查看: 4781|回復(fù): 3
單片機可調(diào)時鐘程序與仿真圖
ID:254549 發(fā)表于 2017-11-28 11:02 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
功能鍵,時或分+1,選擇調(diào)節(jié)時或分或秒,調(diào)節(jié)清零鍵.
  1. #include"reg52.h"
  3. #define uint unsigned int
  4. uchar code DuanMa[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  5. uchar code DuanMa1[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
  6. uchar hours=00,minutes=00,seconds=00;
  7. uchar Set_Time=0;
  8. uchar key_mode=0;
  9. bit impulse;
  10. uchar Time0_bit=0;
  11. bit flash;
  12. sbit LED=P1^0;
  13. sbit k1=P3^2;
  14. sbit k2=P3^3;
  15. sbit k3=P3^4;
  16. sbit k4=P3^5;
  17. uchar shi,fen,miao;
  18. void delay(uint n)
  19. {
  20.   uint i;
  21.   while(n--)
  22.   {
  23.     for(i=0;i<120;i++);
  24.   }
  25. }
  26. void Mode_Choose()
  27. {
  28.         if(k1==0)
  29.                 {
  30.                         delay(10);
  31.                                 if(k1==0)
  32.                                         {
  33.                                                 key_mode++;
  34.                                                 if(key_mode==2)
  35.                                                         key_mode=0;
  36.                                                 while(!k1);
  37.                                         }
  38.                 }
  39. }
  40. void key_Time_Set()
  41. {
  42.         if(key_mode==1)
  43.                 {
  44.                         if(k2==0)
  45.                                 {
  46.                                         delay(10);
  47.                                                 if(k2==0)
  48.                                                         {
  49.        if(Set_Time==0)
  50.        seconds=0;
  51.        else if(Set_Time==1)
  52.        {
  53.        minutes++;
  54.        if(minutes==60)
  55.        minutes=0;
  56.        }
  57.        else
  58.        {
  59.        hours++;
  60.        if(hours==24)
  61.        hours=0;
  62.        }
  63.        while(!k2);
  64.                                                         }
  65.                                 }
  66.                         if(k3==0)
  67.                                 {
  68.                                         delay(10);
  69.                                                 if(k3==0)
  70.                                                         {
  71.        Set_Time++;
  72.        if(Set_Time==3)
  73.        Set_Time=0;
  74.        while(!k3);
  75.                                                         }
  76.                                 }
  77.                         if(k4==0)
  78.                                 {
  79.                                         delay(10);
  80.                                                 if(k4==0)
  81.                                                         {
  82.        if(Set_Time==0)
  83.        seconds=0;
  84.        else if(Set_Time==1)
  85.        minutes=0 ;
  86.        else
  87.        hours=0;
  88.        while(!k4);
  89.                                                         }
  90.                                 }
  91.                 } }
  92. void Display_ShiZhon()
  93. {
  94.         P0=DuanMa[seconds%10];
  95.         P2=0x80;
  96.         delay(1);
  97.         P0=0xff;
  98.         P0=DuanMa[seconds/10];
  99.         P2=0x40;
  100.         delay(1);
  101.         P0=0xff;
  102.         if(flash)
  103.         {
  104.                 P0=0xbf;
  105.                 P2=0x20;
  106.             delay(1);
  107.                 P0=0xff;
  108.         }
  109.         else
  110.         {
  111.                 P0=0xff;
  112.                 P2=0x20;
  113.             delay(1);
  114.                 P0=0xff;
  115.         }
  116.         P0=DuanMa[minutes%10];
  117.         P2=0x10;
  118.         delay(1);
  119.         P0=0xff;
  120.         P0=DuanMa[minutes/10];
  121.         P2=0x08;
  122.         delay(1);
  123.         P0=0xff;
  124.         P0=0xbf;
  125.         P2=0x04;
  126.     delay(1);
  127.         P0=0xff;
  128.         P0=DuanMa[hours%10];
  129.         P2=0x02;
  130.         delay(1);
  131.         P0=0xff;
  132.         P0=DuanMa[hours/10];
  133.         P2=0x01;
  134.         delay(1);
  135.         P0=0xff;
  136. }
  137. void Display_Time_Set()
  138. {
  139.         if(Set_Time==0)
  140.                 {
  141.                         if(impulse)
  142.                         {
  143.                                 P0=DuanMa[seconds%10];
  144.                                 P2=0x80;
  145.                                 delay(1);
  146.                                 P0=0xff;
  147.
  148.                                 P0=DuanMa[seconds/10];
  149.                                 P2=0x40;
  150.                                 delay(1);
  151.                                 P0=0xff;
  152.                         }
  153.                         else
  154.                         {
  155.                                 P0=0xff;
  156.                                 P2=0x80;
  157.                                 delay(1);
  158.                                 P0=0xff;
  159.
  160.                                 P0=0xff;
  161.                                 P2=0x40;
  162.                                 delay(1);
  163.                                 P0=0xff;
  164.                         }
  165.
  166.                         if(flash)
  167.                         {
  168.                                 P0=0xbf;
  169.                                 P2=0x20;
  170.                             delay(1);
  171.                                 P0=0xff;
  172.                         }
  173.                         else
  174.                         {
  175.                                 P0=0xff;
  176.                                 P2=0x20;
  177.                             delay(1);
  178.                                 P0=0xff;
  179.                         }
  180.
  181.                         P0=DuanMa[minutes%10];
  182.                         P2=0x10;
  183.                         delay(1);
  184.                         P0=0xff;
  185.
  186.                         P0=DuanMa[minutes/10];
  187.                         P2=0x08;
  188.                         delay(1);
  189.                         P0=0xff;
  190.
  191.                         P0=0xbf;
  192.                         P2=0x04;
  193.                     delay(1);
  194.                         P0=0xff;
  195.
  196.                         P0=DuanMa[hours%10];
  197.                         P2=0x02;
  198.                         delay(1);
  199.                         P0=0xff;
  200.
  201.                         P0=DuanMa[hours/10];
  202.                         P2=0x01;
  203.                         delay(1);
  204.                         P0=0xff;
  205.                 }
  206.         else if(Set_Time==1)
  207.                 {
  208.                         P0=DuanMa[seconds%10];
  209.                         P2=0x80;
  210.                         delay(1);
  211.                         P0=0xff;
  212.
  213.                         P0=DuanMa[seconds/10];
  214.                         P2=0x40;
  215.                         delay(1);
  216.                         P0=0xff;
  217.
  218.                         if(flash)
  219.                         {
  220.                                 P0=0xbf;
  221.                                 P2=0x20;
  222.                             delay(1);
  223.                                 P0=0xff;
  224.                         }
  225.                         else
  226.                         {
  227.                                 P0=0xff;
  228.                                 P2=0x20;
  229.                             delay(1);
  230.                                 P0=0xff;
  231.                         }
  232.
  233.                         if(impulse)
  234.                         {
  235.                                 P0=DuanMa[minutes%10];
  236.                                 P2=0x10;
  237.                                 delay(1);
  238.                                 P0=0xff;
  239.
  240.                                 P0=DuanMa[minutes/10];
  241.                                 P2=0x08;
  242.                                 delay(1);
  243.                                 P0=0xff;
  244.                         }
  245.                         else
  246.                         {
  247.                                 P0=0xff;
  248.                                 P2=0x10;
  249.                                 delay(1);
  250.                                 P0=0xff;
  251.
  252.                                 P0=0xff;
  253.                                 P2=0x08;
  254.                                 delay(1);
  255.                                 P0=0xff;
  256.                         }
  257.
  258.                         P0=0xbf;
  259.                         P2=0x04;
  260.                     delay(1);
  261.                         P0=0xff;
  262.
  263.                         P0=DuanMa[hours%10];
  264.                         P2=0x02;
  265.                         delay(1);
  266.                         P0=0xff;
  267.
  268.                         P0=DuanMa[hours/10];
  269.                         P2=0x01;
  270.                         delay(1);
  271.                         P0=0xff;
  272.                 }
  273.         else
  274.                 {
  275.                         P0=DuanMa[seconds%10];
  276.                         P2=0x80;
  277.                         delay(1);
  278.                         P0=0xff;
  279.
  280.                         P0=DuanMa[seconds/10];
  281.                         P2=0x40;
  282.                         delay(1);
  283.                         P0=0xff;
  284.
  285.                         if(flash)
  286.                         {
  287.                                 P0=0xbf;
  288.                                 P2=0x20;
  289.                             delay(1);
  290.                                 P0=0xff;
  291.                         }
  292.                         else
  293.                         {
  294.                                 P0=0xff;
  295.                                 P2=0x20;
  296.                             delay(1);
  297.                                 P0=0xff;
  298.                         }
  299.
  300.                         P0=DuanMa[minutes%10];
  301.                         P2=0x10;
  302.                         delay(1);
  303.                         P0=0xff;
  304.
  305.                         P0=DuanMa[minutes/10];
  306.                         P2=0x08;
  307.                         delay(1);
  308.                         P0=0xff;
  309.
  310.                         P0=0xbf;
  311.                         P2=0x04;
  312.                     delay(1);
  313.                         P0=0xff;
  314.
  315.                         if(impulse)
  316.                         {
  317.                                 P0=DuanMa[hours%10];
  318.                                 P2=0x02;
  319.                                 delay(1);
  320.                                 P0=0xff;
  321.
  322.                                 P0=DuanMa[hours/10];
  323.                                 P2=0x01;
  324.                                 delay(1);
  325.                                 P0=0xff;
  326.                         }
  327.                         else
  328.                         {
  329.                                 P0=0xff;
  330.                                 P2=0x02;
  331.                                 delay(1);
  332.                                 P0=0xff;
  333.
  334.                                 P0=0xff;
  335.                                 P2=0x01;
  336.                                 delay(1);
  337.                                 P0=0xff;
  338.                         }
  339.                 }
  340. }
  341. void Time_Init()
  342. {
  343.         TMOD=0x11;
  344.         TH0=(65536-50000)/256;
  345.         TL0=(65536-50000)%256;
  346.         ET0=1;
  347.         TR0=1;
  348.         TH1=(65536-50000)/256;
  349.         TL1=(65536-50000)%256;
  350.         ET1=1;
  351.         TR1=0;
  352.         EA=1;
  353. }
  354. void Time0_Interrupt()interrupt 1
  355. {
  356.         TH0=(65536-50000)/256;
  357.         TL0=(65536-50000)%256;
  358.         Time0_bit++;
  359.         if((Time0_bit%10)==0)
  360.         impulse=~impulse;
  361.                 if(Time0_bit==20)
  362. ……………………
  363. …………限于本文篇幅 余下代碼請從51黑下載附件…………
可調(diào)時鐘.zip (82.33 KB, 下載次數(shù): 21)
ID:88606 發(fā)表于 2017-11-29 07:07 | 只看該作者
看看按鍵思路!
ID:269319 發(fā)表于 2017-12-30 21:55 | 只看該作者
看看按鍵思路!
ID:261637 發(fā)表于 2018-1-5 23:23 | 只看該作者
看看按鍵思路!
