---------------------------狀態機---------------------------
Library ieee;
Use ieee.std_logic_1164.all;
Entity statem is
Port(clk,clr:in std_logic;
Q0,Q1,Q2,Q3:out std_logic_vector(6 downto 0));
end;
architecture dd of statem is
Type state is (s0,s1,s2,s3,s4,s5,s6,s7,s8,s9);
signal ss0,ss1,ss2,ss3:state;
signal Q:integer range 0 to 19999999;
signal cp:std_logic;
procedure disp(s:in state;p:out std_logic_vector(6 downto 0))is
begin
case s is
when s0=>p:="1000000";
when s1=>p:="1111001";
when s2=>p:="0100100";
when s3=>p:="0110000";
when s4=>p:="0011001";
when s5=>p:="0010010";
when s6=>p:="0000010";
when s7=>p:="1111000";
when s8=>p:="0000000";
when s9=>p:="0010000";
end case;
end disp;
----------1s---------------
begin
process(clk)
begin
if clk'event and clk='1' then
Q<=Q+1;
if Q=0 then
cp<=not cp;
end if;
end if;
end process;
process(cp)
begin
if clr='0' then
ss0<=s0;
ss1<=s0;
ss2<=s0;
ss3<=s0;
elsif cp'event and cp='1' then
case ss0 is
when s0=>ss0<=s1;
when s1=>ss0<=s2;
when s2=>ss0<=s3;
when s3=>ss0<=s4;
when s4=>ss0<=s5;
when s5=>ss0<=s6;
when s6=>ss0<=s7;
when s7=>ss0<=s8;
when s8=>ss0<=s9;
when s9=>ss0<=s0;
case ss1 is
when s0=>ss1<=s1;
when s1=>ss1<=s2;
when s2=>ss1<=s3;
when s3=>ss1<=s4;
when s4=>ss1<=s5;
when s5=>ss1<=s0;
case ss2 is
when s0=>ss2<=s1;
when s1=>ss2<=s2;
when s2=>ss2<=s3;
when s3=>ss2<=s4;
when s4=>ss2<=s5;
when s5=>ss2<=s6;
when s6=>ss2<=s7;
when s7=>ss2<=s8;
when s8=>ss2<=s9;
when s9=>ss2<=s0;
case ss3 is
when s0=>ss3<=s1;
when s1=>ss3<=s2;
when s2=>ss3<=s3;
when s3=>ss3<=s4;
when s4=>ss3<=s5;
when s5=>ss3<=s0;
when others=>null;
end case;
end case;
when others=>null;
end case;
end case;
end if;
end process;
process(ss0,ss1)
variable sss0,sss1,sss2,sss3:std_logic_vector(6 downto 0);
begin
disp(ss0,sss0);
disp(ss1,sss1);
disp(ss2,sss2);
disp(ss3,sss3);
Q0<=sss0;Q1<=sss1;Q2<=sss2;Q3<=sss3;
end process;
end;
--------------------------------判斷語句-----------------------------------------------------
Library ieee;
Use ieee.std_logic_unsigned.all;
Entity statem is
end;
signal ss0,ss2, ss1,ss3:std_logic_vector(3 downto 0);
signal Q:integer range 0 to 12999999;
procedure disp0(s0:in std_logic_vector(3 downto 0);p0:out std_logic_vector(6 downto 0))is
begin
case s0 is
when "0000"=>p0:="1000000";
when "0001"=>p0:="1111001";
when "0010"=>p0:="0100100";
when "0011"=>p0:="0110000";
when "0100"=>p0:="0011001";
when "0101"=>p0:="0010010";
when "0110"=>p0:="0000010";
when "0111"=>p0:="1111000";
when "1000"=>p0:="0000000";
when "1001"=>p0:="0010000";
when others=>null;
end case;
end disp0;
begin
process(clk)
begin
Q<=Q+1;
if Q=0 then
cp<=not cp;
end if;
end if;
end process;
process(cp)
begin
if clr='0' then
ss0<="0000";
ss1<="0000";
ss2<="0000";
ss3<="0000";
ss0<=ss0+1;
if ss0=9 then
ss0<="0000";
ss1<=ss1+1;
if ss1=5 then
ss1<="0000";
ss2<=ss2+1;
if ss2=9 then
ss2<="0000";
ss3<=ss3+1;
if ss3=5 then
ss3<="0000";
end if;
end if;
end if;
end if;
end if;
end process;
process(ss0,ss1,ss2,ss3)
begin
disp0(ss0,sss0);
disp0(ss1,sss1);
disp0(ss2,sss2);
disp0(ss3,sss3);
end process;
end;
