查看: 2025|回復: 4
[求助]用8591單片機采集環境溫度濕度,并在lcd1602顯示
ID:943129 發表于 2021-6-23 13:31 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
要求:在1602上顯示某一變量的數值,正常范圍,并判斷當前狀態
如:t:50            60
      comfort         40
表示當前溫度為50,正常溫度為40-60,當前溫度正常
紅綠字為自己添加的代碼,代碼可通過keil編譯,但在單片機上無法正常顯示。如果將綠字部分注釋掉單片機就可以正常運行實現功能
* 【函數功能】: DA-AD試驗
* 【使用說明】: 單片機:STC89C52
                 串口波特率:9600
                 串口一共發送4個字節
                 1 光敏電阻
                 2 熱敏電阻
                 3 懸空
                 4 可調0-5V電壓(藍色電位器調節)
#include<reg52.h>    //包含單片機寄存器的頭文件
#include <I2C.H>
#define  PCF8591 0x90    //PCF8591 地址
/********IO引腳定義***********************************************************/
sbit LCD_RS=P1^0;//定義引腳
sbit LCD_RW=P1^1;
sbit LCD_E=P1^2;
/********宏定義***********************************************************/
#define LCD_Data P0
#define Busy    0x80 //用于檢測LCD狀態字中的Busy標識
/********數據定義*************************************************************/
unsigned char code uctech[] = {"Thank"};
unsigned char code net[] = {"you!"};
unsigned char code clear[] = {"               "};
unsigned char code net1[] = {"t:"};
unsigned char code net2[] = {"l:"};
unsigned char code net3[] = {"v:"};
unsigned char t;
//溫度
uchar code limit[]={"60"};
uchar code limit1[]={"40"};
unsigned char code condition[]={"too hot"};
uchar code condition1[]={"comfort"};
uchar code condition2[]={"too cold"};
//光
uchar code limit2[]={"100"};
uchar code limit3[]={"60"};
unsigned char code condition3[]={"too bright"};
uchar code condition4[]={"comfort"};
uchar code condition5[]={"too dim"};
//電壓
uchar code limit4[]={"200"};
uchar code limit5[]={"100"};
unsigned char code condition6[]={"too big"};
uchar code condition7[]={"comfort"};
uchar code condition8[]={"too small"};
// 變量定義
unsigned char AD_CHANNEL;
unsigned long xdata  LedOut[8];
unsigned int  D[32];
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
unsigned char data a;
//按鈕
sbit K1=P3^7;
sbit K2=P3^6;
sbit K3=P3^5;
sbit K4=P3^4;
//unsigned char date ;
/*uchar code table[]={0xC0,0xF9,0xA4,0xB0,
                            0x99,0x92,0x82,0xF8,
                            0x80,0x90,0x88,0x83,
                            0xC6,0xA1,0x86,0x8E};     */
  // 函數申明
//void delay(uchar i);
bit DACconversion(unsigned char sla,unsigned char c,  unsigned char Val);
bit ISendByte(unsigned char sla,unsigned char c);
unsigned char IRcvByte(unsigned char sla);
void Initial_com(void);
void WriteDataLCD(unsigned char WDLCD);                    //寫數據
void WriteCommandLCD(unsigned char WCLCD,BuysC);        //寫命令
unsigned char ReadDataLCD(void);                        //讀數據
unsigned char ReadStatusLCD(void);                        //讀狀態
void LCDInit(void);                                        //初始化
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);            //相應坐標顯示字節內容
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);    //相應坐標開始顯示一串內容
void Delay5Ms(void);                                    //延時
void Delay400Ms(void);                                    //延時
/*void delay_1ms()
    unsigned char temp=249;
    while(--temp);
    temp=249;
    while(--temp);
main()
    Initial_com();
    Delay400Ms();     //啟動等待,等LCD講入工作狀態
    LCDInit();         //初始化
    Delay5Ms();     //延時片刻(可不要)
    DisplayListChar(0, 1, uctech);
    ReadDataLCD();
    /********以下AD-DA處理*************/
        switch(AD_CHANNEL)
            case 0: ISendByte(PCF8591,0x41);
                 D[0]=IRcvByte(PCF8591);  //ADC0 模數轉換1      電壓
                 break;
            case 1: ISendByte(PCF8591,0x42);
                 D[1]=IRcvByte(PCF8591);  //ADC1  模數轉換2      光
                 break;
            case 2: ISendByte(PCF8591,0x43);
                 D[2]=IRcvByte(PCF8591);  //ADC2    模數轉換3       溫度
                 break;
            case 3: ISendByte(PCF8591,0x40);
                 D[3]=IRcvByte(PCF8591);  //ADC3   模數轉換4       可調0-5v
                 break;
            case 4: DACconversion(PCF8591,0x40, D[4]); //DAC      數模轉換
                 break;
        D[4]=D[3];  //把模擬輸入采樣的信號 通過數模轉換輸出
        if(K1==0)
            a=1;
            DisplayListChar(0, 1, clear);
            DisplayListChar(0, 0, clear);
            DisplayListChar(14, 0, limit);
            DisplayListChar(14, 1, limit1);
         if(K2==0)
             a=2;  //0
            DisplayListChar(14, 0, limit2);
            DisplayListChar(14, 1, limit3);
         if(K3==0)
             a=3;    //1
            DisplayListChar(14, 0, limit4);
            DisplayListChar(14, 1, limit5);;
         if(K4==0)
             a=4;    //1
        if(a==1)
             DisplayListChar(0, 0, net1);
             DisplayOneChar(2, 0,D[2]/100+0x30);
             DisplayOneChar(3, 0,D[2]%100/10+0x30);
             DisplayOneChar(4, 0,D[2]%10+0x30);
             if(D[2]>60)
                   DisplayListChar(0, 1, condition);
             if(D[2]<40)
                   DisplayListChar(0, 1, condition2);
                   DisplayListChar(0, 1, condition1);
        if(a==2)
             DisplayListChar(0, 0, net2);
             DisplayOneChar(2, 0,D[1]/100+0x30);
             DisplayOneChar(3, 0,D[1]%100/10+0x30);
             DisplayOneChar(4, 0,D[1]%10+0x30);
             if(D[1]>100)
                   DisplayListChar(0, 1, condition3);
             if(D[1]<60)
                   DisplayListChar(0, 1, condition5);
                   DisplayListChar(0, 1, condition4);
        if(a==3)
             DisplayListChar(0, 0, net3);
             DisplayOneChar(2, 0,D[0]/100+0x30);
             DisplayOneChar(3, 0,D[0]%100/10+0x30);
             DisplayOneChar(4, 0,D[0]%10+0x30);
             if(D[0]>200)
                   DisplayListChar(0, 1, condition6);
             if(D[0]<100)
                   DisplayListChar(0, 1, condition8);
                   DisplayListChar(0, 1, condition7);
        if(a==4)
             DisplayListChar(0, 1, net2);
             DisplayOneChar(2, 1,D[1]/100+0x30);
             DisplayOneChar(3, 1,D[1]%100/10+0x30);
             DisplayOneChar(4, 1,D[1]%10+0x30);
             DisplayListChar(6, 0, net3);
             DisplayOneChar(8, 0,D[0]/100+0x30);
             DisplayOneChar(9, 0,D[0]%100/10+0x30);
             DisplayOneChar(10, 0,D[0]%10+0x30);
       if(++AD_CHANNEL>4) AD_CHANNEL=0;
       /********以下將AD的值通過串口發送出去*************/
    /* delay(200);
     SBUF=D[0];
     delay(200);
     SBUF=D[1];
     delay(200);
     SBUF=D[2];
     delay(200);
     SBUF=D[3];
     delay(200);
     if(RI)
        date=SBUF;    //單片機接受
        SBUF=date;    //單片機發送
        RI=0;
/*void delay(uchar i)
  uchar j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
DAC 變換, 轉化函數
   Start_I2c();              //啟動總線
   SendByte(sla);            //發送器件地址
   if(ack==0)return(0);
   SendByte(c);              //發送控制字節
   SendByte(Val);            //發送DAC的數值
   Stop_I2c();               //結束總線
   return(1);
ADC發送字節[命令]數據函數
   Start_I2c();              //啟動總線
   SendByte(c);              //發送數據
   Stop_I2c();               //結束總線
   return(1);
ADC讀字節數據函數
{  unsigned char c;
   Start_I2c();          //啟動總線
   SendByte(sla+1);      //發送器件地址
   c=RcvByte();          //讀取數據0
   Ack_I2c(1);           //發送非就答位
   Stop_I2c();           //結束總線
   return(c);
//*****串口初始化函數***********
EA=1;        //開總中斷
ES=1;        //允許串口中斷
ET1=1;        //允許定時器T1的中斷
TMOD=0x20;   //定時器T1,在方式2中斷產生波特率
PCON=0x00;   //SMOD=0
SCON=0x50;   // 方式1 由定時器控制
TH1=0xfd;    //波特率設置為9600
TL1=0xfd;
TR1=1;       //開定時器T1運行控制位
/***********寫數據********************************************************/
     ReadStatusLCD(); //檢測忙
     LCD_Data = WDLCD;
     LCD_RS = 1;
     LCD_RW = 0;
     LCD_E = 0;         //若晶振速度太高可以在這后加小的延時
     LCD_E = 0;         //延時
     LCD_E = 1;
/***********寫指令********************************************************/
void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時忽略忙檢測
     if (BuysC) ReadStatusLCD(); //根據需要檢測忙
     LCD_Data = WCLCD;
     LCD_RS = 0;
     LCD_RW = 0;
     LCD_E = 0;
     LCD_E = 0;
    LCD_E = 1;
/***********讀數據********************************************************/
     LCD_RS = 1;
     LCD_RW = 1;
     LCD_E = 0;
     LCD_E = 0;
     LCD_E = 1;
     return(LCD_Data);
/***********讀狀態*******************************************************/
     LCD_Data = 0xFF;
     LCD_RS = 0;
     LCD_RW = 1;
     LCD_E = 0;
     LCD_E = 0;
     LCD_E = 1;
     while (LCD_Data & Busy); //檢測忙信號
     return(LCD_Data);
/***********初始化********************************************************/
void LCDInit(void)
     LCD_Data = 0;
     WriteCommandLCD(0x38,0);     //三次模式設置,不檢測忙信號
     Delay5Ms();
     Delay5Ms();
     Delay5Ms();
     WriteCommandLCD(0x38,1);     //顯示模式設置,開始要求每次檢測忙信號
     WriteCommandLCD(0x08,1);     //關閉顯示
     WriteCommandLCD(0x01,1);     //顯示清屏
     WriteCommandLCD(0x06,1);     //顯示光標移動設置
     WriteCommandLCD(0x0C,1);     //顯示開及光標設置
/***********按指定位置顯示一個字符*******************************************/
     Y &= 0x1;
     X &= 0xF;                 //限制X不能大于15,Y不能大于1
     if (Y) X |= 0x40;         //當要顯示第二行時地址碼+0x40;
     X |= 0x80;             //算出指令碼
     WriteCommandLCD(X, 0); //這里不檢測忙信號,發送地址碼
     WriteDataLCD(DData);
/***********按指定位置顯示一串字符*****************************************/
     unsigned char ListLength;
     ListLength = 0;
     Y &= 0x1;
     while (DData[ListLength]>=0x20){ //若到達字串尾則退出
           if (X <= 0xF){         //X坐標應小于0xF
             DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
             ListLength++;
             X++;
/***********短延時********************************************************/
void Delay5Ms(void)
     unsigned int TempCyc = 5552;
     while(TempCyc--);
/***********長延時********************************************************/
     unsigned char TempCycA = 5;
     unsigned int TempCycB;
     while(TempCycA--){
          TempCycB=7269;
          while(TempCycB--);
ID:390416 發表于 2021-7-6 20:33 | 只看該作者
LCD1602顯示℃ 這種自定義符號 http://m.raoushi.com/bbs/dpj-200685-1.html
LCD1602液晶最新資料 說明了具體的時間要求 http://m.raoushi.com/bbs/dpj-205768-1.html
ID:943129 發表于 2021-6-23 17:25 | 只看該作者
yzwzfyz 發表于 2021-6-23 15:11
自己能畫出程序流程圖嗎?
不能,師傅只要求會用:),這東西我不是很懂才學
ID:811711 發表于 2021-6-23 15:31 | 只看該作者
好代碼 太長 誰也幫不了你啊
ID:123289 發表于 2021-6-23 15:11 | 只看該作者
自己能畫出程序流程圖嗎?
