查看: 1876|回復: 0
超聲波+1602顯示
ID:236125 發表于 2017-11-27 11:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit lcdrs=P3^5;
sbit lcdrw=P3^6;
sbit lcden=P3^4;
sbit TRIG = P1^0;
sbit ECHO  =P1^1;
void Timer1_Init();
unsigned int Get_Distance();
void delayms();
void write_com();
void write_data();
void lcd1602init();
bit flag;
uint dValue,tmp;
uchar code lcdline1[]="Welcome To Use!" ;
uchar code lcdline2[]="Table Lam is" ;
void delayms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        lcdrw=0;
        lcden=0;
        P0=com;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void write_data(uchar dat)
        lcdrs=1;
        lcdrw=0;
        P0=dat;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void lcd1602init()
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void writeString(uchar * str, uchar length)
     uchar i;
     for(i = 0; i < length; i++)
                 write_data(str[i]);
void display()
      unsigned char count;
      unsigned char datas[] = {0, 0, 0};
      unsigned int tmp = Get_Distance();
      datas[0] = tmp/100 ;
      datas[1] = tmp%100/10;
      datas[2] = tmp%10;
          write_com(0x80+0x40+12);
          for(count = 0; count < 3; count++)
               write_data('0'+datas[count]); //寫入能識別的字符 ’0‘+數值
void main(void)
        lcd1602init();
        Timer1_Init();
        write_com(0x80);
        writeString(lcdline1,15);
        delayms(1000);
        write_com(0x80+0x40);
    writeString(lcdline2,12);
    delayms(1000);
            display();
                delayms(100);
/***********開啟定時器1并初始化***************/
void Timer1_Init(void)
        TMOD= 0x10;
        TH1=0;
        TL1=0;
        EA =1;
        TR1=0;
void Timer1_ISR() interrupt 3
        flag=1;
        unsigned int distance;
        uint t=100;
        TRIG=1;
        while(t--);
        TRIG=0;
        while(!ECHO);
        flag=0;
        TR1=1;
        while(ECHO);
        TR1=0;
        distance=TH1*256+TL1;
        distance=distance*0.017;
        TH1=0;
        TL1=0;
        delayms(100);
        return distance;
