程序功能:實(shí)現(xiàn)59分59秒的正跑表,定時(shí)器0實(shí)現(xiàn)每一秒中斷
實(shí)現(xiàn)59分59秒的反跑表,定時(shí)器0實(shí)現(xiàn)每一秒中斷
定時(shí)器1實(shí)現(xiàn)每40ms刷新數(shù)碼管一次
每計(jì)時(shí)一分鐘蜂蜜器響一次,包括反跑的時(shí)候
用外部中斷INT0、INT1實(shí)現(xiàn)按鍵掃描,正啟動(dòng)跑表或反啟動(dòng)跑表
無(wú)按鍵時(shí)實(shí)現(xiàn)正跑表
時(shí)鐘:11.0592MHz,KEIL編程環(huán)境
開(kāi)發(fā)日期:2010年6月25日
#include<reg52.h>
#include<absacc.h>
#include<string.h>
sbit LED_COM1 = P1^4; //the 4 8_segment LEDs common control port.
sbit LED_COM2 = P1^5;
sbit LED_COM3 = P1^6;
sbit LED_COM4 = P1^7;
sbit INT0_E=P3^2;
sbit INT1_E=P3^3;
#define LCD_273 XBYTE[0xfe00]
uchar timer0_interrupt_counter=0; //中斷記錄次數(shù)
uchar timer1_interrupt_counter=0;
uchar NUM_miao=0,NUM_fen=0; //記錄秒和分
uchar INT0_flag=0;
uchar INT1_flag=0;
uchar table[10]={0x0C0,0x0F9,0x0A4 ,0x0B0,0x99,0x92, 0x82,0x0F8,0x80,0x90 }; //開(kāi)發(fā)板為共陽(yáng)的
void TIME_init()
TMOD=0x11;//定時(shí)器0和定時(shí)器1工作于方式1
ET0=1; //開(kāi)定時(shí)器/計(jì)數(shù)器0允許
TR0=1; //中斷定時(shí)器0開(kāi)通
EA=1; //開(kāi)總中斷
ET1=1;//開(kāi)定時(shí)器/計(jì)數(shù)器1允許
TR1=1;//中斷定時(shí)器1開(kāi)通
/***************外部中斷0**********************/
IT0=0; //跳沿觸發(fā)
EX0=1;//允許外部中斷0產(chǎn)生中斷
IT1=0; //跳沿觸發(fā)
EX1=1; //允許外部中斷1產(chǎn)生中斷
/*******************優(yōu)先級(jí)設(shè)置******************************/
PX0=1;
PX1=1;
PT0=0;
PT1=0;
void delay(uint time) //延時(shí)函數(shù)
uint i=0,j=0;
for(i=time;i>0;i--);
void display(uchar i,uchar com_counter ) // i表示亮的數(shù),j表示第幾個(gè)數(shù)碼管亮
LCD_273=table;
if(com_counter == 1)
LED_COM1 = 0;
LED_COM2 = 1;
LED_COM3 = 1;
LED_COM4 = 1;
if(com_counter == 2)
LED_COM1 = 1;
LED_COM2 = 0;
LED_COM3 = 1;
LED_COM4 = 1;
if(com_counter == 3)
LED_COM1 = 1;
LED_COM2 = 1;
LED_COM3 = 0;
LED_COM4 = 1;
if(com_counter == 4)
LED_COM1 = 1;
LED_COM2 = 1;
LED_COM3 = 1;
LED_COM4 = 0;
com_counter += 1;
if(com_counter >= 4)
com_counter = 0;
函數(shù):定時(shí)器0中斷服務(wù)程序,產(chǎn)生20*50ms=1s的延時(shí)
介紹:每1s計(jì)時(shí)
void timer0_ISR(void) interrupt 1
TH0=0x4B; //給予初值在11.0592MHZ下定時(shí)50ms:0x4BEC
TL0=0xEC;
timer0_interrupt_counter+=1;
if(timer0_interrupt_counter==20) //20 times interrupt about 50ms.
timer0_interrupt_counter=0; // set interrupt counter as 0
if(INT0_flag==1)
//INT0_flag=0;
NUM_miao++;
if(NUM_miao==60)
P1&=0xF7; //每計(jì)時(shí)到一分鐘蜂鳴器響一次
delay(100);
P1|=0x08; //停止蜂鳴器響
NUM_miao=0;
NUM_fen++;
if(NUM_fen==60){INT0_flag=0;NUM_fen=0;}
if(INT1_flag==1)
// NUM_miao=60;
// NUM_fen=60;
//INT1_flag=0;
NUM_miao--;
if(NUM_miao==0)
delay(100);
P1|=0x08; //停止蜂鳴器響
NUM_miao=60;
NUM_fen--;
if(NUM_fen==0){INT1_flag=0;NUM_fen=60;}
NUM_miao++;
if(NUM_miao==60)
delay(100);
P1|=0x08; //停止蜂鳴器響
NUM_miao=0;
NUM_fen++;
if(NUM_fen==60)NUM_fen=0;
函數(shù):定時(shí)器1中斷服務(wù)程序,產(chǎn)生20ms*2=40ms延時(shí)
介紹:每50msms刷新數(shù)碼管
void timer1_ISR(void) interrupt 3 //動(dòng)態(tài)掃描中斷 每位40ms
TH1=0xFC; //給予初值在11.0592MHZ下定時(shí)20ms:0xB802
TL1=0x78;
timer1_interrupt_counter+=1;
if(timer1_interrupt_counter==1)
display(NUM_fen/10,1); //顯示分的十位 P1^4
if(timer1_interrupt_counter==2)
display(NUM_fen%10,2);
if(timer1_interrupt_counter==3)
display(NUM_miao/10,3); //顯示秒的十位 P1^6
if(timer1_interrupt_counter==4)
display(NUM_miao%10,4); //顯示秒的個(gè)位 P1^7
if(timer1_interrupt_counter>5)timer1_interrupt_counter=0;
函數(shù):外部中斷0服務(wù)程序
介紹:觸發(fā)按鍵KEY1,實(shí)現(xiàn)秒表正跑
void INT0_ISR(void) interrupt 0
INT1_flag=0; //清零反跑標(biāo)志
INT0_flag=1;
NUM_miao=0; //重裝正跑數(shù)據(jù)
NUM_fen=0;
//INT0_E=1; //中斷后對(duì)應(yīng)的INT0引腳設(shè)置為高電平
//IE0=0;
函數(shù):外部中斷1服務(wù)程序
介紹:觸發(fā)按鍵KEY2 ,實(shí)現(xiàn)秒表反跑
void INT1_ISR(void) interrupt 2
INT0_flag=0; //清零正跑標(biāo)志
NUM_miao=60; //重裝反跑數(shù)據(jù)
NUM_fen=59;
INT1_flag=1;
//INT1_E=1; //中斷后對(duì)應(yīng)的INT1引腳設(shè)置為高電平
//IE1=0;
TIME_init();
P1=0x08; //因?yàn)?1單片機(jī)上電復(fù)位后I/0口是高電平
P3=0xff;
