查看: 3478|回復(fù): 0
RFID-RC522源程序
ID:198552 發(fā)表于 2017-5-9 11:27 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
#include "intrins.h"
#include "main.h"
#include "rc522.h"
#include "string.h"
void delay_ns(unsigned int ns)
        unsigned int i;
        for(i=0;i<ns;i++)
                nop();
                nop();
                nop();
// 讀SPI數(shù)據(jù)
unsigned char SPIReadByte(void)
        unsigned char SPICount;                                       // Counter used to clock out the data
        unsigned char SPIData;
        SPIData = 0;
        for (SPICount = 0; SPICount < 8; SPICount++)                  // Prepare to clock in the data to be read
                SPIData <<=1;                                               // Rotate the data
                CLR_SPI_CK; //nop();//nop();                                         // Raise the clock to clock the data out of the MAX7456
                if(STU_SPI_MISO)
                        SPIData|=0x01;
                SET_SPI_CK;   //nop();//nop();                                               // Drop the clock ready for the next bit
        }                                                             // and loop back
        return (SPIData);                              // Finally return the read data
// 寫SPI數(shù)據(jù)
void SPIWriteByte(unsigned char SPIData)
                if (SPIData & 0x80)
                        SET_SPI_MOSI;
                        CLR_SPI_MOSI;
                nop();nop();
                CLR_SPI_CK;nop();nop();
                SET_SPI_CK;nop();nop();
                SPIData <<= 1;
//功    能:讀RC632寄存器
//參數(shù)說明:Address[IN]:寄存器地址
//返    回:讀出的值
unsigned char ReadRawRC(unsigned char Address)
        unsigned char ucAddr;
    unsigned char ucResult=0;
        CLR_SPI_CS;
    ucAddr = ((Address<<1)&0x7E)|0x80;
        SPIWriteByte(ucAddr);
        ucResult=SPIReadByte();
        SET_SPI_CS;
        return ucResult;
//功    能:寫RC632寄存器
//          value[IN]:寫入的值
void WriteRawRC(unsigned char Address, unsigned char value)
        CLR_SPI_CS;
    ucAddr = ((Address<<1)&0x7E);
        SPIWriteByte(value);
        SET_SPI_CS;
//功    能:清RC522寄存器位
//參數(shù)說明:reg[IN]:寄存器地址
//          mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x00;
    tmp = ReadRawRC(reg);
    WriteRawRC(reg, tmp & ~mask);  // clear bit mask
//功    能:置RC522寄存器位
//          mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x00;
    WriteRawRC(reg,tmp | mask);  // set bit mask
//用MF522計(jì)算CRC16函數(shù)
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
    unsigned char i,n;
    ClearBitMask(DivIrqReg,0x04);
    WriteRawRC(CommandReg,PCD_IDLE);
    SetBitMask(FIFOLevelReg,0x80);
    for (i=0; i<len; i++)
    {   WriteRawRC(FIFODataReg, *(pIndata+i));   }
    WriteRawRC(CommandReg, PCD_CALCCRC);
    i = 0xFF;
    do
        n = ReadRawRC(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04));
    pOutData[0] = ReadRawRC(CRCResultRegL);
    pOutData[1] = ReadRawRC(CRCResultRegM);
//功    能:通過RC522和ISO14443卡通訊
//參數(shù)說明:Command[IN]:RC522命令字
//          pInData[IN]:通過RC522發(fā)送到卡片的數(shù)據(jù)
//          InLenByte[IN]:發(fā)送數(shù)據(jù)的字節(jié)長度
//          pOutData[OUT]:接收到的卡片返回?cái)?shù)據(jù)
//          *pOutLenBit[OUT]:返回?cái)?shù)據(jù)的位長度
char PcdComMF522(unsigned char Command,
                 unsigned char *pInData,
                 unsigned char InLenByte,
                 unsigned char *pOutData,
                 unsigned int *pOutLenBit)
    char status = MI_ERR;
    unsigned char irqEn   = 0x00;
    unsigned char waitFor = 0x00;
    unsigned char lastBits;
    unsigned char n;
    unsigned int i;
    switch (Command)
        case PCD_AUTHENT:
                        irqEn   = 0x12;
                        waitFor = 0x10;
                        break;
                case PCD_TRANSCEIVE:
                        irqEn   = 0x77;
                        waitFor = 0x30;
                        break;
                default:
                        break;
    WriteRawRC(ComIEnReg,irqEn|0x80);
    ClearBitMask(ComIrqReg,0x80);
    for (i=0; i<InLenByte; i++)
                WriteRawRC(FIFODataReg, pInData[i]);
    WriteRawRC(CommandReg, Command);
    if (Command == PCD_TRANSCEIVE)
                SetBitMask(BitFramingReg,0x80);
    //i = 600;//根據(jù)時(shí)鐘頻率調(diào)整,操作M1卡最大等待時(shí)間25ms
        i = 2000;
    do
        n = ReadRawRC(ComIrqReg);
        i--;
    while ((i!=0) && !(n&0x01) && !(n&waitFor));
    ClearBitMask(BitFramingReg,0x80);
    if (i!=0)
        if(!(ReadRawRC(ErrorReg)&0x1B))
            status = MI_OK;
            if (n & irqEn & 0x01)
            {   status = MI_NOTAGERR;   }
                       n = ReadRawRC(FIFOLevelReg);
                      lastBits = ReadRawRC(ControlReg) & 0x07;
                if (lastBits)
                                        *pOutLenBit = (n-1)*8 + lastBits;
                                        *pOutLenBit = n*8;
                if (n == 0)
                                        n = 1;
                if (n > MAXRLEN)
                                        n = MAXRLEN;
                for (i=0; i<n; i++)
                                        pOutData[i] = ReadRawRC(FIFODataReg);
                        status = MI_ERR;
    SetBitMask(ControlReg,0x80);           // stop timer now
    return status;
//功    能:尋卡
//參數(shù)說明: req_code[IN]:尋卡方式
//                0x52 = 尋感應(yīng)區(qū)內(nèi)所有符合14443A標(biāo)準(zhǔn)的卡
//                0x26 = 尋未進(jìn)入休眠狀態(tài)的卡
//          pTagType[OUT]:卡片類型代碼
//                0x4400 = Mifare_UltraLight
//                0x0400 = Mifare_One(S50)
//                0x0200 = Mifare_One(S70)
//                0x0800 = Mifare_Pro(X)
//                0x4403 = Mifare_DESFire
//返    回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
        char status;
        unsigned int unLen;
        unsigned char ucComMF522Buf[MAXRLEN];
        ClearBitMask(Status2Reg,0x08);
        WriteRawRC(BitFramingReg,0x07);
        SetBitMask(TxControlReg,0x03);
        ucComMF522Buf[0] = req_code;
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
        if ((status == MI_OK) && (unLen == 0x10))
                *pTagType     = ucComMF522Buf[0];
                *(pTagType+1) = ucComMF522Buf[1];
                status = MI_ERR;
        return status;
//功    能:防沖撞
//參數(shù)說明: pSnr[OUT]:卡片序列號,4字節(jié)
//返    回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
    char status;
    unsigned char i,snr_check=0;
    unsigned int unLen;
    WriteRawRC(BitFramingReg,0x00);
    ClearBitMask(CollReg,0x80);
    ucComMF522Buf[0] = PICC_ANTICOLL1;
    ucComMF522Buf[1] = 0x20;
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
    if (status == MI_OK)
                for (i=0; i<4; i++)
                        *(pSnr+i)  = ucComMF522Buf[i];
                        snr_check ^= ucComMF522Buf[i];
                if (snr_check != ucComMF522Buf[i])
                        status = MI_ERR;
    SetBitMask(CollReg,0x80);
    return status;
//功    能:選定卡片
//參數(shù)說明: pSnr[IN]:卡片序列號,4字節(jié)
//返    回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
    char status;
    unsigned char i;
    unsigned int unLen;
    ucComMF522Buf[1] = 0x70;
    ucComMF522Buf[6] = 0;
    for (i=0; i<4; i++)
            ucComMF522Buf[i+2] = *(pSnr+i);
            ucComMF522Buf[6]  ^= *(pSnr+i);
    CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x18))
                status = MI_OK;
                status = MI_ERR;
    return status;
//功    能:驗(yàn)證卡片密碼
//參數(shù)說明: auth_mode[IN]: 密碼驗(yàn)證模式
//                 0x60 = 驗(yàn)證A密鑰
//                 0x61 = 驗(yàn)證B密鑰
//          addr[IN]:塊地址
//          pKey[IN]:密碼
//          pSnr[IN]:卡片序列號,4字節(jié)
//返    回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
    char status;
    unsigned int unLen;
    ucComMF522Buf[0] = auth_mode;
    ucComMF522Buf[1] = addr;
        memcpy(&ucComMF522Buf[2], pKey, 6);
        memcpy(&ucComMF522Buf[8], pSnr, 6);
    status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
    if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
                status = MI_ERR;
    return status;
//功    能:讀取M1卡一塊數(shù)據(jù)
//參數(shù)說明: addr[IN]:塊地址
//          pData[OUT]:讀出的數(shù)據(jù),16字節(jié)
//返    回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int unLen;
    ucComMF522Buf[0] = PICC_READ;
    CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x90))
                memcpy(pData, ucComMF522Buf, 16);
                status = MI_ERR;
    return status;
//功    能:寫數(shù)據(jù)到M1卡一塊
//          pData[IN]:寫入的數(shù)據(jù),16字節(jié)
//返    回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int unLen;
    ucComMF522Buf[0] = PICC_WRITE;
    if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
                status = MI_ERR;
        memcpy(ucComMF522Buf, pData, 16);
        CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
                        status = MI_ERR;
    return status;
//功    能:命令卡片進(jìn)入休眠狀態(tài)
//返    回: 成功返回MI_OK
char PcdHalt(void)
    char status;
    unsigned int unLen;
    ucComMF522Buf[0] = PICC_HALT;
    ucComMF522Buf[1] = 0;
    return MI_OK;
//功    能:復(fù)位RC522
//返    回: 成功返回MI_OK
char PcdReset(void)
        SET_RC522RST;
    delay_ns(10);
        CLR_RC522RST;
    delay_ns(10);
        SET_RC522RST;
    delay_ns(10);
    WriteRawRC(CommandReg,PCD_RESETPHASE);
    delay_ns(10);
    WriteRawRC(ModeReg,0x3D);            //和Mifare卡通訊,CRC初始值0x6363
    WriteRawRC(TReloadRegL,30);
    WriteRawRC(TReloadRegH,0);
    WriteRawRC(TModeReg,0x8D);
    WriteRawRC(TPrescalerReg,0x3E);
        WriteRawRC(TxAutoReg,0x40);//必須要
    return MI_OK;
//設(shè)置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
   if (type == 'A')                     //ISO14443_A
       WriteRawRC(ModeReg,0x3D);//3F
       WriteRawRC(RxSelReg,0x86);//84
       WriteRawRC(RFCfgReg,0x7F);   //4F
              WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
           delay_ns(1000);
       PcdAntennaOn();
   else{ return -1; }
   return MI_OK;
//開啟天線
//每次啟動(dòng)或關(guān)閉天險(xiǎn)發(fā)射之間應(yīng)至少有1ms的間隔
void PcdAntennaOn(void)
    unsigned char i;
    i = ReadRawRC(TxControlReg);
    if (!(i & 0x03))
        SetBitMask(TxControlReg, 0x03);
//關(guān)閉天線
void PcdAntennaOff(void)
        ClearBitMask(TxControlReg, 0x03);
void init_rc522(void)
  PcdReset();
  PcdAntennaOff();
  PcdAntennaOn();
  M500PcdConfigISOType( 'A' );
//功    能:扣款和充值
//參數(shù)說明: dd_mode[IN]:命令字
//               0xC0 = 扣款
//               0xC1 = 充值
//          addr[IN]:錢包地址
//          pValue[IN]:4字節(jié)增(減)值,低位在前
//返    回: 成功返回MI_OK
/*char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
    char status;
    unsigned int  unLen;
    //unsigned char i;
    ucComMF522Buf[0] = dd_mode;
    {   status = MI_ERR;   }
        memcpy(ucComMF522Buf, pValue, 4);
        //for (i=0; i<16; i++)
        //{    ucComMF522Buf[i] = *(pValue+i);   }
        CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
        unLen = 0;
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
                if (status != MI_ERR)
        {    status = MI_OK;    }
        ucComMF522Buf[0] = PICC_TRANSFER;
    return status;
//功    能:備份錢包
//參數(shù)說明: sourceaddr[IN]:源地址
//          goaladdr[IN]:目標(biāo)地址
//返    回: 成功返回MI_OK
/*char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_RESTORE;
    ucComMF522Buf[1] = sourceaddr;
        ucComMF522Buf[0] = 0;
        ucComMF522Buf[2] = 0;
        ucComMF522Buf[3] = 0;
        {    status = MI_OK;    }
    if (status != MI_OK)
    {    return MI_ERR;   }
    ucComMF522Buf[1] = goaladdr;
    return status;
