查看: 4646|回復: 0
用51單片機做的計算器跟密碼鎖
我用ad軟件畫了原理圖跟pcb圖,并且利用手頭資源做了出來,現在把這個給大家拿出來共享,因為我是學硬件的,所以軟件編程不是太好,程序都是自己打的,但是沒用到中斷跟延時。望各位大神給指點程序的改進之處。
下面是程序
下面是初始界面跟計算器還有密碼鎖的圖片
  1. #include<reg52.h>
  2. #include<stdio.h>
  3. #include"1602.h"
  4. #include"delay.h"
  5. #include"keyboard.h"
  6. sbit key1=P3^0;
  7. sbit key2=P3^1;
  8. unsigned char code password[]={'1','2','3','4','5','6','7','8'};//可以更改此密碼做多組測試
  9. //定義密碼,實際上密碼需要存在eeprom中,可以通過程序更改。
  10. unsigned char code cg_1602[]={ 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
  11. 0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
  12. 0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00,
  13. 0x1f,0x04,0x04,0x0e,0x04,0x04,0x04,0x1f,
  14. 0x0a,0x1f,0x0a,0x1f,0x02,0x04,0x09,0x1f,
  15. 0x00,0x1b,0x1b,0x00,0x11,0x1b,0x0e,0x04};//"年月日王藝xiaolian"
  16. /*------------------------------------------------
  17.                     主程序
  18. ------------------------------------------------*/
  19. main()
  20. {
  21. unsigned char num,i,j;
  22. unsigned char passwordtemp[16];        //最大輸入16個
  23. unsigned char inputtimes;              //密碼輸入錯誤次數
  24. unsigned char passwordlength,PLEN=8;     //輸入密碼長度,實際密碼長度
  25. unsigned char q,p,sign;
  26. unsigned char temp[16];   //最大輸入16個
  27. unsigned char s,num1;
  28. float a=0,b=0;
  29. bit firstflag;
  30. bit Flag;
  31. LCD_Init();         //初始化液晶屏
  32. DelayMs(10);        //延時用于穩定,可以去掉
  33. LCD_Clear();        //清屏
  34. LCD_Write_Com(0x40); //設定CGRAM地址
  35.         for(num1=0;num1<48;num1++) //將自定義字型碼寫入CGRAM中
  36.         {
  37.                 LCD_Write_Data(cg_1602[num1]);
  38.         }
  39.                 LCD_Write_Com(0x82);//年
  40.         {
  41.                 LCD_Write_Data(0);
  42.         }
  43.                 LCD_Write_Com(0x85);//月
  44.         {
  45.                 LCD_Write_Data(1);
  46.         }
  47.                 LCD_Write_Com(0x88);//日
  48.         {
  49.                 LCD_Write_Data(2);
  50.         }
  51.                 LCD_Write_Com(0x8a);//王
  52.         {
  53.                 LCD_Write_Data(3);
  54.         }
  55.                 LCD_Write_Com(0x8b);//藝
  56.         {
  57.                 LCD_Write_Data(4);
  58.         }
  59.                 LCD_Write_Com(0x89);//
  60.         {
  61.                 LCD_Write_Data(5);
  62.         }
  63.          LCD_Write_String(0,0,"17");
  64.          LCD_Write_String(3,0,"11");
  65.          LCD_Write_String(6,0,"19");
  66.          LCD_Write_String(12,0,"Chao");
  67.          LCD_Write_String(1,1,"Welcome to YOU");
  68.         for(s=0;s<5;s++)//延時5s
  69.             DelayMs(500);
  70.                  LCD_Write_Com(0x01);
  71. if(key1==0)
  72. {  LCD_Init();         //初始化液晶屏
  73. DelayMs(10);        //延時用于穩定,可以去掉
  74. LCD_Clear();        //清屏
  75. LCD_Write_String(0,0,"I LIKE MCU");    //寫入第一行信息,主循環中不再更改此信息,所以在while之前寫入
  76. LCD_Write_String(0,1,"Tian He Number 1");    //寫入第二行信息,提示輸入密碼    //寫入第二行信息,提示輸入密碼
  77. for(s=0;s<25;s++)//延時5s
  78.     DelayMs(200);
  79. LCD_Write_Com(0x01);
  80. while (1)         //主循環
  81.   {
  82. q=KeyPro();  //掃描鍵盤
  83. if(q!=0xff)  //如果掃描是按鍵有效值則進行處理
  84.    {
  85.     if(p==0)    //輸入是第一個字符的時候需要把改行清空,方便觀看
  86.    LCD_Write_Com(0x01);
  87. if(('+'==q)|| (p==16) || ('-'==q) || ('x'==q)|| ('/'==q) || ('='==q))//輸入數字最大值16,輸入符號表示輸入結束
  88.    {
  89.    p=0;  //計數器復位
  90.   if(firstflag==0)  //如果是輸入的第一個數據,賦值給a,并把標志位置1,到下一個數據輸入時可以跳轉賦值給b
  91.       {
  92.       sscanf(temp,"%f",&a);
  93.          firstflag=1;
  94.    }
  95.    else
  96.       sscanf(temp,"%f",&b);
  97.    for(s=0;s<16;s++) //賦值完成后把緩沖區清零,防止下次輸入影響結果
  98.       temp[s]=0;
  99.       LCD_Write_Char(0,1,q);
  100.    ///////////////////////
  101.    if(q!='=')      //判斷當前符號位并做相應處理
  102.       sign=q;      //如果不是等號記下標志位
  103.    else
  104.       {
  105.    firstflag=0;   //檢測到輸入=號,判斷上次讀入的符合
  106.          switch(sign)
  107.         {
  108.       case '+':a=a+b;
  109.    break;
  110.    case '-':a=a-b;
  111.    break;
  112.    case 'x':a=a*b;
  113.    break;
  114.    case '/':a=a/b;
  115.    break;
  116.    default:break;
  117.      }
  118.    sprintf(temp,"%g",a);    //輸出浮點型,無用的0不輸出
  119.          LCD_Write_String(1,1,temp);//顯示到液晶屏
  120.    sign=0;a=b=0;            //用完后所有數據清零
  121.    for(s=0;s<16;s++)
  122.       temp[s]=0;
  123.    }
  124.    }
  125.   else if(p<16)
  126.    {
  127.     if((1==p)&& (temp[0]=='0') )//如果第一個字符是0,判讀第二個字符
  128.       {
  129.     if(q=='.')  //如果是小數點則正常輸入,光標位置加1
  130.       {
  131.       temp[1]='.';
  132.    LCD_Write_Char(1,0,q);//輸出數據
  133.    p++;
  134.             } //這里沒有判斷連續按小數點,如0.0.0
  135.    else
  136.     {
  137.      temp[0]=q; //如果是1-9數字,說明0沒有用,則直接替換第一位0
  138.      LCD_Write_Char(0,0,q);//輸出數據
  139.      }
  140.    }
  141.     else
  142.       {
  143.          temp[p]=q;
  144.          LCD_Write_Char(p,0,q);//輸出數據
  145.       p++;   //輸入數值累加
  146.    }
  147.     }
  148.     }
  149.   }
  150. }
  151. else if(key2==0)
  152. {
  153. PLEN=sizeof(password)/sizeof(password[0]);//用于計算出實際密碼長度
  154. LCD_Init();         //初始化液晶屏
  155. DelayMs(10);        //延時用于穩定,可以去掉
  156. LCD_Clear();        //清屏
  157. LCD_Write_String(0,0,"  Welcome! ");    //寫入第一行信息,主循環中不再更改此信息,所以在while之前寫入
  158. LCD_Write_String(0,1,"Input password!");
  159. //寫入第二行信息,提示輸入密碼
  160. while (1)         //主循環
  161.   {
  162. num=KeyPro();  //掃描鍵盤
  163. if(num!=0xff)  //如果掃描是按鍵有效值則進行處理
  164.    {
  165.     if(i==0)    //輸入是第一個字符的時候需要把改行清空,方便觀看密碼
  166.           LCD_Write_String(0,1,"                ");//清除該行
  167.         if(i<16)
  168.           {
  169.        passwordtemp[i]=num;
  170.        LCD_Write_Char(i,1,'*');//輸入的密碼用"*"代替
  171.            }
  172.         i++;   //輸入數值累加
  173.         if(('='==num)|| (i==16))//輸入按鍵值15或者密碼輸入到最大值16,表示輸入結束,需要進行比對
  174.           {
  175.       passwordlength=i-1;  //計算輸入密碼長度
  176.           i=0;  //計數器復位
  177.           if(passwordlength==PLEN)//長度相等則比較,否則直接輸出錯誤
  178.             {
  179.              Flag=1;//先把比較位置1
  180.              for(j=0;j<PLEN;j++)//循環比較8個數值,如果有一個不等 則最終Flag值為0
  181.                 Flag=Flag&&(passwordtemp[j]==password[j]);//比較輸入值和已有密碼
  182.          }
  183.       if(Flag)//如果比較全部相同,標志位置1
  184.            {
  185.             LCD_Write_String(0,1,"                ");//清除該行
  186.         LCD_Write_String(0,1,"Right Open!>>>>");//密碼正確顯示的信息
  187.         inputtimes=0;//輸入正確則次數清零,重新計數
  188.         Flag=0;      //清除正確標志
  189.                 }
  190.           else
  191.             {
  192.                 LCD_Write_String(0,1,"                ");//清除該行
  193.                 LCD_Write_String(0,1,"Wrong! Retry!");//密碼錯誤,提示重新輸入
  194.                 inputtimes++;//連續輸入錯誤,則次數累加
  195.                 if(inputtimes==3)
  196.                   {
  197.                    LCD_Write_String(0,1,"                ");//清除該行
  198.                    LCD_Write_String(0,1,"Wrong 3 times!");//密碼錯誤,提示重新輸入
  199.                    while(1);//停止該位置,重啟電源后才能輸入,實際實用中則需要等到一定時間后才能再次輸入。
  200.                   }
  201. …………
  202. …………
  203. …………限于本文篇幅 余下代碼請從51黑下載附件…………
計算器.rar (976.86 KB, 下載次數: 13)
143-實用密碼鎖.rar (57.42 KB, 下載次數: 14)
