查看: 2676|回復(fù): 0
PCB設(shè)計(jì)中專業(yè)英譯術(shù)語之綜合詞匯
ID:156167 發(fā)表于 2018-4-27 09:34 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. 板:board
  2. 印制板:printed board
  3. 印制電路:printed circuit
  4. 印制線路:printed wiring
  5. 印制線路板:printed wiring board(PWB)
  6. 印制板電路:printed circuit board (PCB)
  7. 印制接點(diǎn):printed contact
  8. 印制組件:printed component
  9. 印制板裝配:printed board assembly
  10. 單面印制板:single-sided printed board(SSB)
  11. 雙面印制板:double-sided printed board(DSB)
  12. 多層印制板:mulitlayer printed board(MLB)
  13. 多層印制電路板:mulitlayer printed circuit board
  14. 多層印制線路板:mulitlayer prited wiring board
  15. 剛性印制板:rigid printed board
  16. 剛性單面印制板:rigid single-sided printed borad
  17. 剛性雙面印制印制板裝配:printed board assembly
  18. 剛性多層印制板:rigid multilayer printed board
  19. 撓性多層印制板:flexible multilayer printed board
  20. 撓性印制板:flexible printed board
  21. 撓性單面印制板:flexible single-sided printed board
  22. 撓性雙面印制板:flexible double-sided printed board
  23. 撓性印制電路:flexible printed circuit (FPC)
  24. 撓性印制線路:flexible printed wiring
  25. 剛性印制板:flex-rigid printed board, rigid-flex printed board
  26. 剛性雙面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
  27. 剛性多層印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
  28. 齊平印制板:flush printed board
  29. 金屬芯印制板:metal core printed board
  30. 金屬基印制板:metal base printed board
  31. 多重布線印制板:mulit-wiring printed board
  32. 陶瓷印制板:ceramic substrate printed board
  33. 導(dǎo)電膠印制板:electroconductive paste printed board
  34. 模塑電路板:molded circuit board
  35. 模壓印制板:stamped printed wiring board
  36. 順序?qū)訅憾鄬佑≈瓢澹簊equentially-laminated mulitlayer
  37. 散線印制板:discrete wiring board
  38. 微線印制板:micro wire board
  39. 積層印制板:buile-up printed board
  40. 積層多層印制板:build-up mulitlayer printed board (BUM)
  41. 積層撓印制板:build-up flexible printed board
  42. 表面層合電路板:surface laminar circuit (SLC)
  43. 埋入凸塊連印制板:B2it printed board
  44. 多層膜基板:multi-layered film substrate(MFS)
  45. 層間全內(nèi)導(dǎo)通多層印制板:ALIVH multilayer printed board
  46. 載芯片板:chip on board (COB)
  47. 埋電阻板:buried resistance board
  48. 母板:mother board
  49. 子板:daughter board
  50. 背板:backplane
  51. 裸板:bare board
  52. 鍵盤板夾心板:copper-invar-copper board
  53. 動(dòng)態(tài)撓性板:dynamic flex board
  54. 靜態(tài)撓性板:static flex board
  55. 可斷拼板:break-away planel
  56. 電纜:cable
  57. 撓性扁平電纜:flexible flat cable (FFC)
  58. 薄膜開關(guān):membrane switch
  59. 混合電路:hybrid circuit
  60. 厚膜:thick film
  61. 厚膜電路:thick film circuit
  62. 薄膜:thin film
  63. 薄膜混合電路:thin film hybrid circuit
  64. 互連:interconnection
  65. 導(dǎo)線:conductor trace line
  66. 齊平導(dǎo)線:flush conductor
  67. 傳輸線:transmission line
  68. 跨交:crossover
  69. 板邊插頭:edge-board contact
  70. 增強(qiáng)板:stiffener
  71. 基底:substrate
  72. 基板面:real estate
  73. 導(dǎo)線面:conductor side
  74. 組件面:component side
  75. 焊接面:solder side
  76. 印制:printing
  77. 網(wǎng)格:grid
  78. 圖形:pattern
  79. 導(dǎo)電圖形:conductive pattern
  80. 非導(dǎo)電圖形:non-conductive pattern
  81. 字符:legend
  82. 標(biāo)志:mark
