查看: 2446|回復: 6
這個51單片機延遲函數為什么不對?
ID:894974 發表于 2021-4-6 20:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
#include<intrins.h>
sbit RS = P1^0;   //定義端口
sbit RW = P1^1;
sbit EN = P2^5;
sbit DU = P2^0;
sbit WE = P2^1;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
void cmg88()//關數碼管,點陣函數
DU=1;
P0=0X00;
DU=0;
              延遲函數
void delay(unsigned int xms)
    unsigned int i,j;                 毫秒
    for(i=xms;i>0;i--)
        for(j=114;j>0;j--);
              判忙函數
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
              寫入命令函數
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
              寫入數據函數
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
                清屏函數
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
              寫入字符串函數
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);     //表示第一行
         LCD_Write_Com(0xC0 + x);      //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
              寫入字符函數
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函數
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*顯示模式設置*/
   DelayMs(5);
   DelayMs(5);
   DelayMs(5);
   LCD_Write_Com(0x08);    /*顯示關閉*/
   LCD_Write_Com(0x01);    /*顯示清屏*/
   LCD_Write_Com(0x06);    /*顯示光標移動設置*/
   DelayMs(5);
   LCD_Write_Com(0x0C);    /*顯示開及光標設置*/
                    主函數
void main(void)
cmg88();//關數碼管,點陣函數
LCD_Init();
LCD_Clear();//清屏
while (1)
  LCD_Write_Char(1,0,'-');
  LCD_Write_Char(2,0,'-');
  LCD_Write_Char(3,0,'-');
  LCD_Write_Char(4,0,'-');
  LCD_Write_Char(5,0,'-');
  LCD_Write_Char(6,0,'>');
  LCD_Write_Char(7,0,'3');
  LCD_Write_Char(8,0,'<');
  LCD_Write_Char(9,0,'-');
  LCD_Write_Char(10,0,'-');
  LCD_Write_Char(11,0,'-');
  LCD_Write_Char(12,0,'-');
  LCD_Write_Char(13,0,'-');
  delay(2000);
  LCD_Write_Char(7,0,'2');
  delay(2000);
  LCD_Write_Char(7,0,'1');
  delay(2000);
  LCD_Write_String(1,1,"6666666666");
  while(1);
ID:207421 發表于 2021-4-6 23:48 | 只看該作者
在KEIL里面,選擇好正確的或對應大小的晶振,DEBUG一下,就知道具體延時了多少時間了
ID:894154 發表于 2021-4-7 09:41 | 只看該作者
延時哪不對了?報啥錯?還是delay時間不對
ID:390416 發表于 2021-4-7 10:02 | 只看該作者
你可以在51黑論壇搜索以下名字
LCD1602顯示℃ 這種自定義符號
ID:390416 發表于 2021-4-7 10:05 | 只看該作者
LCD1602顯示℃ 這種自定義符號 http://m.raoushi.com/bbs/dpj-200685-1.html
ID:52586 發表于 2021-4-7 10:46 | 只看該作者
描述問題要清楚, 別人才知道怎么幫你。 延時不對是怎么不對,你希望是什么結果, 實際是什么 現象,實際現象與你的期待有什么不符?
ID:844772 發表于 2021-4-7 10:50 | 只看該作者
這顯示的都是啥啊
