查看: 2501|回復: 0
帶有12864液晶的數字溫度計
ID:250103 發表于 2017-11-16 21:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程 序 名:數字溫度計(基本)
編 寫 者:楊范
指導老師:王韌
時   間 :2016.12.20
班   級        :自卓1401班
功   能 :DS18B20顯示溫度
使用說明:將單片機的P2口用杜邦線線連于液晶的數據總線(P20--D0...P27--D7),
          點陣E連至P37,點陣RW連至P36,點陣RS連至P35,DS18B20接于P3^3
#include<reg52.h>
#include"lcd12864.h"
#include"delay.h"
#include<intrins.h>
#include"ds18b20.h"
#include"key_hl.h"
#define uint  unsigned int
//uchar  disp_temp[9];        //DS18B20處理后數據存放數組
sbit fmq=P0^0;
extern uchar  disp_temp[9];        //DS18B20處理后數據存放數組
extern int shangxian,xiaxian;        //報警溫度上下限
extern int wendu;
uchar shangfenchai[5];                 //報警上限處理后數據存放數組
uchar xiafenchai[5];                 //報警下限處理后數據存放數組
void xianshi()
        shangfenchai[0]=shangxian/100+'0';
        shangfenchai[1]=shangxian/10%10+'0';
        shangfenchai[2]=shangxian%10+'0';
        shangfenchai[3]=0x20;
        xiafenchai[0]=xiaxian/100+'0';
        xiafenchai[1]=xiaxian/10%10+'0';
        xiafenchai[2]=xiaxian%10+'0';
        xiafenchai[3]=0x20;
        if(shangfenchai[0]=='0')                  //去掉最高位的0
                shangfenchai[0]=0x20;
                if(shangfenchai[1]=='0')
                        shangfenchai[1]=0x20;
        if(xiafenchai[0]=='0')                                //去掉最高位的0
                xiafenchai[0]=0x20;
                if(xiafenchai[1]=='0')
                        xiafenchai[1]=0x20;
/***************  以下為主函數  *****************/
        uchar v,i;
        uchar shangxian1,zancun;        //調節溫度上下限暫存所用
        shangxian=30;                                //報警溫度上限初賦值
        xiaxian=27;                                        //報警溫度下限初賦值
        lcd12864_init();
        Delay(10);
        lcd12864_display(1,2,"湖南工學院");
        lcd12864_display(2,3,"電信學院");
        lcd12864_display(3,3,"自卓1401班");
        lcd12864_display(4,4,"楊范");
        Delay(2000);
        lcd12864_write_command(0x01);
        Delay(10);
                top:while(v!=0x48)
                        lcd12864_display(1,2,"數\xfd字溫度計");
                        lcd12864_display(3,2,"P.確定進入?");
                        v=keyscan();
                if(v==0x48)
                        switch(v)
                                Delay(10);
                                case 0x48:if(v==0x48)
                                                          v=keyscan();
                                                          while(v!=0x18&&v!=0x48&&v!=0x88)
        lcd12864_display(1,4,"確認");
        lcd12864_display(3,2,"是        否  ");
        v=keyscan();
                                                          switch(v)
        fmq=1;
        lcd12864_init();
        Delay(1);
        lcd12864_display(1,1,"現在室內溫度");
        lcd12864_display(2,5,"℃");
        xianshi();
        lcd12864_display(3,1,"上限");
        lcd12864_display(3,3,shangfenchai);
        lcd12864_display(3,5,"下限");
        lcd12864_display(3,7,xiafenchai);
        lcd12864_display(4,1,"A 調上限B 調下限");
        while(v==0x48||v==0x00||v==0x11||v==0x21||v==0x41||v==0x81||
        v==0x12||v==0x22||v==0x42||v==0x82||v==0x14||v==0x24)
        v=keyscan();
        get_temperature();
        if(wendu>=xiaxian&&wendu<=shangxian)
        fmq=1;
        if(wendu<xiaxian||wendu>shangxian)
        fmq=0;
        lcd12864_display(2,1,disp_temp);
        for(i=0;i<250&&((v==0x48||v==0x00||v==0x11||v==0x21||v==0x41||v==0x81||
        v==0x12||v==0x22||v==0x42||v==0x82||v==0x14||v==0x24));i++)
        Delay(1);
        v=keyscan();
                                case 0x18:if(v==0x18)
                                                          fmq=1;
                                                          v=keyscan();
                                                          break;
                                case 0x88:if(v==0x88)
                                                          fmq=1;
                                                          v=keyscan();
                                                          goto top;
                                case 0x44:if(v==0x44)
                                                          lcd12864_init();
                                                          lcd12864_display(1,2,"設置報警上限");
                                                          lcd12864_display(2,1,"您將輸入:0~255");   //設置報警上限
                                                          lcd12864_display(4,1,"S15 確定S14 歸零");
                                                          lcd12864_write_command(0x88);
                                                          shangxian1=0;
                                                          while(v!=0x48)
        v=keyscan( );
        switch(v)
        case 0x11:zancun=0;
        lcd12864_write_data('0');
        shangxian1=shangxian1*10+zancun;
        break;
        case 0x21:zancun=1;
        lcd12864_write_data('1');
        break;
        case 0x41:zancun=2;
        lcd12864_write_data('2');
        break;
        case 0x81:zancun=3;
        lcd12864_write_data('3');
        break;
        case 0x12:zancun=4;
        lcd12864_write_data('4');
        break;
        case 0x22:zancun=5;
        lcd12864_write_data('5');
        break;
        case 0x42:zancun=6;
        lcd12864_write_data('6');
        break;
        case 0x82:zancun=7;
        lcd12864_write_data('7');
        break;
        case 0x14:zancun=8;
        lcd12864_write_data('8');
        break;
        case 0x24:zancun=9;
        lcd12864_write_data('9');
        break;
        case 0x28:lcd12864_init();
        shangxian1=0;
                                                          shangxian=shangxian1;
                                                          break;
                                case 0x84:if(v==0x84)
                                                          lcd12864_init();
                                                          lcd12864_display(1,2,"設置報警下限");                    //          設置報警下限
                                                          shangxian1=0;
                                                          while(v!=0x48)
        v=keyscan( );
        switch(v)
        case 0x11:zancun=0;
        break;
        case 0x21:zancun=1;
        break;
        case 0x41:zancun=2;
        break;
        case 0x81:zancun=3;
        break;
        case 0x12:zancun=4;
        break;
        case 0x22:zancun=5;
        break;
        case 0x42:zancun=6;
        break;
        case 0x82:zancun=7;
        break;
        case 0x14:zancun=8;
        break;
        case 0x24:zancun=9;
        break;
        shangxian1=0;
                                                          xiaxian=shangxian1;
                                                          break;
                                default:v=keyscan();
                                                break;
