;eeprom.c 在AVR單片機中可以用在ATMEGA16和ATMEGA8中都可以用,在GCC下
;編譯通過。09年11月1號! 陳永飛已測試過!
;讀/寫atmega8515內部EEPROM的例子
;將數據0....9寫入eeprom中,再讀出用數碼管顯示出來
#include <avr/io.h>
#include <avr/eeprom.h>
#define Hidden 16
uchar DispTab[17]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
uchar BitTab[6]={0x7F,0xBF,0xDF,0xEF,0xF7,0xFB};
uchar DispBuf[6]; //顯示緩沖區
unsigned char Counter=0;
void io_init(void)
// PortA
PORTA = 0xff;
DDRA = 0xff;
// PortB
PORTB = 0x0;
DDRB = 0x0;
// PortC
PORTC = 0xfc;
DDRC = 0xfc;
// PortD
PORTD = 0x0;
DDRD = 0x0;
void mDelay(uint DelayTim)
uint i;
for(;DelayTim>0;DelayTim--)
for(i=0;i<600;i++)
void disp()
uchar i;
uchar tmp;
if(++i>=6)
i=0;
PORTC=0xff; //關閉顯示
tmp=DispBuf[i];
PORTA=DispTab[tmp];
tmp=BitTab[i];
PORTC=tmp;
mDelay(1); //延時1ms
int main(void)
unsigned int Count=0;
unsigned char Addr=1; //向地址1里面寫數字
uint8_t temp=0;
io_init();
DispBuf[0]=Hidden;
DispBuf[1]=Hidden;
DispBuf[2]=Hidden;
DispBuf[3]=Hidden;
DispBuf[4]=0; //次低位顯示0
temp=eeprom_read_byte (Addr);
DispBuf[5]=temp;
if(++Count==1000)
Count=0;
Counter++;
eeprom_write_byte(Addr,Counter);
if(Counter>=10)
Counter=0; //計數值在0~9之間循環
disp(); //調用顯示程序
