#include "reg52.h"
#include "absacc.h"
unsigned char table[]={0x77,0x7e,0xbe,0xde,
0x7d,0xbd,0xdd,0x7b,
0xbb,0xdb,0xee,0xed,
0xeb,0xe7,0xd7,0xb7};
code char code tab[]={0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,0xff,0xbf};
unsigned char dspbuf[]={10,10,10,10,10,10,10,10};
unsigned char dspcom = 0;
bit key_re;
unsigned char key_press;
unsigned char key_value;
bit key_flag=0;
unsigned char intr=0;
unsigned char read_keyboard(void);
void key_proc(unsigned char key_code);
void ShowNumber(unsigned long num);
void display();
void cls_beep();
void cls_led();
void main(void)
unsigned char key_temp=0xff;
TMOD=0x01;
TL0=0x66;
TH0=0xFC;
TF0=0;
TR0=1;
ET0=1;
EA=1;
cls_beep();
cls_led();
if(key_flag)
key_flag=0;
key_temp=read_keyboard();
key_proc(key_temp);
void isr_timer_0(void) interrupt 1
TL0=0x66;
TH0=0xFC;
display();
if(++intr == 10)
intr = 0;
key_flag=1;
void cls_beep()
P0=0X00;
P2=P2&0X1F|0XA0;
P2=P2&0X1F;
void cls_led()
P0=0Xff;
P2=P2&0X1F|0X80;
P2=P2&0X1F;
unsigned char temp,scan,i;
P3=0xf0;
temp=P3&0xf0;
if(temp!=0xf0)
key_press++;
key_press=0;
if(key_press == 2)
key_press=0;
key_re=1;
P3=0X0F;
scan=P3&0X0F;
temp=temp|scan;
for(i=0;i<16;i++)
if(temp==table[i])
key_value=i;
//P3=0x0f
if((key_re == 1) && (temp == 0xF0))
key_re=0;
return key_value;
return 0xff;
static unsigned long result=0;
static unsigned long addend=0;
static unsigned char cp;
if((key_code>=0)&&(key_code<=9))//ÅD¶Ïêy×Ö¼ü
addend=addend*10+key_code;
ShowNumber(addend);
if(key_code==10)//¼ó·¨
result=result+addend;
cp=1;
addend=0;
ShowNumber(result);
if(key_code==11)//¼õ·¨
if(result==0)
result=addend;
result=result-addend;
addend=0;
cp=2;
ShowNumber(result);
if(key_code==12)//3Ë
if(result==0)
result=addend;
if(cp==0xff)
result=result*addend;
cp=3;
addend=0;
ShowNumber(result);
if(key_code==13)//3y·¨
if(result==0)
result=addend;
if(cp==0xff)
result=result/addend;
cp=4;
addend=0;
ShowNumber(result);
else if(key_code==14)//=
switch(cp)
case 1:result=result+addend;
break;
case 2:result=result-addend;
break;
case 3:result=result*addend;
break;
case 4:result=result/addend;
break;
addend=0;cp=0xff;
ShowNumber(result);
else if(key_code==15)//Çåáã
addend=0;
result=0;
ShowNumber(addend);
(num>=100000)?(dspbuf[2]=num/100000):(dspbuf[2]=10);
(num>=10000)?(dspbuf[3]=num%100000/10000):(dspbuf[3]=10);
(num>=1000)?(dspbuf[4]=num%10000/1000):(dspbuf[4]=10);
(num>=100)?(dspbuf[5]=num%1000/100):(dspbuf[5]=10);
(num>=10)?(dspbuf[6]=num%100/10):(dspbuf[6]=10);
dspbuf[7]=num%10;
void display(void)
P0 = 0xff;
P2 = ((P2&0x1f)|0xE0);
P2 &= 0x1f;
P0 = 1<<dspcom;
P2 = ((P2&0x1f)|0xC0);
P2 &= 0x1f;
P0 = tab[dspbuf[dspcom]];
P2 &= 0x1f;
if(++dspcom == 8)
dspcom = 0;
