帶有鬧鐘的電子時鐘
查看數(shù): 4107 | 評論數(shù): 1 | 收藏 0
發(fā)布時間: 2016-9-6 22:11
帶有鬧鐘的電子時鐘 #include<reg52.h> #include<intrins.h> #define uint unsigned int #define uchar unsigned char uchar a,miao,shi,fen,ri,yue,nian,week,key1n,temp; uchar shi1,fen1=5,shi2, ...
ID:709315 發(fā)表于 2020-3-17 20:25
為什么我運行不了?提示是這樣的錯誤......(我用的是Keil3)
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0D1AH BYTE (163%) *
Program Size: data=39.1 xdata=0 code=3583
LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
    MODULE:  D:\KEIL\C51\LIB\C51S.LIB (-----)
    LIMIT:   0800H BYTES
Target not created
