查看: 8747|回復: 2
單片機+LCD1602顯示℃ 這種自定義符號
ID:390416 發表于 2020-12-29 12:29 | 顯示全部樓層 |閱讀模式
本帖最后由 人人學會單片機 于 2020-12-30 11:29 編輯
  1. #include "all.h"
  2. u8 xdata LCD1602_Write_Buffer1[16];
  3. u8 xdata LCD1602_Write_Buffer2[16];
  4. u8 code LCD1602_5x8[8]={0x08,0x00,0x07,0x08,0x08,0x08,0x08,0x07};
  5. u8 xdata LCD1602_Write_Cursor_Add;
  6. void LCD1602_Delay(u8 len)
  7. {
  8.         u8 idata i;
  9.         while(len--)
  10.         {
  11.                 i=15;
  12.                 while(i--);
  13.         }
  14. }
  15. void LCD1602_Write_Add(u8 Add)                //寫地址命令
  16. {
  17.         LCD1602_RS=0;
  18.         LCD1602_E=0;
  19.         LCD1602_Delay(10);
  20.         LCD1602_E=1;
  21.         HC595_Write_Buffer[0]=Add;
  22.         HC595_Write_Buffer[1]=0;
  23.         HC595_Write_Data_Drive();
  24.         LCD1602_E=0;
  25. }
  26. void LCD1602_Write_Dat(u8 Dat)                //寫內容
  27. {
  28.         LCD1602_RS=1;
  29.         LCD1602_E=0;
  30.         LCD1602_Delay(10);
  31.         LCD1602_E=1;
  32.         HC595_Write_Buffer[0]=Dat;
  33.         HC595_Write_Buffer[1]=0;
  34.         HC595_Write_Data_Drive();
  35.         LCD1602_E=0;
  36. }
  37. void LCD1602_Init()
  38. {
  39.         u8 i;
  40.         P4M0&=0x9f;
  41.         P4M1&=0x9f;//P4.6  P4.5 準雙向口模式
  42.         LCD1602_Write_Add(0x38);
  43.         LCD1602_Delay(250);
  44.         LCD1602_Write_Add(0x01);
  45.         LCD1602_Delay(250);
  46.         LCD1602_Write_Add(0x02);
  47.         LCD1602_Delay(250);
  48.         LCD1602_Write_Add(0x06);
  49.         LCD1602_Delay(250);
  50.         LCD1602_Write_Add(0x0C);
  51.         LCD1602_Delay(250);
  52.         LCD1602_Write_Add(0x14);
  53.         LCD1602_Delay(250);
  54.         LCD1602_Write_Add(0x40);//自定義存儲空間起始地址
  55.         for(i=0;i<8;i++)
  56.         {
  57.                 LCD1602_Write_Dat(LCD1602_5x8[i]);
  58.         }
  59. }
  60. void LCD1602_Display_Ser()
  61. {
  62.         u8 i;
  63.         LCD1602_Write_Add(0x80);
  64.         for(i=0;i<16;i++)
  65.         {
  66.                 LCD1602_Write_Dat(LCD1602_Write_Buffer1[i]);
  67.         }
  68.         LCD1602_Write_Add(0xC0);
  69.         for(i=0;i<16;i++)
  70.         {
  71.                 LCD1602_Write_Dat(LCD1602_Write_Buffer2[i]);
  72.         }
  73.         switch(LCD1602_Write_Cursor_Add)
  74.         {
  75.                 case 0:LCD1602_Write_Add(0x0C);break;//不顯示也不閃爍光標
  76.                 case 1:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCa);break;
  77.                 case 2:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCd);break;
  78.                 case 3:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC7);break;
  79.                 case 4:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC4);break;
  80.                 case 5:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xC1);break;
  81.                 case 6:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0xCf);break;
  82.                 case 7:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x89);break;
  83.                 case 8:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x86);break;
  84.                 case 9:LCD1602_Write_Add(0x0F);LCD1602_Write_Add(0x83);break;
  85.         }
  86. }
一、以上代碼,主函數大循環前面初始化P4IO口為準雙向口
二、主函數大循環前面需要初始化LCD1602_Init();
三、我們是使用595轉換給LCD的D0~D7。你們可以直接用P2口賦值給LCD。
四、主函數每500ms 調用LCD1602_Display_Ser()函數。實現數據每半秒刷新一次即可。省掉讀忙的過程。
五、兩個LCD1602_Write_Buffer[];數組,分別是上下兩行的顯存。其他地方有需要,就往里面丟ASCII值就可以了。比如0x30+5.液晶顯示數字5
六、以上代碼由《人人學會單片機》視頻教程原創書寫。其他地方引用請注明出處!
15 03 18 02 ASCII與GB2312漢字碼表.zip (6.89 MB, 下載次數: 14)
15 03 18 01 LCD1602詳細中文資料 適合V1.2版本的開發板.pdf (1.66 MB, 下載次數: 28)
不好意思 忘記上傳資料文檔了。
一、LCD1602詳細中文資料
二、ASCII與GB2312漢字碼表
三、LCD1602初始化時序圖
四、背面電阻修改圖
ID:102963 發表于 2020-12-29 22:29 | 顯示全部樓層
攝氏度符號可以拆成2部分,一個是圈,一個是C。圈就是寫數據0xdf,C就是寫數據C,這樣就能顯示出來了。
ID:390416 發表于 2020-12-30 11:34 | 顯示全部樓層
songxia8013 發表于 2020-12-29 22:29
這樣拆分 肯定很丑啊 ,再說了 也不一定有空間多顯示一個字符。沒必要為了一個字符。去執行移屏操作。那樣很不直觀了。
