1. 導(dǎo)線(信道):conduction (track) 2. 導(dǎo)線(體)寬度:conductor width 3. 導(dǎo)線距離:conductor spacing 4. 導(dǎo)線層:conductor layer 5. 導(dǎo)線寬度/間距:conductor line/space 6. 第一導(dǎo)線層:conductor layer No.1 7. 圓形盤:round pad 8. 方形盤:square pad 9. 菱形盤:diamond pad 10. 長(zhǎng)方形焊盤:oblong pad 11. 子彈形盤:bullet pad 12. 淚滴盤:teardrop pad 13. 雪人盤:snowman pad 14. V形盤:V-shaped pad 15. 環(huán)形盤:annular pad 16. 非圓形盤:non-circular pad 17. 隔離盤:isolation pad 18. 非功能連接盤:monfunctional pad 19. 偏置連接盤:offset land 20. 腹(背)裸盤:back-bard land 21. 盤址:anchoring spaur 22. 連接盤圖形:land pattern 23. 連接盤網(wǎng)格陣列:land grid array 24. 孔環(huán):annular ring 25. 組件孔:component hole 26. 安裝孔:mounting hole 27. 支撐孔:supported hole 28. 非支撐孔:unsupported hole 29. 導(dǎo)通孔:via 30. 鍍通孔:plated through hole (PTH) 31. 余隙孔:access hole 32. 盲孔:blind via (hole) 33. 埋孔:buried via hole 34. 埋/盲孔:buried /blind via 35. 任意層內(nèi)部導(dǎo)通孔:any layer inner via hole (ALIVH) 36. 全部鉆孔:all drilled hole 37. 定位孔:toaling hole 38. 無連接盤孔:landless hole 39. 中間孔:interstitial hole 40. 無連接盤導(dǎo)通孔:landless via hole 41. 引導(dǎo)孔:pilot hole 42. 端接全隙孔:terminal clearomee hole 43. 準(zhǔn)表面間鍍覆孔:quasi-interfacing plated-through hole 44. 準(zhǔn)尺寸孔:dimensioned hole 45. 在連接盤中導(dǎo)通孔:via-in-pad 46. 孔位:hole location 47. 孔密度:hole density 48. 孔圖:hole pattern 49. 鉆孔圖:drill drawing 50. 裝配圖:assembly drawing 51. 印制板組裝圖:printed board assembly drawing 52. 參考基準(zhǔn):datum referan
