查看: 2703|回復: 0
LCD12864液晶顯示正弦函數(shù)的單片機源程序
ID:237272 發(fā)表于 2017-10-30 19:51 | 顯示全部樓層 |閱讀模式
  1. #include<stc.h>
  2. #include<math.h>
  3. #include"ZB.h"
  4. #include"12864.h"
  5. void main()
  6. {
  7.         uchar i,j;
  8.         uchar num;
  9.         uchar w=10,A=6;
  10.         init_LCD();
  11.         Clear_GDRAM();
  12.         write_LCD_command(0x36);                                //繪圖打開
  13.         display_BMP(ZB);                                                //顯示圖形
  14.         while(1)
  15.         {
  16.                 write_LCD_command(0x30);                   //普通模式
  17.                 write_LCD_command(0x80);                   //設置地址
  18.                 write_LCD_data('T');
  19.                 write_LCD_data(':');
  20.                 write_LCD_data(2*w/100+0x30);
  21.                 write_LCD_data(2*w%100/10+0x30);
  22.                 write_LCD_data(2*w%10+0x30);
  23.                 write_LCD_command(0x83);                   //設置地址
  24.                 write_LCD_data('A');
  25.                 write_LCD_data(':');
  26.                 write_LCD_data(A/10+0x30);
  27.                 write_LCD_data(A%10+0x30);
  28.                 write_LCD_command(0x36);
  29.                 for(i=13;i<128;i++)
  30.                 {
  31.                         j=35-A*sin((i-13)*3.14/w);                 //sin函數(shù)公式
  32.                         Draw_dots(i,j,1);
  33.                         delay(400);
  34.                 }
  35. /**********以下為按鍵掃描函數(shù)**************/
  36.                 if(KEY1==0)                        //模式鍵按下
  37.                 {
  38.                         delay(10);
  39.                         if(KEY1==0)
  40.                         {
  41.                                 while(!KEY1);
  42.                                 key_value++;
  43.                                 if(key_value>2)
  44.                                         key_value=0;
  45.                         }
  46.                 }
  47.                 if(key_value==1)                         //若選擇的是周期模式
  48.                 {
  49.                         write_LCD_command(0x30);
  50.                         write_LCD_command(0x86);
  51.                         for(num=0;num<4;num++)
  52.                         {
  53.                                 write_LCD_data(HZ1[num]);         //顯示"周期"漢字
  54.                         }
  55.                         if(KEY2==0)                                                //加鍵按下時
  56.                         {
  57.                                 delay(10);
  58.                                 if(KEY2==0)
  59.                                 {
  60.                                         while(!KEY2);
  61.                                         w=w+5;                                        //w加
  62.                                         if(w==65)
  63.                                                 w=10;
  64.                                         Clear_GDRAM();
  65.                                         write_LCD_command(0x36);//重新顯示圖形
  66.                                         display_BMP(ZB);
  67.                                 }
  68.                         }
  69.                         if(KEY3==0)
  70.                         {
  71.                                 delay(10);
  72.                                 if(KEY3==0)
  73.                                 {
  74.                                         while(!KEY3);
  75.                                         if(w>=10)                                //w減
  76.                                                 w=w-5;
  77.                                         Clear_GDRAM();
  78.                                         write_LCD_command(0x36); //繪圖打開
  79.                                         display_BMP(ZB);                //重新顯示圖形
  80.                                 }
  81.                         }
  82.                 }
  83.                 if(key_value==2)                                //若選擇的是幅度模式
  84.                 {
  85.                         write_LCD_command(0x30);
  86.                         write_LCD_command(0x86);
  87.                         for(num=0;num<4;num++)
  88.                         {
  89.                                 write_LCD_data(HZ2[num]);            //顯示"幅度"漢字
  90.                         }
  91.                         if(KEY2==0)
  92.                         {
  93.                                 delay(10);
  94.                                 if(KEY2==0)
  95.                                 {
  96.                                         while(!KEY2);
  97.                                         A=A+2;                                          //A加
  98.                                         if(A==22)
  99.                                                 A=8;
  100.                                         Clear_GDRAM();
  101.                                         write_LCD_command(0x36);  //繪圖打開
  102.                                         display_BMP(ZB);                  //重新顯示圖形
  103.                                 }
  104.                         }
  105.                         if(KEY3==0)
  106.                         {
  107.                                 delay(10);
  108.                                 if(KEY3==0)
  109.                                 {
  110.                                         while(!KEY3);
  111.                                         if(A>=6)                                   //A減
  112.                                                 A=A-2;
  113.                                         Clear_GDRAM();
  114.                                         write_LCD_command(0x36);   //繪圖打開
  115.                                         display_BMP(ZB);                   //重新顯示圖形
  116.                                 }
  117.                         }
  118.                 }
  119.         }
  120. }
所有資料51hei提供下載(在文章的最后有完整工程下載):
http://m.raoushi.com/bbs/dpj-97144-1.html
