查看: 2566|回復: 0
封裝為一個通用性數(shù)碼管單片機函數(shù),求指教哦
ID:208105 發(fā)表于 2017-11-19 12:01 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
原理圖:
  1. #ifndef _DEFINE_H_
  2. #define _DEFINE_H_
  3. #include <intrins.h>
  4. //定義數(shù)據(jù)
  5. unsigned char Seg_Yang_Led_Table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  6. //定義函數(shù)
  7. void Delay1ms()  //@11.0592MHz
  8. {
  9. unsigned char i, j;
  10. _nop_();
  11. _nop_();
  12. _nop_();
  13. i = 11;
  14. j = 190;
  15. do
  16. {
  17.   while (--j);
  18. } while (--i);
  19. }
  20. void TestSeg()
  21. {
  22. P2 |= 0xc0;
  23. P0 = 0x80;
  24. P2 &= ~(0xc0);
  25. P0 = 0xff;
  26. P2 |= 0xe0;
  27. P0 =  Seg_Yang_Led_Table[0];
  28. P2 &= ~(0xe0);
  29. P0 = 0x00;
  30. Delay1ms();
  31. P2 |= 0xc0;
  32. P0 = 0x40;
  33. P2 &= ~(0xc0);
  34. P0 = 0xff;
  35. P2 |= 0xe0;
  36. P0 =  Seg_Yang_Led_Table[1];
  37. P2 &= ~(0xe0);
  38. P0 = 0x00;
  39. Delay1ms();
  40. P2 |= 0xc0;
  41. P0 = 0x20;
  42. P2 &= ~(0xc0);
  43. P0 = 0xff;
  44. P2 |= 0xe0;
  45. P0 =  Seg_Yang_Led_Table[2];
  46. P2 &= ~(0xe0);
  47. P0 = 0x00;
  48. Delay1ms();
  49. P2 |= 0xc0;
  50. P0 = 0x10;
  51. P2 &= ~(0xc0);
  52. P0 = 0xff;
  53. P2 |= 0xe0;
  54. P0 =  Seg_Yang_Led_Table[3];
  55. P2 &= ~(0xe0);
  56. P0 = 0x00;
  57. Delay1ms();
  58. P2 |= 0xc0;
  59. P0 = 0x08;
  60. P2 &= ~(0xc0);
  61. P0 = 0xff;
  62. P2 |= 0xe0;
  63. P0 =  Seg_Yang_Led_Table[4];
  64. P2 &= ~(0xe0);
  65. P0 = 0x00;
  66. Delay1ms();
  67.
  68. P2 |= 0xc0;
  69. P0 = 0x04;
  70. P2 &= ~(0xc0);
  71. P0 = 0xff;
  72. P2 |= 0xe0;
  73. P0 =  Seg_Yang_Led_Table[5];
  74. P2 &= ~(0xe0);
  75. P0 = 0x00;
  76. Delay1ms();
  77. P2 |= 0xc0;
  78. P0 = 0x02;
  79. P2 &= ~(0xc0);
  80. P0 = 0xff;
  81. P2 |= 0xe0;
  82. P0 =  Seg_Yang_Led_Table[6];
  83. P2 &= ~(0xe0);
  84. P0 = 0x00;
  85. Delay1ms();
  86.
  87. P2 |= 0xc0;
  88. P0 = 0x01;
  89. P2 &= ~(0xc0);
  90. P0 = 0xff;
  91. P2 |= 0xe0;
  92. P0 =  Seg_Yang_Led_Table[7];
  93. P2 &= ~(0xe0);
  94. P0 = 0x00;
  95. Delay1ms();
  96. }
  97. #endif
