只需一步,快速開(kāi)始
查看: 3308|回復(fù): 0
3D打印出的機(jī)器蟲(chóng)撲翼飛行
ID:107189 發(fā)表于 2016-3-4 19:31 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
一支來(lái)自康奈爾大學(xué)的機(jī)器人專(zhuān)家隊(duì)伍用3D打印技術(shù)創(chuàng)造出了微型的機(jī)器飛蟲(chóng)。
The flapping wings of the hovering robotic insects (known as ornithopters) are very thin, lightweight and yet strong. Traditionally, the manufacturing process for these wings is time-consuming and a case of trial and error. However, advances in rapid prototyping have greatly expanded the possibilities for wing design, allowing wing shapes to replicate those of real insects or virtually any other shape. Furthermore, this can be done in minutes.
機(jī)器飛蟲(chóng)(被稱(chēng)為撲翼機(jī))撲打的翅翼非常纖薄、輕質(zhì),卻很牢固。傳統(tǒng)上,這些翅翼的制造過(guò)程相當(dāng)費(fèi)時(shí),需要不斷地出錯(cuò)重試。然而,快速成形技術(shù)的迅猛發(fā)展大大提高了翅翼設(shè)計(jì)的可能性,完全能夠復(fù)制真實(shí)昆蟲(chóng)的翅翼形狀,事實(shí)上可以刻畫(huà)任何形狀。并且這一切只需幾分鐘就能完成。
Researchers have managed to create a ornithopter with 3-D-printed wings weighing just 3.89 grams that can hover untethered for 85 seconds.
研究人員試圖創(chuàng)造一種僅重3.89g的3D打印的撲翼機(jī)機(jī)翼,它能夠獨(dú)立飛行85秒。2
In order to create the ornithopters, the Cornell roboticists used an Objet EDEN260V 3-D printer. The wings are made of a polythene film stretched over a carbon fiber frame. The “fuselage” of the robotic insect was designed to hold a small GM14 motor, crank and wing hinge. The wings are driven by a crankshaft that is connected to a gearbox. Having initially connected the ornithopter using a DC power source, they realized that the device could lift 1.5 grams of payload, which was roughly the mass of the batteries required for flight.
康奈爾大學(xué)的研究人員用了一臺(tái)Eden260V 3D打印機(jī)來(lái)制造撲翼機(jī)。機(jī)翼是由碳纖維框架和包裹在外面的聚乙烯膜構(gòu)成的。機(jī)器昆蟲(chóng)的“機(jī)身”被設(shè)計(jì)成能夠搭載一臺(tái)小型GM14引擎以及曲軸和鉸鏈。機(jī)翼由連接著齒輪箱的機(jī)軸驅(qū)動(dòng)。起初給撲翼機(jī)接上一個(gè)直流電源之后,他們發(fā)現(xiàn)這個(gè)裝置的有效載荷為1.5g,這大概可以勉強(qiáng)提起飛行所需的電池。
When they experimented with a free-flying ornithopter, they needed to introduce lightweight sails above and below the winged robot in order to maintain stability (see second part of the video above).
在用撲翼機(jī)進(jìn)行獨(dú)立飛行實(shí)驗(yàn)時(shí),需要在它的上下各安一個(gè)帆來(lái)保持穩(wěn)定。
The work at Cornell is testing hypotheses of insect propulsion and control. Researchers will test how different wing angles affect flight. If successful, these principles could form the basis of hovering ornithopter control. In other words, we could be seeing some seriously cool navigable robot insects.
在康奈爾大學(xué)的工作是測(cè)試?yán)ハx(chóng)的推進(jìn)力和可控性。研究人員將會(huì)測(cè)試不同的機(jī)翼角度對(duì)飛行的影響。如果一切順利,這些原理能夠作為撲翼機(jī)飛行控制的基礎(chǔ)。換言之,我們可能即將看到一些相當(dāng)酷的可操縱的機(jī)器昆蟲(chóng)。1
Engineers have only been able to replicate flapping wing flight in the last decade. Major challenges include the lack of any established body of theoretical and experimental work on the unsteady aerodynamics of flapping wing flight for the purpose of wing design (most aircraft are designed for smooth flight). Researchers also need a sophisticated solution to make sure the robot remains upright. And they must solve problems with the energy density of batteries.
在過(guò)去十年中,工程師們只能復(fù)制撲翼飛行。主要挑戰(zhàn)就包括缺乏在理論上和實(shí)踐中都可行的用于撲翼飛行器機(jī)翼設(shè)計(jì)的流體力學(xué)方案(大多數(shù)飛行器都被設(shè)計(jì)用于平穩(wěn)飛行)。研究人員還需要一個(gè)成熟的方案來(lái)確保飛行器保持正直。他們還需解決電池的能量密度問(wèn)題。
相關(guān)帖子
