查看: 1732|回復(fù): 0
閑來無事隨意寫回復(fù)8*8點陣顯示箭頭 單片機程序
ID:332444 發(fā)表于 2022-12-1 13:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
緣由http://m.raoushi.com/bbs/dpj-225369-1.html
#include<reg52.h>
unsigned char code M[]={
        0xff,0xff,0xfe,0xfd,0xf8,0xfd,0xfe,0xff,
  0xff,0xff,0xfd,0xfb,0xf0,0xfb,0xfd,0xff,
  0xff,0xff,0xfb,0xf7,0xe0,0xf7,0xfb,0xff,
  0xff,0xff,0xf7,0xef,0xc0,0xef,0xf7,0xff,
  0xff,0xff,0xef,0xdf,0x80,0xdf,0xef,0xff,
  0xff,0xff,0xdf,0xbf,0x00,0xbf,0xdf,0xff};
        unsigned char wei=0,zt=1,ys=0,cs=0,sj=0;
                if(wei==0)wei=1;else wei*=2;
                P3=M[sj+cs];
                P2=wei;
                while(++ys);
                P2=P3=255;
                if(++sj>8){sj=0;++zt;}
                if(zt>47){cs+=8;if(cs>40)cs=0;zt=0;}
