//P0口段選,P2口位選,P1.2LED指示燈,P1.3蜂鳴器 按鍵不足 誤差:24小時(shí)差20s
- #include <reg51.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit KEY1=P3^0;
- sbit KEY2=P3^1;
- sbit KEY3=P3^2;
- sbit KEY4=P3^3;
- sbit LED=P1^2;
- sbit BEEP=P1^3;
- uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- uchar StrTab[8];
- uchar minute=30,hour=14,second;
- //yanshi
- void delay(unsigned int cnt)
- { while(--cnt);
- //chaizi
- void Displaypro(void)
- StrTab[0]=tab[hour/10];
- StrTab[1]=tab[hour%10];
- StrTab[2]=0XBF;
- StrTab[3]=tab[minute/10];
- StrTab[4]=tab[minute%10];
- StrTab[6]=0XBF;
- StrTab[5]=tab[second/10];
- StrTab[7]=tab[second%10];
- //zhuhanshu
- void main()
- TMOD|=0x01;
- TH0=0xd8;
- TL0=0xf0;
- ET0=1;
- TR0=1;
- TMOD|=0x10;
- TH1=0xf8;
- TL1=0xf0;
- ET1=1;
- TR1=1;
- EA=1;
- Displaypro();
- //按鍵部分可以這樣寫(xiě)
- /*while(1)
- static uchar P3=0xff;
- if(P3&&(KEY1==0||KEY2==0||KEY3==0||KEY4==0))
- delay(1000);
- //xiaodou
- P3=0x00;
- if(KEY1==0)
- {delay(1000);hour++;
- if(hour==24)hour=0;Displaypro(); }
- else if(KEY4==0){ delay(1000);second--;
- if(second==0)second=59;Displaypro(); }
- else if(KEY2==0){delay(1000);minute++ ;
- if(minute==59)minute=0;Displaypro(); }
- else if(KEY3==0){ delay(1000);minute--;
- if(minute==0)minute=59;Displaypro(); }
- else if(KEY1==1&&KEY2==1&&KEY3==1&&KEY4==1)P3=0xff;
- while(1)
- if(minute==14)
- {if(hour==2)
- {P1=0x00; }
- if(!KEY1)
- delay(10000);
- if(!KEY1)
- { delay(20000);delay(20000);
- hour++;
- delay(20000);delay(20000);
- Displaypro();
- if(!KEY2)
- delay(20000);
- if(!KEY2)
- hour--;
- if(hour==0)hour=23;
- Displaypro();
- if(!KEY3)
- delay(20000);
- if(!KEY3)
- {delay(20000);delay(20000);
- minute++;
- Displaypro();
- if(!KEY4)
- delay(20000);
- if(!KEY4)
- minute--;
- Displaypro();
- //T1
- void time1_isr(void) interrupt 3 using 0
- static unsigned char num;
- TH1=0xF8;
- TL1=0xf0;
- P2=0XFF;
- {switch (num)
- case 0:P2=0XFE;P0=~StrTab[num];break;
- case 1:P2=0XFD;P0=~StrTab[num];break;
- case 2:P2=0XFB;P0=~StrTab[num];break;
- case 3:P2=0XF7;P0=~StrTab[num];break;
- case 4:P2=0XEF;P0=~StrTab[num];break;
- case 5:P2=0XBf;P0=~StrTab[num];break;
- case 6:P2=0XDf;P0=~StrTab[num];break;
- case 7:P2=0X7F;P0=~StrTab[num];break;
- default:break;
- num++;
- if(num==8)
- num=0;
- //T0
- void tim(void) interrupt 1 using 1
- static unsigned char count;
- TH0=0xd8;
- TL0=0xf0;
- count++;
- switch (count)
- case 0:
- case 20:
- case 40:
- case 60:
- case 80:Displaypro(); break;
- case 50:LED=!LED; break;
- default:break;
- if (count==92)//將100改為92可以縮小至最小誤差
- count=0;
- second++;
- if(second==60)
- second=0;
- minute++;
- if(minute==60)
- minute=0;
- hour++;
- if(hour==24)
- hour=0;
