51單片機簡易計算器程序 無法顯示按鈕的數字
查看數: 2350 | 評論數: 5 | 收藏 0
發布時間: 2020-4-11 15:47
51單片機做的簡易計算器,但是仿真的時候按按鈕數碼管沒反應,正常應該是按按鈕會顯示數字出來 #include "reg52.h" #include "absacc.h" unsigned char code table[]={0x77,0x7e,0xbe,0xde,0x7d,0xbd,0xd ...
ID:958368 發表于 2021-10-27 09:34
#include "reg52.h"
#include "absacc.h"
unsigned char table[]={0x77,0x7e,0xbe,0xde,
                       0x7d,0xbd,0xdd,0x7b,
                       0xbb,0xdb,0xee,0xed,
                       0xeb,0xe7,0xd7,0xb7};
code char code tab[]={0xc0,0xf9,0xa4,0xb0,
                      0x99,0x92,0x82,0xf8,
                      0x80,0x90,0xff,0xbf};
unsigned char dspbuf[]={10,10,10,10,10,10,10,10};
unsigned char dspcom = 0;
bit key_re;
unsigned char key_press;
unsigned char key_value;
bit key_flag=0;
unsigned char intr=0;
unsigned char read_keyboard(void);
void key_proc(unsigned char key_code);
void ShowNumber(unsigned long num);
void display();
void cls_beep();
void cls_led();
void main(void)
        unsigned char key_temp=0xff;
        TMOD=0x01;
        TL0=0x66;
        TH0=0xFC;
        TF0=0;
        TR0=1;
        ET0=1;
        EA=1;
        cls_beep();
        cls_led();
        while(1)
                if(key_flag)
                        key_flag=0;
                        key_temp=read_keyboard();
                        key_proc(key_temp);
void isr_timer_0(void) interrupt 1
        TL0=0x66;
        TH0=0xFC;
        display();
        if(++intr == 10)
                intr = 0;
                key_flag=1;
void cls_beep()
        P0=0X00;
        P2=P2&0X1F|0XA0;
        P2=P2&0X1F;
void cls_led()
        P0=0Xff;
        P2=P2&0X1F|0X80;
        P2=P2&0X1F;
        unsigned char temp,scan,i;
        P3=0xf0;
        temp=P3&0xf0;
        if(temp!=0xf0)
                key_press++;
        else
                key_press=0;
        if(key_press == 2)
                key_press=0;
                key_re=1;
                P3=0X0F;
                scan=P3&0X0F;
                temp=temp|scan;
                for(i=0;i<16;i++)
                        if(temp==table[i])
                                key_value=i;
        //P3=0x0f
        if((key_re == 1) && (temp == 0xF0))
                key_re=0;
                return key_value;
        return 0xff;
        static unsigned long result=0;
        static unsigned long addend=0;
        static unsigned char cp;
        if((key_code>=0)&&(key_code<=9))//ÅD¶Ïêy×Ö¼ü
                addend=addend*10+key_code;
                ShowNumber(addend);
        else
                if(key_code==10)//¼ó·¨
                result=result+addend;
                cp=1;
                addend=0;
                ShowNumber(result);
        else
                if(key_code==11)//¼õ·¨
                if(result==0)
                        result=addend;
                else
                        result=result-addend;
                addend=0;
                cp=2;
                ShowNumber(result);
        else
                if(key_code==12)//3Ë
                if(result==0)
                        result=addend;
                else
                        if(cp==0xff)
                        else
                                result=result*addend;
                cp=3;
                addend=0;
                ShowNumber(result);
                else
                        if(key_code==13)//3y·¨
                if(result==0)
                        result=addend;
                else
                        if(cp==0xff)
                        else
                                result=result/addend;
                cp=4;
                addend=0;
                ShowNumber(result);
        else if(key_code==14)//=
                switch(cp)
                        case 1:result=result+addend;
                                                        break;
                        case 2:result=result-addend;
                                                        break;
                        case 3:result=result*addend;
                                                        break;
                        case 4:result=result/addend;
                                                        break;
                addend=0;cp=0xff;
                ShowNumber(result);
        else if(key_code==15)//Çåáã
                addend=0;
                result=0;
                ShowNumber(addend);
        (num>=100000)?(dspbuf[2]=num/100000):(dspbuf[2]=10);
        (num>=10000)?(dspbuf[3]=num%100000/10000):(dspbuf[3]=10);
        (num>=1000)?(dspbuf[4]=num%10000/1000):(dspbuf[4]=10);
        (num>=100)?(dspbuf[5]=num%1000/100):(dspbuf[5]=10);
        (num>=10)?(dspbuf[6]=num%100/10):(dspbuf[6]=10);
        dspbuf[7]=num%10;
void display(void)
        P0 = 0xff;
        P2 = ((P2&0x1f)|0xE0);
        P2 &= 0x1f;
        P0 = 1<<dspcom;
        P2 = ((P2&0x1f)|0xC0);
        P2 &= 0x1f;
        P0 = tab[dspbuf[dspcom]];
        P2 &= 0x1f;
        if(++dspcom == 8)
                dspcom = 0;
ID:591189 發表于 2020-4-11 16:44
每一毫秒拉高按鍵標志看似可行,但是你完成一次按鍵操作要多久?
你按鍵還沒按完已經是下一個標志了,按鍵怎么讀的出來?
把按鍵掃描放進中斷,再把升高按鍵標志放進掃描里就可以了
ID:591189 發表于 2020-4-11 16:38
你忘了在按鍵掃描程序里升高按鍵標志KEY_FLAGE
ID:726904 發表于 2020-4-11 16:06
求大佬指出問題
ID:726904 發表于 2020-4-11 15:58
z求大神解答,是哪里出問題了
