查看: 1688|回復: 0
單片機矩陣鍵盤源程序
ID:198664 發表于 2017-5-9 15:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#define uint  unsigned int
sbit we = P2^7;
sbit du = P2^6;
uchar code leddata[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄滅
                0x00  //自定義
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
uchar KeyScan()        //帶返回值的子函數
        uchar cord_l,cord_h;//聲明列線和行線的值的儲存變量
        P3 = 0x0f;//0000 1111
        if( (P3 & 0x0f) != 0x0f)//判斷是否有按鍵按下
                delay(5);//軟件消抖
                          cord_h = P3 & 0x0f;// 儲存行線值
                          P3 = cord_l | 0xf0;
                          cord_l = P3 & 0xf0;// 儲存列線值
                          while( (P3 & 0xf0) != 0xf0 );//松手檢測
                          return (cord_l + cord_h);//返回鍵值碼
void KeyPro()
        switch( KeyScan() )
                 //第一行鍵值碼
                case 0xee: P0 = leddata[0];                break;
                case 0xde: P0 = leddata[1];                break;
                case 0xbe: P0 = leddata[2];                break;
                case 0x7e: P0 = leddata[3];                break;
                //第二行鍵值碼
                case 0xed: P0 = leddata[4];                break;
                case 0xdd: P0 = leddata[5];                break;
                case 0xbd: P0 = leddata[6];                break;
                case 0x7d: P0 = leddata[7];                break;
                //第三行鍵值碼
                case 0xeb: P0 = leddata[8];                break;
                case 0xdb: P0 = leddata[9];                break;
                case 0xbb: P0 = leddata[10];        break;
                case 0x7b: P0 = leddata[11];        break;
                //第四行鍵值碼
                case 0xe7: P0 = leddata[12];        break;
                case 0xd7: P0 = leddata[13];        break;
                case 0xb7: P0 = leddata[14];        break;
                case 0x77: P0 = leddata[15];        break;
                //獨立鍵盤
                case 0xfe: P0 = leddata[16];        break;
                case 0xfd: P0 = leddata[17];        break;
                case 0xfb: P0 = leddata[18];        break;
                case 0xf7: P0 = leddata[19];        break;
        we = 1;//打開位選
        P0 = 0;//八位數碼管全顯示
        we = 0;//鎖存位選
        du = 1;//打開段選端
        P0 = leddata[22];
                 KeyPro();//提取鍵值碼并且送不同數值給數碼管顯示
