short-Cricuit Constraint;Between Polygon Region (0 holes(s))AD PCB板子DRC時(shí)出錯(cuò)
查看數(shù): 9594 | 評(píng)論數(shù): 2 | 收藏 0
    組圖打開中,請(qǐng)稍候......
發(fā)布時(shí)間: 2018-1-23 19:52
AD求助~PCB板子DRC時(shí)出現(xiàn)這個(gè)錯(cuò)誤一直找不到 short-Cricuit Constraint;Between Polygon Region (0 holes(s)) Bottom Layer And Via(55.067mm,39.548mm)from Top Layer to Bottom Layer Location:[X = 0mm][Y = 0mm ...
ID:939211 發(fā)表于 2021-6-17 11:19
我把覆銅去掉再重新畫線,就解決了
ID:379554 發(fā)表于 2018-7-26 17:40
怎么解決的啊?我也遇到了
