標題: DS18B20上的溫度為什么無法正常顯示在顯示屏上 [打印本頁]
作者: 小白熊123 時間: 2021-6-15 14:25
無論按那個開關 都這樣顯示 就是顯示不出來正確結果 求大佬幫忙看看
2021-6-15 14:25 上傳
#include<reg51.h>
unsigned intshu[]={0x30,0x31,0x32,0x33,0x34,0X35,0x36,0x37,0x38,0x39};
unsignedlong t;
unsignedchar k,f=0;
sbitRS=P2^0;
sbitRW=P2^1;
sbitE=P2^2;
sbitDS=P1^1;
void del(int count ) //延時程序
{while(count--);}
voiddelay(unsigned int count)//延時程序
{int p;
while(count--)
for(p=0;p<125;p++);
voidwrite(unsigned char date)//向DS18B20中寫入數據
{ int i;
for(i=0;i<8;i++)
{DS=0;
DS=date&0x01; // 寫入數據。
del(15)
DS=1;
date>>=1;
void init(unsigned int n)// RW=0,RS=0;向指令寄存器中寫入命令,即對1602初始化。
{delay(10);
E=0;
RS=0;
RW=0;
E=1;
P0=n;
E=0;
voidwrite_data(unsigned char n)//RS=1,RW=0;向數據寄存器中寫入數據,即顯示的數符。
{delay(10);
E=0;
RS=1;
RW=0;
E=1;
P0=n;
E=0;
voidwrite2(unsigned char i)
{ i+=0x30;
if(i==4){i=0;}
write(0x55);
write(0x28);
write(i);
write(0xc5);
write(0xb8);
write(0x00);
write(0x00);
write(0x00);
voidmatchrom() //匹配ROM
unsigned char i;
k=P3;
switch(k)
{ case 0: { f=1;
init(0x80);write_data(0x50);//press
init(0x81);write_data(0x72);
init(0x82);write_data(0x65);
init(0x83);write_data(0x73);
init(0x84);write_data(0x73);
init(0x85);write_data(0x80);
init(0x86);write_data(0x61);//a
init(0x87);write_data(0x80);
init(0x88);write_data(0x6b);//key
init(0x89);write_data(0x65);
init(0x8a);write_data(0x79);
init(0x8b);write_data(0x80);
init(0x8c);write_data(0x21);//!
for(i=0x8d;i<=0xcf;i++)
{init(i);write_data(0x80);}
}break;
case 1: { init(0x83);write_data(0x31); //NO 1
write2(0);
write(0x8e); }break;
case 2: { init(0x83);write_data(0x32);//NO 2
write2(1);
write(0xb9); }break;
case 4: { init(0x83);write_data(0x33); //NO 3
write2(2);
write(0xe0); }break;
case 8:{ init(0x83);write_data(0x34); //NO 4
write2(3);
write(0xd7); } break;
default:{ f=1;
init(0x80);write_data(0x50); //please
init(0x81);write_data(0x6c);
init(0x83);write_data(0x61);
init(0x85);write_data(0x65);
init(0x86);write_data(0x80);
init(0x87);write_data(0x70); //press
init(0x88);write_data(0x72);
init(0x8a);write_data(0x73);
init(0x8b);write_data(0x73);
init(0x8c);write_data(0x80);
init(0x8d);write_data(0x6f); //one
init(0x8e);write_data(0x6e);
init(0x8f);write_data(0x65);
init(0xc0);write_data(0x80);
init(0xc1);write_data(0x80);
init(0xc2);write_data(0x80);
init(0xc3);write_data(0x6b);//key
init(0xc4);write_data(0x65);
init(0xc5);write_data(0x79);
init(0xc6);write_data(0x80);
init(0xc7);write_data(0x6f);//only
init(0xc8);write_data(0x6e);
init(0xc9);write_data(0x6c);
init(0xca);write_data(0x79);
init(0xcb);write_data(0x80);
init(0xcc);write_data(0x21);//!
init(0xcd);write_data(0x80);
init(0xce);write_data(0x80);
init(0xcf);write_data(0x80); }break;
void lcd(unsigned char m) //當為負溫度時,液晶顯示可以高位為0屏蔽.
{ init(0x80);write_data(0x4e);//NO
init(0x81);write_data(0x4f);
init(0x82);write_data(0x80);
init(0x84);write_data(0x80);
init(0x85);write_data(0x74);//temperature
init(0x86);write_data(0x65);
init(0x87);write_data(0x6d);
init(0x88);write_data(0x70);
init(0x8a);write_data(0x72);
init(0x8b);write_data(0x61);
init(0x8c);write_data(0x74);
init(0x8d);write_data(0x75);
init(0x8e);write_data(0x72);
init(0xc2);write_data(0x69); //is:
init(0xc3);write_data(0x73);
init(0xc4);write_data(0x3a);
if(m==1)
{if((t/1000%10)!=0)
{init(0xc5);write_data(0x2d);
init(0xc6);write_data(shu[t/1000%10]);
{init(0xc5);write_data(0xfe);
init(0xc6);write_data(0x2d);
{if(t/10000!=0)
{init(0xc5);write_data(shu[t/10000]);
{if((t/1000%10)!=0)
init(0xc6);write_data(0xfe);
init(0xc7);write_data(shu[t/100%10]);
init(0xc8);write_data(0x2e);
init(0xc9);write_data(shu[(t%100)/10]);
init(0xcb);write_data(0x27);
init(0xcc);write_data(0x43);
void jiance()
{unsignedchar n=0;
do{DS=1;
DS=0;
del(100);
DS=1;
del(10); 。
n=DS;
del(20); //低電平至少要持續60~240us
} while(n==1); 。
read() //從DS18B20中讀出數據
{unsigned char i;
unsigned long date=0;
for(i=0;i<16;i++)
{ DS=0; //主機在某一時刻將總線從高電平拉到低電平.
date>>=1;
DS=1;
del(3); //保持15us將總線拉到高電平,產生讀時間隙
if(DS)
date|=0x8000;
del(8); //讀數據需要持續35us~60us.
return(date);
{unsigned long flag=0;
EA=0;
SP=0X60;
init(0x01); //對液晶屏初始化
init(0x38);
init(0x0c);
init(0x06);
jiance(); //對DS18B20初始?
matchrom();
write(0x44); //啟動溫度變換
del(100);
jiance();
matchrom();
if(f==1)
{f=0;}
{ write(0xbe); // 讀暫存存儲器
t=read();
flag=t&0x8000; //對讀取的數據進行處理
if(flag==0x8000)
{t=~t;
t=t+1;
t=t*25;
t>>=2;
lcd(1);//負值
{ t=t*25;
t>>=2;
lcd(0);//正值
作者: 人人學會單片機 時間: 2021-6-19 08:50
LCD1602顯示℃ 這種自定義符號 http://m.raoushi.com/bbs/dpj-200685-1.html
LCD1602液晶最新資料 說明了具體的時間要求 http://m.raoushi.com/bbs/dpj-205768-1.html
