簡(jiǎn)單的計(jì)算器程序 自己編的
程序下載:
智能計(jì)算器.zip
(36.9 KB, 下載次數(shù): 93)
2016-12-13 21:25 上傳
點(diǎn)擊文件名下載附件
部分源碼預(yù)覽:
- #ifndef __PROCESS_H__
- #define __PROCESS_H__
- uint8 key,num;
- uint8 fuhao;//定義具體的那個(gè)符號(hào),是加減還是乘除。
- uint8 flag; //定義有沒有按下符號(hào)鍵,這個(gè)是統(tǒng)稱
- long a,b,c,d; //定義運(yùn)算數(shù)據(jù)的第一個(gè)和第二個(gè)及等于的數(shù)變量
- uint8 k; //定義小數(shù)點(diǎn)后面顯示的位數(shù)
- uint8 biao,keyflag; // + - * /
- uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數(shù)據(jù)
- void process()
- P1=0xfe; //令第一行為0,然后判斷是哪一列按下
- if(P1!=0xfe)
- delay(1000);
- if(P1!=0xfe)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=0;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //1
- case 0xd0: num=1;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //2
- case 0xb0: num=2;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //3
- case 0x70: num=3;break; //加
- while(P1!=0xfe);
- switch (num)
- case 0:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 1:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 2:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 3:flag=1;fuhao=1;lcdwrd(0x30+dat1[num]);break; //加號(hào)+
- P1=0xfd; //令第二行為0,判斷是哪一列按下
- if(P1!=0xfd)
- delay(1000);
- if(P1!=0xfd)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=4;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //4
- case 0xd0: num=5;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //5
- case 0xb0: num=6;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //6
- case 0x70: num=7;break; //減—
- while(P1!=0xfd);
- switch (num)
- case 4:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 5:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 6:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 7:flag=1;fuhao=2;lcdwrd(0x30+dat1[num]);break;
- P1=0xfb; //令第三行為0,判斷哪一列按下
- if(P1!=0xfb)
- delay(1000);
- if(P1!=0xfb)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=8;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //7
- case 0xd0: num=9;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //8
- case 0xb0: num=10;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //9
- case 0x70: num=11;break; //乘*
- while(P1!=0xfb);
- switch (num)
- case 8:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 9:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 10:if(flag==0){a=a*10+dat1[num];}else{b=b*10+dat1[num];} lcdwrd(0x30+dat1[num]);break;
- case 11:flag=1;fuhao=3;lcdwrd(0x30+dat1[num]);break;
- P1=0xf7; //令第四行為0,判斷哪一列按下
- if(P1!=0xf7)
- delay(1000);
- if(P1!=0xf7)
- key=P1&0xf0;
- switch(key)
- case 0xe0: num=12;if(keyflag==1){keyflag=0;lcdwrc(0x01);};break; //0
- case 0xd0: num=13;break; //清除rst
- case 0xb0: num=14;break; //等號(hào)=
- case 0x70: num=15;break; //除/
- while(P1!=0xf7);
- switch(num)
- case 12: if(flag==0){a=a*10+dat1[num];lcdwrd(0x30);}else{b=b*10+dat1[num];lcdwrd(0x30);}break;
- case 13: lcdwrc(0x01);a=0;b=0;flag=0;fuhao=0;break;
- case 15:flag=1;fuhao=4;lcdwrd(0x2f);break;//除號(hào)/
- case 14:
- switch (fuhao)
- case 1:
- lcdwrc(0x4f+0x80);
- lcdwrc(0x04);//設(shè)置光標(biāo)左移,屏幕不移動(dòng)
- c=a+b;
- while(c!=0) //一位一位顯示
- lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
- c=c/10;//取前面的結(jié)果數(shù)據(jù)
- keyflag=1;
- lcdwrd(0x3d); //顯示等于號(hào)=
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- break;
- case 2:
- if(a>b)
- c=a-b;
- else
- c=b-a;
- keyflag=1;
- if(a<b) lcdwrd(0x2d); //顯示-號(hào)
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- break;
- case 3:
- c=a*b;
- keyflag=1;
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- break;
- case 4:
- k=0;
- c=(long)(((float)a/b)*1000);//強(qiáng)制轉(zhuǎn)換為long。
- k++;
- if(k==3)
- lcdwrd(0x2e);
- k=0;
- keyflag=1;
- if(a/b<0) //如果a比b小的話那么除的結(jié)果最高位是0
- lcdwrd(0x30);
- lcdwrd(0x3d); //顯示等號(hào)
- a=0;
- b=0;
- flag=0;
- fuhao=0;//全部清除為0
- break;
- break;
- #endif
