[axis-1].step_delay <= srd[axis-1].min_delay)
srd[axis-1].step_delay = srd[axis-1].min_delay;
srd[axis-1].run_state = RUN;
else{
srd[axis-1].run_state = ACCEL;
// Reset counter.
srd[axis-1].accel_count = 0;
//OCR1A = 10;
switch(axis)
case 1:
TIM2->CCR1=10;
TIM2->ARR=10;
break;
case 2:
TIM3->CCR1=10;
TIM3->ARR=10;
break;
case 3:
TIM4->CCR1=10;
TIM4->ARR=10;
break;
case 4:
TIM5->CCR1=10;
TIM5->ARR=10;
break;
// Set Timer/Counter to divide clock by 8
//TCCR1B |= ((0<<CS12)|(1<<CS11)|(0<<CS10));
switch(axis)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
void AxisMoveRel(u32 axis, s32 step, u32 accel, u32 decel, u32 speed)//相對運動
u32 max_s_lim;
u32 accel_lim;
float ftemp=0.0;
if(step <0)
return;
return;
step =-step;
return;
return;
if(step == 1)
// Move one step...
switch(axis)
case 1:
TIM2->CCR1=10;
TIM2->ARR=10;
break;
case 2:
TIM3->CCR1=10;
TIM3->ARR=10;
break;
case 3:
TIM4->CCR1=10;
TIM4->ARR=10;
break;
case 4:
TIM5->CCR1=10;
TIM5->ARR=10;
break;
switch(axis)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
else if(step != 0)
if(max_s_lim == 0){
max_s_lim = 1;
if(accel_lim == 0){
accel_lim = 1;
else{
else{
// Reset counter.
//OCR1A = 10;
switch(axis)
case 1:
TIM2->CCR1=10;
TIM2->ARR=10;
break;
case 2:
TIM3->CCR1=10;
TIM3->ARR=10;
break;
case 3:
TIM4->CCR1=10;
TIM4->ARR=10;
break;
case 4:
TIM5->CCR1=10;
TIM5->ARR=10;
break;
switch(axis)
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
void TIM2_IRQHandler(void)//1軸定時器中斷處理
// Holds next delay period.
u16 new_step_delay;
// Remember the last step delay used when accelrating.
static u16 last_accel_delay;
// Counting steps when moving.
static u32 step_count = 0;
// Keep track of remainder from new_step-delay calculation to incrase accurancy
static s32 rest = 0;
static u8 i=0;
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
/* Clear TIM2 Capture Compare1 interrupt pending bit*/
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
TIM2->CCR1=srd[0].step_delay;
TIM2->ARR=srd[0].step_delay;
// OCR1A = srd.step_delay; //
if(srd[0].run_state)
if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_1)==1)
GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_1);
GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_1);
//PORTD^=BIT(5);
i++;
if(i==2)
i=0;
switch(srd[0].run_state)
case STOP:
step_count = 0;
rest = 0;
TIM_Cmd(TIM2, DISABLE);
MotionStatus[0] = 0;
bEmgStopping[0]=FALSE;
break;
case ACCEL:
//sm_driver_StepCounter(srd.dir);
step_count++;
if(srd[0].dir==CW)
position[0]++;
// if(bLmtPos[0])
// srd[0].run_state = STOP;
// break;
position[0]--;
// if(bLmtNeg[0])
// break;
srd[0].accel_count++;
new_step_delay = srd[0].step_delay - (((2 * (long)srd[0].step_delay) + rest)/(4 * srd[0].accel_count + 1));
rest = ((2 * (long)srd[0].step_delay)+rest)%(4 * srd[0].accel_count + 1);
if(step_count >= srd[0].decel_start || bStopCmd[0] || (bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW))
if(bStopCmd[0])
bStopCmd[0]=FALSE;
srd[0].accel_count = T1_FREQ/2/stpdecel[0]*T1_FREQ/srd[0].step_delay/srd[0].step_delay*-1;
else if((bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW))
bEmgStopping[0]=TRUE;
srd[0].accel_count = srd[0].decel_val;
srd[0].run_state = DECEL;
else if(new_step_delay <= srd[0].min_delay)
last_accel_delay = new_step_delay;
new_step_delay = srd[0].min_delay;
rest = 0;
srd[0].run_state = RUN;
break;
case RUN:
step_count++;
if(srd[0].dir==CW)
position[0]++;
// if(bLmtPos[0])
// break;
position[0]--;
// if(bLmtNeg[0])
// break;
if(bStopCmd[0])
bStopCmd[0]=FALSE;
// Start decelration with same delay as accel ended with.
new_step_delay = last_accel_delay;
break;
case DECEL:
step_count++;
if(srd[0].dir==CW)
position[0]++;
// if(bLmtPos[0])
// break;
position[0]--;
// if(bLmtNeg[0])
// break;
if(bStopCmd[0])
bStopCmd[0]=FALSE;
else if(!bEmgStopping[0] && ((bLmtPos[0] && srd[0].dir==CW) || (bLmtNeg[0] && srd[0].dir==CCW)))
if(srd[0].accel_count >= 0)
break;
srd[0].step_delay = new_step_delay;
void TIM3_IRQHandler(void)//2軸定時器中斷處理
u16 new_step_delay;
static u8 i=0;
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
TIM3->CCR1=srd[1].step_delay;
TIM3->ARR=srd[1].step_delay;
if(srd[1].run_state)
if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_2)==1)
GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_2);
GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_2);
i++;
if(i==2)
i=0;
switch(srd[1].run_state)
case STOP:
step_count = 0;
rest = 0;
TIM_Cmd(TIM3, DISABLE);
MotionStatus[1] = 0;
bEmgStopping[1]=FALSE;
break;
case ACCEL:
step_count++;
if(srd[1].dir==CW)
position[1]++;
// if(bLmtPos[1])
// srd[1].run_state = STOP;
// break;
position[1]--;
// if(bLmtNeg[1])
// break;
srd[1].accel_count++;
new_step_delay = srd[1].step_delay - (((2 * (long)srd[1].step_delay) + rest)/(4 * srd[1].accel_count + 1));
rest = ((2 * (long)srd[1].step_delay)+rest)%(4 * srd[1].accel_count + 1);
if(step_count >= srd[1].decel_start || bStopCmd[1] || (bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW))
if(bStopCmd[1])
bStopCmd[1]=FALSE;
srd[1].accel_count = T1_FREQ/2/stpdecel[1]*T1_FREQ/srd[1].step_delay/srd[1].step_delay*-1;
else if((bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW))
bEmgStopping[1]=TRUE;
srd[1].accel_count = srd[1].decel_val;
srd[1].run_state = DECEL;
else if(new_step_delay <= srd[1].min_delay)
new_step_delay = srd[1].min_delay;
rest = 0;
srd[1].run_state = RUN;
break;
case RUN:
step_count++;
if(srd[1].dir==CW)
position[1]++;
// if(bLmtPos[1])
// break;
position[1]--;
// if(bLmtNeg[1])
// break;
// Chech if we should start decelration.
if(bStopCmd[1])
bStopCmd[1]=FALSE;
break;
case DECEL:
step_count++;
if(srd[1].dir==CW)
position[1]++;
// if(bLmtPos[1])
// break;
position[1]--;
// if(bLmtNeg[1])
// break;
if(bStopCmd[1])
bStopCmd[1]=FALSE;
else if(!bEmgStopping[1] && ((bLmtPos[1] && srd[1].dir==CW) || (bLmtNeg[1] && srd[1].dir==CCW)))
if(srd[1].accel_count >= 0)
break;
srd[1].step_delay = new_step_delay;
void TIM4_IRQHandler(void)//3軸定時器中斷處理
u16 new_step_delay;
static u8 i=0;
if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
TIM4->CCR1=srd[2].step_delay;
TIM4->ARR=srd[2].step_delay;
if(srd[2].run_state)
if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_3)==1)
GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_3);
GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_3);
i++;
if(i==2)
i=0;
switch(srd[2].run_state)
case STOP:
step_count = 0;
rest = 0;
TIM_Cmd(TIM4, DISABLE);
MotionStatus[2] = 0;
bEmgStopping[2]=FALSE;
break;
case ACCEL:
step_count++;
if(srd[2].dir==CW)
position[2]++;
// if(bLmtPos[2])
// srd[2].run_state = STOP;
// break;
position[2]--;
// if(bLmtNeg[2])
// break;
srd[2].accel_count++;
new_step_delay = srd[2].step_delay - (((2 * (long)srd[2].step_delay) + rest)/(4 * srd[2].accel_count + 1));
rest = ((2 * (long)srd[2].step_delay)+rest)%(4 * srd[2].accel_count + 1);
if(step_count >= srd[2].decel_start || bStopCmd[2] || (bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW))
if(bStopCmd[2])
bStopCmd[2]=FALSE;
srd[2].accel_count = T1_FREQ/2/stpdecel[2]*T1_FREQ/srd[2].step_delay/srd[2].step_delay*-1;
else if((bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW))
bEmgStopping[2]=TRUE;
srd[2].accel_count = srd[2].decel_val;
srd[2].run_state = DECEL;
else if(new_step_delay <= srd[2].min_delay)
new_step_delay = srd[2].min_delay;
rest = 0;
srd[2].run_state = RUN;
break;
case RUN:
step_count++;
if(srd[2].dir==CW)
position[2]++;
// if(bLmtPos[2])
// break;
position[2]--;
// if(bLmtNeg[2])
// break;
if(bStopCmd[2])
bStopCmd[2]=FALSE;
break;
case DECEL:
step_count++;
if(srd[2].dir==CW)
position[2]++;
// if(bLmtPos[2])
// break;
position[2]--;
// if(bLmtNeg[2])
// break;
new_step_delay = srd[2].step_delay - (2*srd[2].step_delay+rest)/(4*srd[2].accel_count+1);
rest = (2 * srd[2].step_delay+rest)%(4 * srd[2].accel_count + 1);
if(bStopCmd[2])
bStopCmd[2]=FALSE;
else if(!bEmgStopping[2] && ((bLmtPos[2] && srd[2].dir==CW) || (bLmtNeg[2] && srd[2].dir==CCW)))
if(srd[2].accel_count >= 0)
break;
srd[2].step_delay = new_step_delay;
void TIM5_IRQHandler(void)//4軸定時器中斷處理
u16 new_step_delay;
static u8 i=0;
if (TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM5, TIM_IT_Update);
TIM5->CCR1=srd[3].step_delay;
TIM5->ARR=srd[3].step_delay;
if(srd[3].run_state)
if(GPIO_ReadOutputDataBit(CONTROL_PORT, AXIS_PULSE_4)==1)
GPIO_ResetBits(CONTROL_PORT, AXIS_PULSE_4);
GPIO_SetBits(CONTROL_PORT, AXIS_PULSE_4);
//PORTD^=BIT(5);
i++;
if(i==2)
{i=0;
switch(srd[3].run_state)
case STOP:
step_count = 0;
rest = 0;
TIM_Cmd(TIM5, DISABLE);
MotionStatus[3] = 0;
bEmgStopping[3]=FALSE;
break;
case ACCEL:
step_count++;
if(srd[3].dir==CW)
position[3]++;
// if(bLmtPos[3])
// srd[3].run_state = STOP;
// break;
position[3]--;
// if(bLmtNeg[3])
// break;
srd[3].accel_count++;
new_step_delay = srd[3].step_delay - (((2 * (long)srd[3].step_delay) + rest)/(4 * srd[3].accel_count + 1));
rest = ((2 * (long)srd[3].step_delay)+rest)%(4 * srd[3].accel_count + 1);
if(step_count >= srd[3].decel_start || bStopCmd[3] || (bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW))
if(bStopCmd[3])
bStopCmd[3]=FALSE;
srd[3].accel_count = T1_FREQ/2/stpdecel[3]*T1_FREQ/srd[3].step_delay/srd[3].step_delay*-1;
else if((bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW))
bEmgStopping[3]=TRUE;
srd[3].accel_count = srd[3].decel_val;
srd[3].run_state = DECEL;
else if(new_step_delay <= srd[3].min_delay)
new_step_delay = srd[3].min_delay;
rest = 0;
srd[3].run_state = RUN;
break;
case RUN:
step_count++;
if(srd[3].dir==CW)
position[3]++;
// if(bLmtPos[3])
// break;
position[3]--;
// if(bLmtNeg[3])
// break;
if(bStopCmd[3])
bStopCmd[3]=FALSE;
break;
case DECEL:
step_count++;
if(srd[3].dir==CW)
position[3]++;
// if(bLmtPos[3])
// break;
position[3]--;
// if(bLmtNeg[3])
// break;
if(bStopCmd[3])
bStopCmd[3]=FALSE;
else if(!bEmgStopping[3] && ((bLmtPos[3] && srd[3].dir==CW) || (bLmtNeg[3] && srd[3].dir==CCW)))
if(srd[3].accel_count >= 0)
break;
srd[3].step_delay = new_step_delay;
void EXTI0_IRQHandler(void)//1軸回零開關(guān)觸發(fā),記錄觸發(fā)時的位置值
if(EXTI_GetITStatus(EXTI_Line0) != RESET)
HomePos[0]=position[0];
bZeroCapture[0]=TRUE;
if(MotionStatus[0])
bStopCmd[0]=TRUE;
EXTI_ClearITPendingBit(EXTI_Line0);
DisableHomeCapture1;
void EXTI1_IRQHandler(void)//2軸回零開關(guān)觸發(fā),記錄觸發(fā)時的位置值
if(EXTI_GetITStatus(EXTI_Line1) != RESET)
HomePos[1]=position[1];
bZeroCapture[1]=TRUE;
if(MotionStatus[1])
bStopCmd[1]=TRUE;
EXTI_ClearITPendingBit(EXTI_Line1);
DisableHomeCapture2;
void EXTI2_IRQHandler(void)//3軸回零開關(guān)觸發(fā),記錄觸發(fā)時的位置值
if(EXTI_GetITStatus(EXTI_Line2) != RESET)
HomePos[2]=position[2];
bZeroCapture[2]=TRUE;
if(MotionStatus[2])
bStopCmd[2]=TRUE;
EXTI_ClearITPendingBit(EXTI_Line2);
DisableHomeCapture3;
void EXTI3_IRQHandler(void)//4軸回零開關(guān)觸發(fā),記錄觸發(fā)時的位置值
if(EXTI_GetITStatus(EXTI_Line3) != RESET)
HomePos[3]=position[3];
bZeroCapture[3]=TRUE;
if(MotionStatus[3])
bStopCmd[3]=TRUE;
EXTI_ClearITPendingBit(EXTI_Line3);
DisableHomeCapture4;
u32 sqrt(u32 x)//開方
register u32 xr; // result register
register u32 q2; // scan-bit register
register u8 f; // flag (one bit)
xr = 0; // clear result
q2 = 0x40000000L; // higest possible result bit
do
if((xr + q2) <= x)
x -= xr + q2;
f = 1; // set flag
else{
f = 0; // clear flag
xr >>= 1;
if(f){
xr += q2; // test flag
} while(q2 >>= 2); // shift twice
if(xr < x){
return xr +1; // add for rounding
else{
return xr;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval : None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
