查看: 7241|回復: 6
求助:電子秤鎖定屏顯問題?
ID:45225 發表于 2016-6-11 20:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
各位師傅好!我用STC12LE5A60S2單片機和HX711編寫了一個電子秤程序,我想通過一只按鍵按一次鎖定數碼管顯示的重量,再按一次解除鎖定,進入正常顯示。我試了下,斷開hx711的DOUT或者PD_SCK或者同時斷開均可達到目的,但不知C程序如何編寫,試了很多方法均不行,敬請個位師傅給點思路,謝謝!!下面是程序:請大家幫忙看看!謝謝指教! #include<reg52.h>#include<intrins.h>
uint Lheight;
uint compensate;
uchar discode[4]={0,0,0,0};
extern void LedDisplay(void);
sbit P10= P1^0;   //按鍵
sbit  hx711_dout=P3^6;
sbit  hx711_sck=P3^7;
extern unsigned char discode[4];
uchar  code Dis_7[10]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 };//0,1,2,3,4,5,6,7,8,9
uchar code scan_con[4]= {0xfe,0xfd,0xfb,0xf7 };
unsigned int ReadCount(void);
// 延時 MS
void delay(uint x)
     uchar j;
    while(x--)
     for(j=0;j<125;j++)
//延時 500US
void delay500us(void)
    unsigned char a,b;
     for(b=7l;b>0;b--)
         for(a=2;a>0;a--);
//hx711 us延時
void delay_hx711_us(void)
   _nop_();
   _nop_();
//數碼管顯示
     uchar k;
    for(k=0;k<4;k++)
         P0=Dis_7[discode[k]];
         P2=scan_con[k];
         delay500us();
         P2=0xff;
// 按鈕
void ButtonScan(void)
   if(!P10)
      delay(10);
   if(!P10)
          compensate=ReadCount();//
//讀重量值,并A/D轉換,返回 (hx711驅動程序)
        unsigned long Count;
        uint ADval;
        uchar i;
        hx711_dout=1;
        delay_hx711_us();
        hx711_sck=0;
        Count=0;
        while(hx711_dout)
        LedDisplay();
        for(i=0;i<24;i++)
                hx711_sck=1;
                Count=Count<<1;
                hx711_sck=0;
                if(hx711_dout)
                   Count++;
          hx711_sck=1;
          delay_hx711_us();
          Count=Count^0x800000;         //第25個脈沖下降沿來時轉換數據
          hx711_sck=0;
          ADval=(float)(Count>>8);
          return(ADval);
//分解
void discode0(void)
        discode[0]=Lheight%10;
        discode[1]=(Lheight%100)/10;
        discode[2]=(Lheight%1000)/100;
        discode[3]=(Lheight%10000)/1000;
//讀取重量值
void WeighWork(void)
     float Tempheight;
     uint a;
     a=ReadCount();
     if(a<=compensate)
            Lheight=0;             //校0
     else Lheight=a-compensate;
     discode0();                 //調用數值分解函數
     Lheight=discode[3]*1000+discode[2]*100+discode[1]*10+discode[0];
      Tempheight=(float)(Lheight/0.822);
     Lheight=(float)(Tempheight);   // 將Tempheight轉浮點型
void main(void)
        P10=1;
        delay(1000);
        compensate=ReadCount()+1;
//                 ReadCount();
                WeighWork();
                LedDisplay();
                ButtonScan();
ID:94827 發表于 2016-6-11 22:38 | 只看該作者
在單片機和數碼管之間加一個573之類的芯片,利用芯片的鎖存端實現硬件方面的鎖定
ID:45225 發表于 2016-6-12 10:38 | 只看該作者
謝謝樓上大哥的指點!請問:不另加573鎖存器行不行?
ID:123289 發表于 2016-6-12 19:44 | 只看該作者
1,做一個標記位K,每按鍵一次K求反(K=0或1,TURE/FALSE)
2,做兩個顯示區(比如:四個字節),放秤的采樣顯示數據.設為XS1和XS2.
3,每次采樣值只存放于XS1中.
4,當K=0時,顯示XS1的值,即正常顯示秤的測量值.
5.當K=1時,將XS1復制至XS2中,并顯示XS2的值.
ID:45225 發表于 2016-6-12 21:09 | 只看該作者
本帖最后由 fbzsn 于 2016-6-15 22:14 編輯
非常感謝yzwzfyz高級工程師的指導!有點思路了,我去試試。再次感謝!(問題已解決,再次感謝yzwzfyz高級工程師的指導!)
ID:123289 發表于 2016-6-16 10:39 | 只看該作者
初學者:總是把數據(現場處理過的),拿去直接顯示,就是不好的做法,機會性很差.
正確的做法是:把數據(現場處理過的),先送到顯示緩沖區(如XS1,XS2...),而后再從顯示緩沖區取出數據去顯示.
這樣顯示的機動性就強了,要怎么做就怎么做?
對于你來說.只是修改XS1,或XSn中的數據而矣.
而XS1,或XSn,只是幾個字節的內存而矣,隨便定義一下即可.
比如,XS1放的是動態數據(隨顯示內容更改變動),而XS2,只是在需要的時候,從XS1中復制一下,那么:
當你將XS1送去顯示時,顯示的內容就是不斷變化的(如時間)
當你將XS2送去顯示時,顯示的內容就是不變的(如永遠是"13:57",因為你在13:57將XS1復制到了XS2中,而XS2已后就不變了)
所以你只要選擇從哪個緩沖區取數據顯示,就會得到不同的顯示效果.
ID:45225 發表于 2017-3-29 22:33 | 只看該作者
謝謝 yzwzfyz總工程師指點!完美解決問題。
