查看: 5500|回復: 0
TFT點陣上的七段數碼管表
ID:72008 發表于 2015-1-12 19:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
想讓TFT顯示數字,可以直接調用ASCII碼表即可,但是要想顯示的數字有7段數碼管的效果,那就要自己動手了,在zimo221.exe中新建想要大小的數字,如下是16*32大小的數字代碼和32*64大小的數字代碼。太耗費時間和眼力了,留著備用吧。
制作是還是有點竅門的,不要0-9按順序制作,看看他們的形態,想想應按照那種順序制作會比較快捷再動手。
0
/*--  調入了一幅圖像:  --*/
/*--  寬度x高度=16x32  --*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x17,0xF0,0x38,0x08,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x10,0x08,
0x00,0x00,0x10,0x08,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x17,0xE8,0x0F,0xF0,0x07,0xE0,0x00,0x00
1
/*--  調入了一幅圖像:這是您新建的圖像  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,
0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x01,0x00,0x00,0x00,
0x01,0x00,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,
0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00
2
/*--  調入了一幅圖像:*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x07,0xF0,0x00,0x08,0x00,0x1C,0x00,0x1C,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x07,0xE8,
0x0F,0xF0,0x17,0xE0,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,
0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x17,0xE0,0x0F,0xF0,0x07,0xE0,0x00,0x00
3
/*--  調入了一幅圖像:*/
0x0F,0xF0,0x07,0xE8,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x07,0xE8,0x0F,0xF0,0x07,0xE0,0x00,0x00
4
/*--  調入了一幅圖像:*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x08,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x17,0xE8,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00
5
/*--  調入了一幅圖像: --*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x17,0xF0,0x38,0x00,0x38,0x00,0x38,0x00,
0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x17,0xE0,
6
/*--  調入了一幅圖像: --*/
0x0F,0xF0,0x17,0xE8,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,
7
/*--  調入了一幅圖像: --*/
0x00,0x00,0x00,0x00,0x07,0xE0,0x0F,0xF0,0x17,0xE8,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x18,0x08,
0x00,0x00,0x00,0x08,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,
8
/*--  調入了一幅圖像:  --*/
9
/*--  調入了一幅圖像:  --*/
以下是32*64的代碼:
0
/*--  寬度x高度=32x64  --*/
0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xC0,0x07,0xFF,0xFF,0xE0,0x0F,0xFF,0xFF,0xF0,
0x17,0xFF,0xFF,0xE8,0x3B,0xFF,0xFF,0xDC,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x38,0x00,0x00,0x1C,0x10,0x00,0x00,0x08,
0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x08,0x38,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x3B,0xFF,0xFF,0xDC,0x17,0xFF,0xFF,0xE8,
0x0F,0xFF,0xFF,0xF0,0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,
1
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x08,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,
2
0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC8,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x01,0xFF,0xFF,0x9C,0x03,0xFF,0xFF,0xC8,
0x07,0xFF,0xFF,0xE0,0x13,0xFF,0xFF,0xC0,0x39,0xFF,0xFF,0x80,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x78,0x00,0x00,0x00,0x3B,0xFF,0xFF,0xC0,0x17,0xFF,0xFF,0xE0,
3
0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC8,0x01,0xFF,0xFF,0x9C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x03,0xFF,0xFF,0xC8,0x07,0xFF,0xFF,0xE0,
4
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x39,0xFF,0xFF,0x9C,0x13,0xFF,0xFF,0xC8,
5
0x17,0xFF,0xFF,0xE0,0x3B,0xFF,0xFF,0xC0,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x39,0xFF,0xFF,0x80,0x13,0xFF,0xFF,0xC0,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x03,0xFF,0xFF,0xDC,0x07,0xFF,0xFF,0xE8,
6
0x07,0xFF,0xFF,0xE0,0x13,0xFF,0xFF,0xC8,0x39,0xFF,0xFF,0x9C,0x7C,0x00,0x00,0x3E,
7
0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xE0,0x07,0xFF,0xFF,0xF0,0x0F,0xFF,0xFF,0xF8,
0x07,0xFF,0xFF,0xF0,0x13,0xFF,0xFF,0xE8,0x38,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
8
9
0x17,0xFF,0xFF,0xE0,0x3B,0xFF,0xFF,0xC8,0x7C,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
