查看: 5756|回復: 2
單片機矩陣鍵盤仿真原理圖和源代碼
ID:252394 發(fā)表于 2017-11-22 20:26 | 顯示全部樓層 |閱讀模式
4*4矩陣鍵盤的實現(xiàn)原理圖以及代碼
  1. #include<reg51.h>
  2. unsigned char a[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7f,0x39,0x3f,0x79,0x71};
  3. void delay(unsigned int xsm);
  4. unsigned char keyscan(){
  5.         unsigned char key,Row,Col;
  6.         P3=0x0f;
  7.         if(P3!=0x0f){
  8.                 delay(10);//去抖
  9.                 if(P3!=0x0f){
  10.                         Row=P3&0x0f;//確保端口值正確(行的值)
  11.                         P3=0xf0;
  12.                         Col=P3&0xf0;//列值
  13.                 }
  14.                 while((P3&0xf0)!=0xf0);//判斷鍵是否抬起
  15.         }
  16.         switch(Row+Col){
  17.                 case 0xee:key=0;break;
  18.                 case 0xde:key=1;break;
  19.                 case 0xbe:key=2;break;
  20.                 case 0x7e:key=3;break;
  21.                 case 0xed:key=4;break;
  22.                 case 0xdd:key=5;break;
  23.                 case 0xbd:key=6;break;
  24.                 case 0x7d:key=7;break;
  25.                 case 0xeb:key=8;break;
  26.                 case 0xdb:key=9;break;
  27.                 case 0xbb:key=10;break;
  28.                 case 0x7b:key=11;break;
  29.                 case 0xe7:key=12;break;
  30.                 case 0xd7:key=13;break;
  31.                 case 0xb7:key=14;break;
  32.                 case 0x77:key=15;break;
  33.         }
  34.         return key;
  35. }
  36. void main(){
  37.         unsigned key1;
  38.         while(1){
  39.                 key1=keyscan();
  40.                 P2=a[key1];
  41.         }
  42. ……………………
  43. …………限于本文篇幅 余下代碼請從51黑下載附件…………
矩陣鍵盤.zip (58.98 KB, 下載次數(shù): 102)
ID:164151 發(fā)表于 2019-1-1 20:31 | 顯示全部樓層
很好的資料偶
ID:741740 發(fā)表于 2020-5-4 11:04 來自觸屏版 | 顯示全部樓層
謝謝樓主,這兩天要做這個實驗,我編的代碼有問題正好可以借鑒一下
