直流電機正反轉,pwm占空比調速,測速,數碼管顯示當前的速度
#include <reg52.h>
sbit jiasu=P1^0; //占空比加
sbit jiansu=P1^1; //占空比減
sbit zhengz=P1^2; //正傳
sbit fanz=P1^3; //反轉
sbit tingz=P1^4; //停止
sbit IN1=P3^0; //用于正傳
sbit IN2=P3^1; //用于反轉
sbit pwm=P1^7; //調速
uint zhuansu,count,flag,r=25;
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//共陰管
void delay(uint z) //延時1ms函數
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
/*void pwm(uint t) //調速
ENA=0;
delay(95);
ENA=1;
delay(t);
void zz()
IN1=1;
IN2=0;
void fz()
IN1=0;
IN2=1;
void stop()
IN1=0;
IN2=0;
void init()//初始化函數
TMOD=0x51; //定時器,1計數,T0,T1方式1 G,C/t,M0,M1
TH0=(65535-10000)/256;
TL0=(65535-10000)%256; //定時器0裝入初值
EA=1; //開總中斷
ET0=1; //定時器0開中斷
TR0=1;
TH1=0x00;
TL1=0x00; //定時1計數初值
ET1=1; //定時器1開中斷
TR1=1;
//EX0=1;
//IT0=1;
//count=0;
// flag=0;
void t11()
TH1=0x00;
TL1=0x00; //定時1計數初值
ET1=1; //定時器1開中斷
TR1=1;
void keyscan() //控制函數
if(jiasu==0)
while(jiasu==0)
r++;
if(jiansu==0)
while(jiansu==0)
r--;
void display(uint x) //速度顯示
if(x>10000)
P2=0xfd;
P0=duanma[x/10000]; //wan
delay(5);
P2=0xfb;
P0=duanma[x%10000/1000]; //qian
delay(5);
P2=0xf7;
P0=duanma[x%1000/100]; //bai
delay(5);
P2=0xef;
P0=duanma[x%100/10]; //shi
delay(5);
P2=0xdf;
P0=duanma[x%10]; //ge
delay(5);
else if(x>1000)
P2=0xfb;
delay(5);
P2=0xf7;
delay(5);
P2=0xef;
delay(5);
P2=0xdf;
delay(5);
else if(x>100)
P2=0xf7;
delay(5);
P2=0xef;
delay(5);
P2=0xdf;
delay(5);
else if(x>10)
P2=0xef;
delay(5);
P2=0xdf;
delay(5);
P2=0xdf;
delay(5);
init(); //初始化
if(tingz==0)
stop();
else if(fanz==0)
fz();
else zz();
keyscan(); //調速程序
display(zhuansu); //顯示轉速
/*void t1()interrupt 0 using 1 //外部中斷0脈沖技術記錄電機的轉速 電機轉一圈count加一
count++ ;
void t0()interrupt 1 using 2 //定時器0顯示轉速
count++;
flag++;
if(count>50)
count=0;
if(count<r)
pwm=1;
else pwm=0;
if(flag==100) //計時到達1s
zhuansu=(TH1*256+TL1);
t11();
flag=0;
TL0=(65535-10000)%256;//定時10ms 12
電機proteus仿真圖
