#include "my_include.h"
int DataGeted=0; //數(shù)據(jù)已生成標記
unsigned int numTransfers_Tx=0; //發(fā)送數(shù)據(jù)塊數(shù)計數(shù)器(中斷中使用)
int BlockCnt=0; //處理數(shù)據(jù)塊數(shù)計數(shù)器(驅(qū)動3D0發(fā)光管閃動)
int KeyDownFlag;
int KeyDownCnt;
int dat,xx;
//函數(shù)聲明
extern void fir(); //fir
extern void initial_sys(); //系統(tǒng)初始化(I2C McBSP AIC23 EDMA EMIF etc.)
extern void func();
//Block Data Send interrupt function
//interrupt period=240/48000=0.005s=5ms
long DMARec_p;
interrupt void DMA_tx_Isr()
numTransfers_Tx++;
DataGeted=1;
//修改DMA2源地址,并啟動DMA2
*DMA_CSR2=(*DMA_CSR2)&(0xfff7);//clear FRAME trasmited flag, B3 ,清除幀中斷
if((numTransfers_Tx&0x0001)==1)
*DMA_CSSA_U2 =((long)BufferB*2)>>16; //通道目的起始地址Upper 數(shù)據(jù)地址為0x20000
*DMA_CSSA_L2 =(unsigned int)((long)BufferB*2); //通道目的起始地址Low
DMARec_p = BufferA;
*DMA_CSSA_U2 =((long)BufferA*2)>>16; //通道目的起始地址Upper 數(shù)據(jù)地址為0x20000
*DMA_CSSA_L2 =(unsigned int)((long)BufferA*2); //通道目的起始地址Low
DMARec_p = BufferB;
*DMA_CCR2 =0x1986; //通道使能,不重復(fù),利用McBSP1發(fā)送事件進行同步
LBDS1=~uLED[(numTransfers_Tx>>5)&0x7];
//Light on/off LED 3D0 to display the Pragram is Running
void BlinkLed(int Flag)
if(Flag==0)
// *IODATA=(*IODATA)|(1<<6);//B6=1, GPIO6=1, Light off LED
*IODATA=(*IODATA)&0xffbf;//B6=0, GPIO6=0, Light on LED
void main(void)
initial_sys(); //初始化
//標紅部分自己弄的,想用key1控制fir和func函數(shù)的調(diào)用,但是怎么改都不成,想法是這樣子的:按key1,數(shù)碼管()就是func的函數(shù))會從0...9閃爍,fir也就成功接入了
if(KeyDownFlag==1)
KeyDownCnt--;
if(KeyDownCnt==0)
KeyDownFlag=0;
dat=keyboard & 0x00ff;
if((dat!=0xff)&&(KeyDownFlag==0))//some key is down
KeyDownFlag=1;
KeyDownCnt=200; //200*5ms=1s
if(dat==0xf7) //key1 is down
xx=1;
if(DataGeted==1&&xx==1)//處理周期為5ms(48000/240=200Hz)
xx=0;
DataGeted=0;
*IODATA=(*IODATA)&0xff7f;//B7=0, GPIO7=0, 23J0=1, for test CPU use ratio
BlinkLed((BlockCnt/100)%2); //控制3D0已1Hz的頻率閃動
BlockCnt++;
fir();
func();
*IODATA=(*IODATA)|(1<<7);//B7=1, GPIO7=1, 23J0=0, for test CPU use ratio
}//Block data Getted
}//while(1)
