查看: 1759|回復: 3
LCD1602顯示一排黃方塊
對比度調過了,硬件連接也跟仿真一樣沒啥問題,大佬們幫我看看程序哪里有問題,急!!!lcd1602.c
#include "bsp-lcd1602.h"
void LCD1602_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(LCD1602_CLK, ENABLE);
        GPIO_InitTypeDef LCD1602_GPIOStruct;
        LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_PP;
        LCD1602_GPIOStruct.GPIO_Speed = GPIO_Speed_10MHz;
        LCD1602_GPIOStruct.GPIO_Pin =  LCD1602_E | LCD1602_RS | LCD1602_RW ;
        GPIO_Init(LCD1602_GPIO_PORT,&LCD1602_GPIOStruct);
        LCD1602_GPIOStruct.GPIO_Mode = GPIO_Mode_Out_OD;
        LCD1602_GPIOStruct.GPIO_Pin =   DB0 |  DB1 | DB2 |DB3 |  DB4 | DB5|
        DB6 |  DB7 ;
void LCD1602_WaitReady(void
        uint8_t sta;
        GPIOB->ODR =0x00FF;
        RSO(0);
        RWO(1);
        EO(1);
        SysTick_Delay_Us(1);
        do{
                sta=GPIO_ReadInputDataBit(LCD1602_GPIO_PORT,GPIO_Pin_7);
                EO(0);
        }while(sta);
void LCD1602_WriteCmd(uint8_t cmd
        LCD1602_WaitReady();
        RSO(0);
        RWO(0);
        EO(0);
        EO(1);
        LCD1602_GPIO_PORT->ODR &= (cmd|0xFF00);
        EO(0);
        SysTick_Delay_Us(400);
void LCD1602_WriteDat(uint8_t dat
        RSO(1);
        RWO(0);
        SysTick_Delay_Us(30);
        EO(1);
        LCD1602_GPIO_PORT->ODR &=(dat|0xFF00);
        EO(0);
void LCD1602_SetCursor(uint8_t x, uint8_t y)
    uint8_t addr;
    if (y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    LCD1602_WriteCmd(addr|0x80);
void LCD1602_ShowStr(uint8_t x, uint8_t y, uint8_t *str, uint8_t len)
    LCD1602_SetCursor(x, y);
    while (len--)
        LCD1602_WriteDat(*str++);
void LCD_ShowNum(uint8_t x, uint8_t y,uint8_t num)
    LCD_ShowChar(x,y,num+'0');
void LCD_ShowChar(uint8_t x, uint8_t y,uint8_t dat)
        LCD1602_WriteDat(dat);
void LCD1602_Init(void)
          LCD1602_GPIO_Config();
    LCD1602_WriteCmd(0X38);
    LCD1602_WriteCmd(0x0C);
    LCD1602_WriteCmd(0x06);
    LCD1602_WriteCmd(0x01);
main.c
#include "stm32f10x.h"
#include "delay.h"
#include "sys.h"
#include "adc.h"
#define LED PAout(3)
#define KEY1 PAin(8)
#define KEY2 PAin(9)
#define KEY3 PAin(10)
void LED_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_SetBits(GPIOA,GPIO_Pin_3);
void KEY_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
int main(void)
int a,b,c,d;
        float temp;
        delay_init();
        LCD1602_Init();
  ADC1_GPIO_Config();
  ADC_Config();
        LCD1602_ShowStr(2,0,"Qiti=0.0mg/L",13);
        LED_Init();
        KEY_Init();
        b=ADC_GetConversionValue(ADC1);
        temp=(float)b*(3.4/4096);
        a=temp/1;
        c=temp*10;
        d=c%10;
        LCD_ShowNum(7,0,a);
        LCD_ShowNum(9,0,d);
                if(KEY3==0)
                if(temp>2) LED=1;
                else LED=0;
                if(KEY1==0) LED=1;
                if(KEY2==0) LED=0;
                delay_ms(200);
ID:262 發表于 2023-5-14 22:04 | 只看該作者
來看一下51hei論壇里面解決此問題的痛苦經歷吧:
51hei搜索框輸入"1602 方塊"或者"1602 黑塊"或者"1602 白塊"或者"1602 格":
這個是io口設置問題,最終搞定了:http://m.raoushi.com/bbs/dpj-199732-1.html
http://m.raoushi.com/bbs/dpj-168643-1.html
http://m.raoushi.com/bbs/dpj-208189-1.html
http://m.raoushi.com/bbs/dpj-210690-1.html
既有可能是軟件問題也有硬件問題
http://m.raoushi.com/bbs/dpj-187378-1.html
http://m.raoushi.com/bbs/dpj-160754-1.html
ID:277550 發表于 2023-5-15 10:02 | 只看該作者
調節顯示對比度
ID:584814 發表于 2023-5-15 15:27 | 只看該作者
知道對比度調過了,可以再調回來。
也可以本壇搜索找一下成功的例子。
