我要寫(xiě)一個(gè)藍(lán)牙控制RGB變色和兩個(gè)光電傳感器計(jì)數(shù)的程序
單個(gè)的模塊可以實(shí)現(xiàn),但是我在往一起合的時(shí)候,就不能了
而且發(fā)現(xiàn)功能會(huì)互相影響,求大神幫我改一下代碼,說(shuō)一下
思路,怎么才能兩個(gè)同時(shí)運(yùn)行,,很急..- #include <reg52.h>
- #include <string.h>
- #include <intrins.h>
- #define LCD1602_DB P0
- unsigned char tmp;
- unsigned int c=0;
- unsigned char flag1s = 0;
- unsigned char flag2s = 0;
- unsigned char counter = 0;//jishu
- unsigned char str[] = "COUNT: ";
- sbit LCD1602_RS = P1^0;
- sbit LCD1602_RW = P1^1;
- sbit LCD1602_E = P1^5;
- sbit red = P2^0;
- sbit LED = P2^2;
- sbit red1 = P2^1;
- sbit RR = P3^5;
- sbit GG = P3^6;
- sbit BB = P3^7;
- int PWM_0 = 0;
- int PWM_1 = 0;
- int PWM_2 = 0;
- void InitLcd1602();
- void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
- void itoa (unsigned int n,unsigned char s[5]);
- void keepred();
- void init(); //串口初始化
- void send(unsigned char a); //單字節(jié)發(fā)送函數(shù)
- void ctrl(); //接收處理函數(shù)
- void color();
- void keepPWM();
- void delay (unsigned char t) //延時(shí)
- unsigned char i;
- while(t--)
- for(i=0; i<114; i++);
- void main()
- unsigned int sec = 0, i=0, j = 0;
- unsigned char s[5] ;
- unsigned char x[6] = "none";
- init();
- red = 1;
- red1 = 1;
- TMOD = 0x21;
- TL0 = 0xC9; //設(shè)置定時(shí)初值
- TH0 = 0xFF;
- TR0 = 1;
- ET0 = 1;
- ET1 = 1;
- EA = 1;
- InitLcd1602();
- sec = 0;
- itoa(sec, s);
- LcdShowStr(8, 0, x);
- while(1)
- keepPWM();
- if(RI==1) // 是否有數(shù)據(jù)到來(lái)
- RI = 0;
- tmp = SBUF;
- ctrl();
- delay(5); // 暫存接收到的數(shù)據(jù)
- else if(flag1s == 1 )
- flag1s = 0;
- sec++;
- else if(flag2s == 1 )
- flag2s = 0;
- if(sec > 0)
- sec--;
- else if(sec<=0)
- sec = 0;
- else
- itoa(sec, s);
- memset(s, '\0', 5);
- delay(50);
- if(RI == 0)
- PWM_0 = PWM_0;
- PWM_1 = PWM_1;
- PWM_2 = PWM_2;
- delay(5);
- delay(5);
- void LcdWaitReady()
- unsigned char sta;
- LCD1602_DB = 0xFF;
- LCD1602_RS = 0;
- LCD1602_RW = 1;
- do {
- LCD1602_E = 1;
- sta = LCD1602_DB;
- LCD1602_E = 0;
- }while(sta & 0x80);
- void LcdWriteCmd(unsigned char cmd)
- LcdWaitReady();
- LCD1602_RS = 0;
- LCD1602_RW = 0;
- LCD1602_DB = cmd;
- LCD1602_E = 1;
- LCD1602_E = 0;
- void LcdWriteDat(unsigned char dat)
- LcdWaitReady();
- LCD1602_RS = 1;
- LCD1602_RW = 0;
- LCD1602_DB = dat;
- LCD1602_E = 1;
- LCD1602_E = 0;
- void LcdSetCursor(unsigned char x, unsigned char y)
- unsigned char addr;
- if(y == 0)
- addr = 0x00 + x;
- else
- addr = 0x40 + x;
- LcdWriteCmd(addr | 0x80);
- LcdSetCursor(x, y);
- while(*str != '\0')
- LcdWriteDat(*str++);
- LcdWriteCmd(0x38);
- LcdWriteCmd(0x0C);
- LcdWriteCmd(0x06);
- LcdWriteCmd(0x01);
- void itoa (unsigned int n,unsigned char s[])
- unsigned char temp;
- unsigned int i = 0;
- unsigned int len = 0;
- while(n != 0)
- s[i] = (n % 10) + '0' ;//算出字符
- n = n / 10;
- i++;
- s[i] = '\0';
- len = strlen(s);
- for(i = 0; i < len / 2; i++) //前后換順序
- temp = s[i];
- s[i] = s[len - 1 - i];
- s[len - 1 - i] = temp;
- LcdShowStr(1, 0, str);
- LcdShowStr(8, 0, s);
- s[0] = '\0';
- void keepPWM()//保持輸出
- if(PWM_0 <=0)
- PWM_0 =0;
- if(PWM_1 <=0)
- PWM_1 =0;
- if(PWM_2 <=0)
- PWM_2 =0;
- if(PWM_0 >=255)
- PWM_0 =255;
- if(PWM_1 >=255)
- PWM_1 =255;
- if(PWM_2 >=255)
- PWM_2 =255;
- void init() //串口初始化
- ES=0; //關(guān)中斷
- SCON = 0x50; // REN=1允許串行接受狀態(tài),串口工作模式1,
- //10位UART(1位起始位,8位數(shù)據(jù)位,1位停止位,無(wú)奇偶校驗(yàn)),波特率可變
- TMOD = 0x20; // 定時(shí)器1工作于方式2,8位自動(dòng)重載模式, 用于產(chǎn)生波特率
- TH1=TL1=0xFD; // 波特率9600 (本次測(cè)試采用晶振為11.0592)
- PCON &= 0x7f; // 波特率不倍增
- TR1 = 1; //定時(shí)器1開(kāi)始工作,產(chǎn)生波特率
- //發(fā)送標(biāo)志位置0
- TI=0; //接收標(biāo)志位置0
- RI=0;
- //EA=0;
- ES=1;
- /*void send(unsigned char a) //單字節(jié)數(shù)據(jù)發(fā)送
- //注意:若單片機(jī)TXD(P3.1)無(wú)上拉能力,必須在P3.1端接上拉電阻。本次測(cè)試需要接上拉電阻
- TI=0;
- SBUF=a;
- while(TI==0);
- TI=0;
- if(c%2) //發(fā)送指示燈標(biāo)志,每接收一次,此燈亮滅交替
- led=1;
- else
- led=0;
- c++;
- void ctrl() //接收處理函數(shù)
- switch(tmp)
- case '1': //白
- PWM_0 = 0;
- PWM_1 = 0;
- PWM_2 = 0;
- LED = ~LED;
- break;
- case '2':
- PWM_0 = 255-128; //紫
- PWM_1 = 255;
- PWM_2 = 255-128;
- LED = ~LED;
- break;
- case '3':
- PWM_0 = 255; //藍(lán)色
- PWM_1 = 255;
- PWM_2 = 0;
- LED = ~LED;
- break;
- case '4':
- PWM_0 = 30; // 淺藍(lán)
- PWM_1 = 100;
- PWM_2 = 255;
- LED = ~LED;
- break;
- case '5':
- PWM_0 = 255-33; // 灰
- PWM_1 = 255-33;
- PWM_2 = 255-33;
- LED = ~LED;
- break;
- case '6':
- PWM_0 = 254; // mie
- PWM_1 = 254;
- PWM_2 = 254;
- LED = ~LED;
- break;
- case 'a':
- PWM_0=PWM_0+5; // jiaqiang
- PWM_1=PWM_1+5;
- PWM_2=PWM_2+5;
- break;
- case 'b':
- PWM_0=PWM_0-5; // jianruo
- PWM_1=PWM_1-5;
- PWM_2=PWM_2-5;
- keepPWM();
- break;
- case 'c': //shanshuo
- color();
- LED = ~LED;
- break;
- default: //其他,燈全滅
- PWM_0 = 0; //hei
- PWM_1 = 0;
- PWM_2 = 0;
- // send(tmp);
- break;
- }delay(5);
- void color()
- { //隨機(jī)顏色
- while(RI==0)
- PWM_0 = rand()%255;
- delay(2);
- PWM_1 = rand()%255;
- delay(2);
- PWM_2 = rand()%255;
- delay(2);
- void InterruptTimer0() interrupt 1
- TH0 = 0xFC;
- TL0 = 0x67;
- if (red == 0&&red1==1) //兩個(gè)光電判斷人進(jìn)出
- delay(99);
- if(red1==0)
- flag1s = 1;
- if (red1 == 0&&red == 1)
- delay(99);
- if(red == 0)
- flag2s = 1;
- counter++;
- if(counter >= 255) counter = 0; //三路pWM輸出
- if(counter >= PWM_0) RR = 0; else RR = 1;
- if(counter >= PWM_1) GG = 0; else GG = 1;
- if(counter >= PWM_2) BB = 0; else BB = 1;
