查看: 2283|回復(fù): 0
單片機(jī)交通燈設(shè)計(jì)源碼
ID:145459 發(fā)表于 2016-11-2 11:37 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
實(shí)驗(yàn)名:交通燈設(shè)計(jì)
實(shí)驗(yàn)內(nèi)容:利用中斷,定時(shí)/計(jì)數(shù)器,數(shù)碼管和led燈進(jìn)行交通燈的設(shè)計(jì)
                                       #include <reg52.h>
                                        sbit wei1=P2^4;             //定義位選 0
                                        sbit wei2=P2^5;             //1
                                        sbit wei3=P2^6;             //2
                                        sbit wei4=P2^7;             //3
                                        sbit green_we=P1^2;         //定義交通燈綠東西
                                        sbit green_ns=P1^3; //定義交通燈綠南北
                                        sbit red_we=P1^0;    //定義交通燈紅東西
                                        sbit red_ns=P1^1;      //定義交通燈紅南北
                                        sbit yellow_we=P1^4;        //定義交通燈黃東西
                                        sbit yellow_ns=P1^5;         //定義交通燈黃南北
                                        uchar num,num1,shi_we,shi_ns,ge_we,ge_ns;
                                        uint xianshi_we,xianshi_ns;
                                        uchar code table[]={
                                        0x3f,0x06,0x5b,0x4f,0x66,
                                        0x6d,0x7d,0x07,0x7f,0x6f}; //定義數(shù)值0,1,2....9
                                        void delayms(uint xsm) //延時(shí)程序
                                        uint i,j;
                                        for(i=xsm;i>0;i--)
                                        for(j=110;j>0;j--);
                                        void display(uchar shi_we,uchar ge_we,ucharshi_ns,uchar ge_ns)          //定義數(shù)碼管函數(shù)
                                        wei1=1;
                                        wei2=0;
                                        wei3=0;
                                        wei4=0;
                                        P0=table[shi_we];
                                        delayms(5);
                                        wei1=0;
                                        wei2=1;
                                        wei3=0;
                                        wei4=0;
                                        P0=table[ge_we];
                                        delayms(5);
                                        wei1=0;
                                         wei2=0;
                                        wei3=1;
                                        wei4=0;
                                        P0=table[shi_ns];
                                        delayms(5);
                                        wei1=0;
                                        wei2=0;
                                        wei3=0;
                                        wei4=1;
                                        P0=table[ge_ns];
                                        delayms(5);
                                        num=0;
                                        num1=0;
                                        xianshi_we=99;
                                        xianshi_ns=99;
                                        shi_we=9;
                                        ge_we=9;
                                        shi_ns=9;
                                        ge_ns=9;
                                        TMOD=0x51;                                   //設(shè)置定時(shí)器0和計(jì)數(shù)器1為工作方式1
                                        TH0=(65536-46080)/256;    //設(shè)置初值
                                        TL0=(65536-46080)%256;
                                        TH1=(65536-46080)/256;
                                        TL1=(65536-46080)%256;
                                        EA=1;                                        //開總中斷
                                        ET0=1;                                               //開定時(shí)器0中斷
                                        ET1=1;                                               //開定時(shí)器1中斷
                                        TR0=1;                                               //啟動(dòng)定時(shí)器0
                                        TR1=1;                                               //啟動(dòng)定時(shí)器1
                                        P1=0xff;         //led燈全滅
                                        P1=0xf6;  //定義東西亮紅燈,南北亮綠燈;
                                               display(shi_we,ge_we,shi_ns,ge_ns);
                                                 if(num1==1140)
                                               P1=0xde;//定義東西亮紅燈,南北亮黃燈;
                                    if(num1==1200)
                                               P1=0xf9;//定義東西亮綠燈,南北亮紅燈;
                                               xianshi_we=60;
                                    xianshi_ns=60;
                                    if(num1==2340)
                                               P1=0xed;//定義東西亮黃燈,南北亮紅燈;
                                    if(num1==2400)
                                               num1=0;
                                               xianshi_we=60;
                                    xianshi_ns=60;
                                               P1=0xf6;//定義東西亮紅燈,南北亮綠燈;
                                        void T0_time()interrupt 1
                                               num++;
                                               if(num%20==0)
                                          num=0;
                                                xianshi_we--;
                                           xianshi_ns--;
                                                shi_we=xianshi_we/10;
                                                ge_we=xianshi_we%10;
                                                shi_ns=xianshi_ns/10;
                                                ge_ns=xianshi_ns%10;
                                        void T1_count() interrupt 3
                                        num1++;
相關(guān)帖子
