查看: 3647|回復: 1
基于51單片機的溫度報警器程序設計
ID:255127 發表于 2017-11-29 13:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <AT89X51.h>
#define SET  P3_1
#define DEC  P3_2
#define ADD  P3_3
#define BEEP P3_6
#define ALAM P1_2
#define DQ   P3_7
bit shanshuo_st;
bit beep_st;
sbit DIAN = P0^5;
uchar x=0;
signed char m;
uchar n;
uchar set_st=0;
signed char shangxian=38;
signed char xiaxian=5;
uchar  code
LEDData[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};
void Delay_DS18B20(int num)
   while(num--);        }
   void Init_DS18B20(void)
   unsigned char x=0;
   DQ = 1;
   Delay_DS18B20(8);
   DQ = 0;
   Delay_DS18B20(80);
   DQ = 1;
   Delay_DS18B20(14);
   x = DQ;
   Delay_DS18B20(20);
   unsigned char ReadOneChar(void)
   unsigned char i=0;
   unsigned char dat = 0;
   for (i=8;i>0;i--)
   DQ = 0;
   dat>>=1;
   DQ = 1;
   if(DQ)
   dat|=0x80;
   Delay_DS18B20(4);
   return(dat);
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Delay_DS18B20(5);
DQ = 1;
dat>>=1;
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();     //讀低8位
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5;
return(t);
void Delay(uint num)
while( --num );
void InitTimer(void)
TMOD=0x1;
TH0=0x3c;
TL0=0xb0;
void check_wendu(void)
uint a,b,c;
c=ReadTemperature()-5;
a=c/100;
b=c/10-a*10;
m=c/10;
n=c-a*100-b*10;
if(m<0){m=0;n=0;}
if(m>99){m=99;n=9;}
void Disp_init(void)
P0 = ~0x80;
P2 = 0x7F;
Delay(200);
P2 = 0xDF;
Delay(200);
P2 = 0xF7;
Delay(200);
P2 = 0xFD;
Delay(200);
P2 = 0xFF;
void Disp_Temperature(void)
P0 = ~0x98;
P2 = 0x7F;
Delay(400);
P0= ~LEDData[n];
P2 = 0xDF;
Delay(400);
P0 = ~LEDData[m%10];
DIAN = 0;
P2 = 0xF7;
Delay(400);
P0 = ~LEDData[m/10];
P2 = 0xFD;
Delay(400);
P2 = 0xFF;
void Disp_alarm(uchar baojing)
P0 =~0x98;
P2 = 0x7F;
Delay(200);
P0 =~LEDData[baojing%10];
P2 = 0xDF;
Delay(200);
P0 =~LEDData[baojing/10];
P2 = 0xF7;
Delay(200);
if(set_st==1)P0 =~0xCE;
else if(set_st==2)P0 =~0x1A;
P2 = 0xFD;
Delay(200);
P2 = 0xFF;
void Alarm()
if(x>=10){beep_st=~beep_st;x=0;}
if((m>=shangxian&&beep_st==1)||(m<xiaxian&&beep_st==1))
BEEP=0;
ALAM=0;
BEEP=1;
ALAM=1;
void main(void)
uint z;
InitTimer();
EA=1;      //全局中斷開關
TR0=1;
   ET0=1;      //開啟定時器0
    IT0=1;
         IT1=1;
        check_wendu();
         check_wendu();
          for(z=0;z<300;z++)
Disp_init();
if(SET==0)
Delay(2000);
do{}while(SET==0);
set_st++;x=0;shanshuo_st=1;
if(set_st>2)set_st=0;
if(set_st==0)
EX0=0;
EX1=0;
check_wendu();
Disp_Temperature();
Alarm();
else if(set_st==1)
BEEP=1;
ALAM=1;
EX0=1;    //開啟外部中斷0
EX1=1;
  if(x>=10){shanshuo_st=~shanshuo_st;x=0;}
  if(shanshuo_st) {Disp_alarm(shangxian);}
  else if(set_st==2)
  BEEP=1;    //關閉蜂鳴器
  ALAM=1;
  EX0=1;    //開啟外部中斷0
    EX1=1;
        if(shanshuo_st) {Disp_alarm(xiaxian);}
void timer0(void) interrupt 1
TH0=0x3c;
TL0=0xb0;
x++;
void int0(void) interrupt 0
EX0=0;
if(DEC==0&&set_st==1)
do{
while(DEC==0);
  shangxian--;
   if(shangxian<xiaxian)shangxian=xiaxian;
   else if(DEC==0&&set_st==2)
    do{
        while(DEC==0);
        xiaxian--;
        if(xiaxian<0)xiaxian=0;
                        void int1(void) interrupt 2
                           EX1=0;
                           if(ADD==0&&set_st==1)
                           do{
                            while(ADD==0);
                                shangxian++;
                                  if(shangxian>99)shangxian=99;
                                  else if(ADD==0&&set_st==2)
                                    do{
                                           while(ADD==0);
                                             xiaxian++;
   if(xiaxian>shangxian)xiaxian=shangxian;
ID:378679 發表于 2018-7-24 20:21 | 只看該作者
能否把程序的整個壓縮包發我,謝謝大佬
