STM32 模擬I2C學習問題,發送3個器件地址,只一個回應
查看數: 1810 | 評論數: 1 | 收藏 0
發布時間: 2020-2-10 00:04
初學i2c接口,編寫個程序i2c讀器件ACK  如:"ack=i2c_SendData(0x46);“反復嘗試了3個I2C器件,始終只有MPU6050(Addr:0xD0)返回ACK為低電平。反復嘗試N次后使本人失去了學習的勇氣,太詭異了。請各位 ...
ID:353115 發表于 2020-2-10 14:57
1.線接對了沒有;2.速率是否符合要求;3.給你發一下我的這個發送函數你對照著看看吧
bit I2C_Write(unsigned char dat)
    bit ack;
    unsigned char pos;
    for (pos=0x80; pos; pos>>=1)
        if (dat & pos)
            I2C_SDA = 1;
        else
            I2C_SDA = 0;
        I2C_Delay(0);
        I2C_SCL = 1;
        I2C_Delay(1);
        I2C_SCL = 0;
        I2C_Delay(0);
    I2C_SDA = 1;  //釋放SDA
    I2C_Delay(0);
    I2C_SCL = 1;
    I2C_Delay(0);
    ack = I2C_SDA;  //
    I2C_Delay(0);
    I2C_SCL = 0;
    I2C_Delay(1);
    return !ack;
