查看: 2743|回復: 5
單片機考試,說什么解釋程序,有大佬嘛
ID:250460 發表于 2017-11-21 20:01 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. sbit a1=P1^0;
  6. sbit a2=P1^1;
  7. sbit a3=P1^2;
  8. sbit key=P2^7;
  9. uchar code table[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
  10.                                                           0x80,0x90,0x88};//,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
  11. uchar code dispbit[]={0x01,0x02};//數碼管位選碼
  12. uchar dis1[]={0,0};
  13. uchar num,temp=10;
  14. uchar t0=0;
  15. void Delay(uint z)
  16. {
  17.         uint x,y;
  18.         for(x=z;x>0;x--)
  19.                 for(y=110;y>0;y--)
  20.                         ;
  21. }
  22. void init()
  23. {
  24.         TMOD=0x01;
  25.         TH0=(65536-50000)/256;
  26.         TL0=(65536-50000)%256;
  27.         EA=1;
  28.         ET0=1;
  29.         TR0=1;
  30. //        temp=0xfb;
  31. //        P1=temp;
  32. }
  33. void Display()
  34. {
  35.
  36.                 uchar i,x,y;
  37.                 dis1[0]=num/10;
  38.                 dis1[1]=num%10;
  39.                 for(i=0;i<2;i++)
  40.                 {
  41.                         P0=table[dis1[i]];
  42.                         P3=table[dis1[i]];
  43.                         P2=dispbit[i];//位選
  44.                         Delay(5);
  45.                         P2=0x00;
  46.
  47.
  48.                      if(key==1)
  49.                         {
  50.
  51.                                 P1=0xf6;
  52.
  53.                                 EA=0;
  54.
  55.
  56.                                 for(x=5000;x>0;x--)
  57.                           for(y=110;y>0;y--);
  58.
  59.                         }
  60.
  61.                         else  EA=1;
  62.
  63.
  64.                 }
  65. }
  66. void main()
  67. {
  68.         init();
  69.         num=30;
  70.         while(num!=0)
  71.         {
  72.                 loop:Display();
  73.                 if(key==1)
  74.                 goto  loop;
  75.                 P1=0xde;
  76.         //        Delay(10);
  77.         if(num==5)
  78.         {
  79.         while(num!=0)
  80.         {
  81.                 loop2:Display();
  82.
  83.             if(key==1)
  84.                 goto  loop2;
  85.                 P1=0xee;
  86.                 Delay(10);
  87. //                P1=0xfe;
  88.         //        Delay(10);
  89.         }
  90.         }
  91.         }
  92.         num=30;
  93.         while(num!=0)
  94.         {
  95.
  96.                 loop1:Display();
  97.                 if(key==1)
  98.                 goto  loop1;
  99.                 P1=0xf3;
  100.         //        Delay(10);
  101.                 if(        num==5)
  102.                 {
  103.                         while(num!=0)
  104.                         {
  105.                         loop3:Display();
  106.                 if(key==1)
  107.                         goto  loop3;
  108.
  109.                         P1=0xfd;
  110.                         Delay(3);
  111.                         }
  112.           }
  113.         //        P1=0xfb;
  114.         //        Delay(3);
  115.         }
  116.
  117.
  118.
  119.
  120.
  121. }
  122. void time0()interrupt 1 using 0
  123. {
  124.         TH0=(65536-50000)/256;
  125.         TL0=(65536-50000)%256;
  126.                 t0++;
  127.                         if(t0==20)
  128.                                 {
  129.                                         t0=0;
  130.                                         num--;
  131.                                 }
  132. }
ID:250460 發表于 2017-11-21 20:13 | 顯示全部樓層
求解釋啊,明天考試,大佬們- -
ID:252062 發表于 2017-11-21 21:04 | 顯示全部樓層
考試都這么多代碼了嗎
ID:252134 發表于 2017-11-22 12:01 | 顯示全部樓層
怎么看都覺得是計時器的代碼
ID:96682 發表于 2017-11-22 16:05 | 顯示全部樓層
大佬們都很忙的,估計源程序注釋標出來了,你的考試也已結束了。
ID:231984 發表于 2017-11-22 20:54 | 顯示全部樓層
中斷計時,送入數碼管顯示,通過按鍵控制某個功能
