只需一步,快速開(kāi)始
查看: 5911|回復(fù): 0
process(clk) 和process(Disp_Temp)這兩個(gè)進(jìn)程看不懂,求指教
ID:150793 發(fā)表于 2017-4-17 20:49 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE  IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.STD_LOGIC_ARItH.all;
ENTITY VHDL1 IS
   PORT (CLK,RST,EN : IN STD_LOGIC;
         Disp_Decode1:OUT STD_LOGIC_VECTOR(6 DOWNTO 0);
         DOUT1:OUT STD_LOGIC_VECTOR(1 DOWNTO 0)
END VHDL1;
ARCHITECTURE BEHAV OF VHDL1 IS
SIGNAL tmb,Disp_Temp : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL tma : STD_LOGIC_VECTOR(2 DOWNTO 0);
signal clk1hz:STD_LOGIC;
SIGNAL count : STD_LOGIC_VECTOR(1 DOWNTO 0);
signal Clk_Count1:STD_LOGIC_VECTOR(13 DOWNTO 0);
signal Disp_Decode: STD_LOGIC_VECTOR(6 DOWNTO 0);
BEGIN
process(Clk)
      begin
        if(Clk'event and Clk='1') then
           if(Clk_Count1<10000) then
             Clk_Count1<=Clk_Count1+1;
             Clk_Count1<="00000000000001";
           end if;
        end if;
    end process;
    Clk1Hz<=Clk_Count1(13);
   PROCESS(CLK1hz,EN)
BEGIN
   IF RST='0' THEN tmb <=(OTHERS=>'0');tma <=(OTHERS=>'0');
   ELSIF CLK1hz'EVENT AND CLK1hz='1' THEN
       IF EN='1' THEN
         if tmb="1001" then tmb<="0000";
             if tma="101" then  tma<="000";
               else tma<=tma+1;
               END IF;
           else tmb<=tmb+1;
             END IF;
          END IF;
       END IF;
       --dout<=conv_std_logic_vector(conv_integer(tmb)+conv_integer(tma)*10,6);
       --dout<=tmb;
      -- dout1<=tma;
  END PROCESS;
process(clk)
begin
   IF CLK'EVENT AND CLK='1' THEN
        count<=count+1;
       Disp_Decode1<=Disp_Decode;
         end if;
         END PROCESS;
process(count)
         begin
            case count is
                   WHEN "00"|"10"=>dout1<="10";Disp_Temp<=tmb;
                   WHEN "01"|"11"=> dout1<="01";Disp_Temp<='0'& tma;
                   WHEN OTHERS =>NULL;
             END CASE;
               END PROCESS;
      process(Disp_Temp)      --顯示轉(zhuǎn)換
      begin
        case Disp_Temp is
          when "0000"=>Disp_Decode<="0111111";   --0
          when "0001"=>Disp_Decode<="0000110";   --1
          when "0010"=>Disp_Decode<="1011011";   --2
          when "0011"=>Disp_Decode<="1001111";   --3
          when "0100"=>Disp_Decode<="1100110";   --4
          when "0101"=>Disp_Decode<="1101101";   --5
          when "0110"=>Disp_Decode<="1111101";   --6
          when "0111"=>Disp_Decode<="0000111";   --7
          when "1000"=>Disp_Decode<="1111111";   --8
          when "1001"=>Disp_Decode<="1101111";   --9
         -- when 10=>Disp_Decode<="1000000";   ---
          when others=>Disp_Decode<="0000000";   --全滅
        end case;
    end process;
END BEHAV;
