11F04E單片機串口通訊,發送1,回傳數據混亂沒有規則,串口初始化有問題嗎?
查看數: 1548 | 評論數: 2 | 收藏 0
發布時間: 2020-4-5 08:54
#include "reg52.h" #include "intrins.h" void Usartinit() {SCON=0x50; TMOD=0X20; TL1 = 0xD7; //設定定時初值 TH1 = 0xFE; //設定定時初值 TR1=1; ES=1; EA=1; } void main(){ UsartInit();w ...
ID:213173 發表于 2020-4-5 10:20
#include "reg52.h"
void Usartinit()
    SCON = 0x50;
    TMOD = 0x20;
    TH1 = 0xfd;//晶振11.0592MHz 波特率9600
    TL1 = 0xfd;
    TR1 = 1;
    ES = 1;
    EA = 1;
void main()
        UsartInit();
        while(1)
void Usart() interrupt 4
        unsigned char ReceiveData;
        RI=0;
        ReceiveData=SBUF;//保存接收到的數據
        if(ReceiveData == 1)
                ReceiveData = ReceiveData + 1;
        else
                ReceiveData = ReceiveData + 5;
        SBUF=ReceiveData;
        while(!TI); //回傳處理后的數據
        TI=0;
ID:213173 發表于 2020-4-5 10:11
        RI=0;
        else
        SBUF=ReceiveData; //回傳處理后的數據
        while(!TI);
        TI=0;
