查看: 1638|回復: 2
11F04E單片機串口通訊,發送1,回傳數據混亂沒有規則,串口初始化有問題嗎?
ID:722679 發表于 2020-4-5 08:54 | 顯示全部樓層 |閱讀模式
#include "reg52.h"
#include "intrins.h"
void Usartinit()
{SCON=0x50; TMOD=0X20; TL1 = 0xD7; //設定定時初值
TH1 = 0xFE; //設定定時初值 TR1=1; ES=1; EA=1; }
void main(){ UsartInit();while(1){} }
void Usart() interrupt 4
{unsigned char ReceiveData;ReceiveData=1;RI=0;if(ReceiveData == 1)
{ ReceiveData = ReceiveData + 1;}else{ ReceiveData = ReceiveData + 5;}
SBUF=ReceiveData; while(!TI); TI=0;}
ID:213173 發表于 2020-4-5 10:11 | 顯示全部樓層
        RI=0;
        ReceiveData=SBUF;//保存接收到的數據
        SBUF=ReceiveData; //回傳處理后的數據
        while(!TI);
        TI=0;
ID:213173 發表于 2020-4-5 10:20 | 顯示全部樓層
#include "reg52.h"
void Usartinit()
    SCON = 0x50;
    TMOD = 0x20;
    TH1 = 0xfd;//晶振11.0592MHz 波特率9600
    TL1 = 0xfd;
    TR1 = 1;
    ES = 1;
    EA = 1;
        UsartInit();
        RI=0;
        SBUF=ReceiveData;
        while(!TI); //回傳處理后的數據
        TI=0;
