START BIT P1.3 ;??????????????Ч VOUT BIT P1.6 ;???β?????? VIN BIT P3.2 ;???????????????? S1 BIT P1.5 ;??????? S2 BIT P1.4 ;??????? AEB BIT P3.6 ;AEB ???? L BIT P2.0 ;??·???????????λ???? ML BIT P2.1 ;????·???????????λ???? MR BIT P2.2 ;????·???????????λ???? R BIT P2.3 ;??·???????????λ???? BELL BIT P3.7 ;??????????????Ч?? E BIT P1.0 ;???????(????) RW BIT P1.1 RS BIT P1.2 ORG 0000H LJMP MAIN ;??????? ORG 0003H LJMP INTT0 ;????ж? 0 ???? ORG 001BH LJMP ITT1 ;???????ж? ORG 0030H MAIN: MOV SP,#60H ;??? CLR BELL ;??????? CLR E ;?????????? LCALL SETUP ;?????????? LCALL LOGON ;????????????? MOV R0,#30H MOV R7,#48H CLEAR: MOV @R0,#00H INC R0 DJNZ R7,CLEAR ;????棨30H-48H?? MOV 60H,#0FH ;???e????????λ????? MOV 61H,#01H MOV 62H,#00H MOV 63H,#00H START1: JB START, $ ;???????????????????? CLR 00H ;????λ MOV P2,00H; MOV 75H,#00H ;?巽λ??????? MOV R0,#00H MOV R1,#40H MOV TMOD,#11H ;T0??T1 ??????λ?????(???????????) MOV TH0,#00H MOV TL0,#00H MOV TH1,#3CH ;??? 50ms ??? MOV TL1,#0D8H; SETB EX0 ;?????ж? CLR ET0 SETB ET1 ;??????? T1 ?ж? SETB EA ;?????ж? SETB TR1 ;???????? T1 HERE: JNB 00H,$ ;????ж? LCALL COMPUT ;??????????? LCALL DATAUP ;?????????? LCALL BAOJING ;??????????? LCALL DELAY ;???? 0.5s SJMP START1 INTT0: CLR TR0 ;?????? T0 CLR EX0 ;?????ж? MOV @R1,TL0 ;???????? INC R1 MOV @R1,TH0 INC R1 MOV TH0,#00H ;???????? MOV TL0,#00H INC R0 RETI ITT1: CLR TR1 ;?????? T1 CLR EX0 ;???ж? MOV TH1,#3CH ;???????? MOV TL1,#0D8H CJNE R0,#04H,H0 ;??·????????????? H0 CLR TR0 CLR EA SETB 00H ;???????????λ MOV R0,#00H MOV R1,#40H LCALL BIJIAO ;?????????? SJMP A1 H0: LCALL CHOOSE ;???????????? LCALL FASHE ;??????????????? SETB TR0 ;??????? T0 SETB TR1 ;???????? T1 SETB ET0 ;???ж? LCALL DELAY3MS ;??? 3ms SETB EX0 ;?????ж? A1: RETI CHOOSE: CJNE R0,#00H,H1 ;??? 1??????· CLR S1 CLR S2 SJMP H4 H1: CJNE R0,#01H,H2 ;??? 2????????· SETB S1 CLR S2 SJMP H4 H2: CJNE R0,#02H,H3 ;??? 3????????· CLR S1 SETB S2 SJMP H4 H3: CJNE R0,#03H,H4 ;??? 4??????· SETB S1 SETB S2 SJMP H4 H4: RET FASHE: MOV R5,#10H ;????????????? C1: MOV R4,#05H MOV R3,#05H CPL VOUT NOP DJNZ R3,$ CPL VOUT DJNZ R4,$ DJNZ R5,C1 RET BIJIAO: PUSH ACC ;???????? PUSH PSW LCALL BIJIAO1 LCALL BIJIAO2 LCALL BIJIAO3 LCALL BIAOZHI POP PSW POP ACC RET BIJIAO1: MOV A,41H ;???????????? 1???????????????????? CJNE A,43H,L1 CLR C MOV A,40H CJNE A,42H,L1 MOV 50H,40H MOV 51H,41H MOV 70H,#00H SJMP L0 L1: JC L2 MOV 50H,42H MOV 51H,43H MOV 70H,#02H SJMP L0 L2: MOV 50H, 40H MOV 51H,41H MOV 70H,#01H SJMP L0 L0: CLR C RET BIJIAO2: MOV A,45H ; ???????????? 2???????????????????? CJNE A,47H,L3 CLR C MOV A,44H CJNE A,46H,L3 MOV 52H,44H MOV 53H,45H MOV 71H,#00H SJMP L8 L3: JC L4 MOV 52H,46H MOV 53H,47H MOV 71H,#02H SJMP L8 L4: MOV 52H,44H MOV 53H,45H MOV 71H,#01H L8: CLR C RET BIJIAO3:MOV A,51H ;???????????? 3 CJNE A,53H,L5 CLR C MOV A,50H CJNE A,52H,L5 MOV 54H,50H MOV 55H,51H MOV 72H,#00H SJMP L7 L5: JC L6 MOV 54H,52H MOV 55H,53H MOV 72H,#02H SJMP L7 L6: MOV 54H,50H MOV 55H,51H MOV 72H,#01H L7: CLR C RET BIAOZHI: MOV A,72H ;??λ????????? CJNE A,#01H,B2 MOV A,70H CJNE A,#01H,B11 MOV 75H,#0FEH SJMP B10 B11: JC B12 MOV 75H,#0FDH SJMP B10 B12: MOV 75H,#0FCH SJMP B10 B2: JC B3 MOV A,71H CJNE A,#01H,B21 MOV 75H,#0FBH SJMP B10 B21: JC B22 MOV 75H,#0F7H SJMP B10 B22: MOV 75H,#0F3H SJMP B10 B3: MOV A,70H CJNE A,71H,B4 CJNE A,#01H,B31 MOV 75H,#0FAH SJMP B10 B31: JC B32 MOV 75H,#0F5H SJMP B10 B32: MOV 75H,#0F0H SJMP B10 B4: JC B5 MOV A,70H CJNE A,#01H,B41 MOV 75H,#0F2H SJMP B10 B41: MOV A,71H CJNE A,#01H,B42 MOV 75H,#0F9H SJMP B10 B42: MOV 75H,#0F1H SJMP B10 B5: MOV A,71H CJNE A,#01H,B51 MOV 75H,#0F8H SJMP B10 B51: MOV A,70H CJNE A,#01H,B52 MOV 75H,#0F6H SJMP B10 B52: MOV 75H,#0F4H SJMP B10 B10: CLR C RET ;?????????? SETUP: MOV A,#01H ;??????????????? LCALL WRITE_COM; NOP MOV A,#38H LCALL WRITE_COM; NOP MOV A,#0CH LCALL WRITE_COM; NOP MOV A,#06H LCALL WRITE_COM NOP MOV A,#01H LCALL WRITE_COM NOP NOP MOV A,#00H LCALL WRITE_COM LCALL DELAY10MS RET LOGON: MOV A,#80H ;?????????????? LCALL WRITE_COM NOP NOP MOV DPTR,#AS1 LCALL WRITE_ASC16 NOP NOP MOV A,#0C0H LCALL WRITE_COM NOP MOV DPTR,#AS2 LCALL WRITE_ASC16 NOP NOP RET DATAUP: MOV A,#0C9H ;??????????????? LCALL WRITE_COM MOV R1,#30H MOV DPTR,#TABLE MOV R2,#04H MOV A,#00H M1: MOV A,@R1 MOVC A,@A+DPTR LCALL WRITE_DATA INC R1 DJNZ R2,M1 RET WRITE_COM: LCALL DELAY10MS ;???д????????? CLR RS CLR RW SETB E NOP MOV P0,A NOP CLR E RET WRITE_DATA: LCALL DELAY10MS ;???д????????? SETB RS CLR RW SETB E NOP MOV P0,A NOP CLR E RET WRITE_ASC16: MOV R4,#16H ;???д???????? DD1: CLR A MOVC A,@A+DPTR LCALL WRITE_DATA INC DPTR DJNZ R4,DD1 RET TABLE:DB 30H,31H,32H,33H,34H,35H,36H,37H,38H,39H,3AH,3BH,3CH,3DH,3EH,20H AS1: DB "REVERSING RADAR " AS2: DB "DISTANCE: CM " COMPUT: PUSH ACC ;???????????? PUSH PSW PUSH B MOV PSW,#08H ;??????鶴?????????????????????? MOV R3,55H MOV R2,54H MOV R1,#00H MOV R0,#11H LCALL MUL2BY2 MOV R3,#03H MOV R2,#0E8H LCALL DIV4BY2 LCALL DIV4BY2; MOV 30H,R4 MOV A,40H JNZ JJ0 MOV 30H,#0FH JJ0: MOV A,R0 MOV R4,A MOV A,R1 MOV R5,A MOV R3,#00H MOV R2,#64H LCALL DIV4BY2 MOV 31H,R4 MOV A,31H JNZ JJ1 MOV A,30H SUBB A,#0FH JNZ JJ1 MOV 31H,#0FH JNZ JJ1 MOV 31H,#0FH JJ1: MOV A,R0 MOV R4,A MOV A,R1 MOV R5,A MOV R3,#00H MOV R2,#0AH LCALL DIV4BY2 MOV 32H,R4 MOV A,32H JNZ JJ2 MOV A,31H SUBB A,#0FH JNZ JJ2 MOV 32H,#0FH JJ2: MOV 33H,R0 POP B POP PSW POP ACC RET MUL2BY2: CLR A ;??????????????? MOV R7,A MOV R6,A MOV R5,A MOV R4,A MOV 36H,#10H MULLOOP1: CLR C MOV A,R4 RLC A MOV R4,A MOV A,R5 RLC A MOV R6,A MOV A,R7 RLC A MOV R7,A MOV A,R0 RLC A MOV R0,A MOV A,R1 RLC A MOV R0,A MOV A,R1 RLC A MOV R1,A JNC MULLOOP2 CLR C MOV A,R4 ADDC A,R2 MOV R4,A MOV A,R5 ADDC A,R3 MOV R5,A MOV A,R6 ADDC A,#00H MOV R6,A MOV A,R7 ADDC A,#00H MOV R7,A MULLOOP2: DJNZ 36H,MULLOOP1 RET DIV4BY2: MOV 37H,#20H ;?????/????????????????? MOV R0,#00H MOV R1,#00H DIVLOOP1: MOV A,R4 RLC A MOV R4,A MOV A,R5 RLC A MOV R5,A MOV A,R6 RLC A MOV R6,A MOV A,R7 RLC A MOV R7,A MOV A,R0 RLC A MOV R0,A MOV A,R1 RLC A MOV R1,A CLR C MOV A,R0 SUBB A,R2 MOV B,A MOV A,R1 SUBB A,R3 JC DIVLOOP2 MOV R0,B MOV R1,A DIVLOOP2: CPL C DJNZ 37H,DIVLOOP1 MOV A,R4 RLC A MOV R4,A MOV A,R5 RLC A MOV R5,A MOV A,R6 RLC A MOV R6,A MOV A,R7 RLC A MOV R7,A RET BAOJING: PUSH ACC ;????????? PUSH PSW MOV A,60H CJNE A,30H,BAO1 ;???????????С???????λ??????????λ??? CLR C MOV A,61H CJNE A,31H,BAO2 ;?θ?λ??? CLR C MOV A,62H CJNE A,32H,BAO3 ;?δθ?λ??? CLR C MOV A,63H CJNE A,33H,BAO4 ;???λ??? LJMP BAOJIN BAO1: JC BAOJIN LJMP BAOYUAN BAO2: JNC BAOJIN MOV A,31H CJNE A,#0FH,BAOYUAN LJMP BAOJIN BAO3: JNC BAOJIN MOV A,32H CJNE A,#0FH,BAOYUAN LJMP BAOJIN BAO4: JC BAOYUAN LJMP BAOJIN BAOYUAN: SETB AEB ;??С????????????? CLR BELL MOV A,75H MOV P2,A POP PSW POP ACC RET BAOJIN: CLR AEB ;??С????С???????? SETB BELL MOV A,75H MOV P2,A POP PSW POP ACC RET DELAY3MS: MOV R5,#0FH ;??????? D3: MOV R6,#64H D4: DJNZ R6,D4 DJNZ R5,D3 RET DELAY1MS: MOV R5,#0AH ;??????? D7: MOV R6,#30H D12: DJNZ R6, D12 DJNZ R5,D7 RET DELAY10MS: MOV R5,#32H ;??????? D5: MOV R6,#64H D6: DJNZ R6,D6 DJNZ R5,D5 RET DELAY: MOV R4,#28H ;??????? D9: LCALL DELAY10MS DJNZ R4,D9 RET END |
angmall 發表于 2020-1-15 00:46 好的我把程序發車來奧! |
| 軟件問題 |
程序都是貼的圖片,程序也不短,光憑眼去分析也是需要花時間的,建議把原程序貼出來,或許會有好心人幫你去調試一下找到問題! |
taotie 發表于 2020-1-11 15:16 別逗,我復制哪個啊 |
| 復制代碼粘貼代碼你不會嗎! |
| 匯編控制IO口低電平:MOV P2,#00H; |
| 內阻過大,改小一些 |
csmyldl 發表于 2020-1-8 13:30 我就是不會編程,不會用匯編語言控制P20-P23為低電平 |
| 圖一是我出錯的圖,圖二正確的仿真圖 |
jizhongbiao 發表于 2020-1-8 13:42 是我程序問題嘛。。。。 |
| IO口輸出的不對 |
| 二極管限流電阻改為220歐,再控制P20-P23為低電平輸出試試 |
| 你這肯定是程序問題啊 |
| 參數設置問題,電阻阻值過大改成330R,而不是10K |
