查看: 2392|回復: 1
求大神解答為什么1602顯示不出gy-30的亮度值
ID:227369 發表于 2017-10-25 23:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. 求大神解答為什么1602顯示不出gy-30的亮度值,,,,望大神不要介意問題簡單
  2. //***************************************
  3. // BH1750FVI IIC????
  4. // ?????STC89C51
  5. // ??:11.0592M
  6. // ??:LCD1602
  7. // ???? Keil uVision2
  8. // ??????24c04????
  9. // ??:2011?4?20?
  10. //****************************************
  11. #include  <REG51.H>
  12. #include  <math.h>    //Keil library
  13. #include  <stdio.h>   //Keil library
  14. #include  <INTRINS.H>
  15. #define   uchar unsigned char
  16. #define   uint unsigned int
  17. #define   DataPort P0         //LCD1602????
  18. sbit            SCL=P1^0;      //IIC??????
  19. sbit            SDA=P1^1;      //IIC??????
  20. sbit      LCM_RS=P2^0;   //LCD1602????
  21. sbit      LCM_RW=P2^1;   //LCD1602????
  22. sbit      LCM_EN=P2^2;   //LCD1602????
  23. #define          SlaveAddress   0x46 //?????IIC???????,??ALT  ADDRESS????????
  24.                               //ALT  ADDRESS????????0xA6,???????0x3A
  25. typedef   unsigned char BYTE;
  26. typedef   unsigned short WORD;
  27. BYTE    BUF[8];                         //???????
  28. uchar   ge,shi,bai,qian,wan;            //????
  29. int     dis_data;                       //??
  30. void delay_nms(unsigned int k);
  31. void InitLcd();
  32. void Init_BH1750(void);
  33. void WriteDataLCM(uchar dataW);
  34. void WriteCommandLCM(uchar CMD,uchar Attribc);
  35. void DisplayOneChar(uchar X,uchar Y,uchar DData);
  36. void conversion(uint temp_data);
  37. void  Single_Write_BH1750(uchar REG_Address);               //??????
  38. uchar Single_Read_BH1750(uchar REG_Address);                //???????????
  39. void  Multiple_Read_BH1750();                               //????????????
  40. //------------------------------------
  41. void Delay5us();
  42. void Delay5ms();
  43. void BH1750_Start();                    //????
  44. void BH1750_Stop();                     //????
  45. void BH1750_SendACK(bit ack);           //??ACK
  46. bit  BH1750_RecvACK();                  //?ack
  47. void BH1750_SendByte(BYTE dat);         //IIC?????
  48. BYTE BH1750_RecvByte();                 //IIC?????
  49. //-----------------------------------
  50. //*********************************************************
  51. void conversion(uint temp_data)  //  ????? ?,?,?,?,?
  52. {
  53.     wan=temp_data/10000+0x30 ;
  54.     temp_data=temp_data%10000;   //????
  55.         qian=temp_data/1000+0x30 ;
  56.     temp_data=temp_data%1000;    //????
  57.     bai=temp_data/100+0x30   ;
  58.     temp_data=temp_data%100;     //????
  59.     shi=temp_data/10+0x30    ;
  60.     temp_data=temp_data%10;      //????
  61.     ge=temp_data+0x30;
  62. }
  63. //????**************************
  64. void delay_nms(unsigned int k)
  65. {
  66. unsigned int i,j;
  67. for(i=0;i<k;i++)
  68. {
  69. for(j=0;j<121;j++)
  70. {;}}
  71. }
  72. /*******************************/
  73. void WaitForEnable(void)
  74. {
  75. DataPort=0xff;
  76. LCM_RS=0;LCM_RW=1;_nop_();
  77. LCM_EN=1;_nop_();_nop_();
  78. while(DataPort&0x80);
  79. LCM_EN=0;
  80. }
  81. /*******************************/
  82. void WriteCommandLCM(uchar CMD,uchar Attribc)
  83. {
  84. if(Attribc)WaitForEnable();
  85. LCM_RS=0;LCM_RW=0;_nop_();
  86. DataPort=CMD;_nop_();
  87. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  88. }
  89. /*******************************/
  90. void WriteDataLCM(uchar dataW)
  91. {
  92. WaitForEnable();
  93. LCM_RS=1;LCM_RW=0;_nop_();
  94. DataPort=dataW;_nop_();
  95. LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  96. }
  97. /***********************************/
  98. void InitLcd()
  99. {
  100. WriteCommandLCM(0x38,1);
  101. WriteCommandLCM(0x08,1);
  102. WriteCommandLCM(0x01,1);
  103. WriteCommandLCM(0x06,1);
  104. WriteCommandLCM(0x0c,1);
  105. }
  106. /***********************************/
  107. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  108. {
  109. Y&=1;
  110. X&=15;
  111. if(Y)X|=0x40;
  112. X|=0x80;
  113. WriteCommandLCM(X,0);
  114. WriteDataLCM(DData);
  115. }
  116. /**************************************
  117. ??5??(STC90C52RC@12M)
  118. ???????,???????,???????????
  119. ???1T?MCU?,????????
  120. **************************************/
  121. void Delay5us()
  122. {
  123.     _nop_();_nop_();_nop_();_nop_();
  124.     _nop_();_nop_();_nop_();_nop_();
  125.         _nop_();_nop_();_nop_();_nop_();
  126.         _nop_();_nop_();_nop_();_nop_();
  127. }
  128. /**************************************
  129. ??5??(STC90C52RC@12M)
  130. ???????,???????
  131. ???1T?MCU?,????????
  132. **************************************/
  133. void Delay5ms()
  134. {
  135.     WORD n = 560;
  136.     while (n--);
  137. }
  138. /**************************************
  139. ????
  140. **************************************/
  141. void BH1750_Start()
  142. {
  143.     SDA = 1;                    //?????
  144.     SCL = 1;                    //?????
  145.     Delay5us();                 //??
  146.     SDA = 0;                    //?????
  147.     Delay5us();                 //??
  148.     SCL = 0;                    //?????
  149. }
  150. /**************************************
  151. ????
  152. **************************************/
  153. void BH1750_Stop()
  154. {
  155.     SDA = 0;                    //?????
  156.     SCL = 1;                    //?????
  157.     Delay5us();                 //??
  158.     SDA = 1;                    //?????
  159.     Delay5us();                 //??
  160. }
  161. /**************************************
  162. ??????
  163. ????:ack (0:ACK 1:NAK)
  164. **************************************/
  165. void BH1750_SendACK(bit ack)
  166. {
  167.     SDA = ack;                  //?????
  168.     SCL = 1;                    //?????
  169.     Delay5us();                 //??
  170.     SCL = 0;                    //?????
  171.     Delay5us();                 //??
  172. }
  173. /**************************************
  174. ??????
  175. **************************************/
  176. bit BH1750_RecvACK()
  177. {
  178.     SCL = 1;                    //?????
  179.     Delay5us();                 //??
  180.     CY = SDA;                   //?????
  181.     SCL = 0;                    //?????
  182.     Delay5us();                 //??
  183.     return CY;
  184. }
  185. /**************************************
  186. ?IIC??????????
  187. **************************************/
  188. void BH1750_SendByte(BYTE dat)
  189. {
  190.     BYTE i;
  191.     for (i=0; i<8; i++)         //8????
  192.     {
  193.         dat <<= 1;              //????????
  194.         SDA = CY;               //????
  195.         SCL = 1;                //?????
  196.         Delay5us();             //??
  197.         SCL = 0;                //?????
  198.         Delay5us();             //??
  199.     }
  200.     BH1750_RecvACK();
  201. }
  202. /**************************************
  203. ?IIC??????????
  204. **************************************/
  205. BYTE BH1750_RecvByte()
  206. {
  207.     BYTE i;
  208.     BYTE dat = 0;
  209.     SDA = 1;                    //??????,??????,
  210.     for (i=0; i<8; i++)         //8????
  211.     {
  212.         dat <<= 1;
  213.         SCL = 1;                //?????
  214.         Delay5us();             //??
  215.         dat |= SDA;             //???
  216.         SCL = 0;                //?????
  217.         Delay5us();             //??
  218.     }
  219.     return dat;
  220. }
  221. //*********************************
  222. void Single_Write_BH1750(uchar REG_Address)
  223. {
  224.     BH1750_Start();                  //????
  225.     BH1750_SendByte(SlaveAddress);   //??????+???
  226.     BH1750_SendByte(REG_Address);    //???????,?????pdf22?
  227.   //  BH1750_SendByte(REG_data);       //???????,?????pdf22?
  228.     BH1750_Stop();                   //??????
  229. }
  230. //********?????*****************************************
  231. /*
  232. uchar Single_Read_BH1750(uchar REG_Address)
  233. {  uchar REG_data;
  234.     BH1750_Start();                          //????
  235.     BH1750_SendByte(SlaveAddress);           //??????+???
  236.     BH1750_SendByte(REG_Address);                   //????????,?0??
  237.     BH1750_Start();                          //????
  238.     BH1750_SendByte(SlaveAddress+1);         //??????+???
  239.     REG_data=BH1750_RecvByte();              //???????
  240.         BH1750_SendACK(1);
  241.         BH1750_Stop();                           //????
  242.     return REG_data;
  243. }
  244. */
  245. //*********************************************************
  246. //
  247. //????BH1750????
  248. //
  249. //*********************************************************
  250. void Multiple_read_BH1750(void)
  251. {   uchar i;
  252.     BH1750_Start();                          //????
  253.     BH1750_SendByte(SlaveAddress+1);         //??????+???
  254.
  255.          for (i=0; i<3; i++)                      //????6?????,???BUF
  256.     {
  257.         BUF[i] = BH1750_RecvByte();          //BUF[0]??0x32??????
  258.         if (i == 3)
  259.         {
  260.            BH1750_SendACK(1);                //?????????NOACK
  261.         }
  262.         else
  263.         {
  264.           BH1750_SendACK(0);                //??ACK
  265.        }
  266.    }
  267.     BH1750_Stop();                          //????
  268.     Delay5ms();
  269. }
  270. //???BH1750,???????pdf????****
  271. void Init_BH1750()
  272. {
  273.    Single_Write_BH1750(0x01);
  274. }
  275. //*********************************************************
  276. //???********
  277. //*********************************************************
  278. void main()
  279. {
  280.    float temp;
  281.    delay_nms(200);            //??200ms
  282.    InitLcd();           //???LCD
  283.    Init_BH1750();       //???BH1750
  284.   while(1)              //??
  285.   {
  286.     Single_Write_BH1750(0x01);   // power on
  287.     Single_Write_BH1750(0x10);   // H- resolution mode
  288.      delay_nms(180);              //??180ms
  289.     Multiple_Read_BH1750();       //??????,???BUF?
  290.     dis_data=BUF[0];
  291.     dis_data=(dis_data<<8)+BUF[1];//????
  292.     temp=(float)dis_data/1.2;
  293.     conversion(temp);         //???????
  294.         DisplayOneChar(0,0,'L');
  295.         DisplayOneChar(1,0,'i');
  296.         DisplayOneChar(2,0,'g');
  297.         DisplayOneChar(3,0,'h');
  298.         DisplayOneChar(4,0,'t');
  299.     DisplayOneChar(5,0,':');
  300.     DisplayOneChar(7,0,wan); //????
  301.     DisplayOneChar(8,0,qian);
  302.     DisplayOneChar(9,0,bai);
  303.     DisplayOneChar(10,0,shi);
  304.         DisplayOneChar(11,0,ge);
  305.         DisplayOneChar(13,0,'l'); ////?????
  306.         DisplayOneChar(14,0,'x');
  307.   }
  308. }
ID:316425 發表于 2018-6-11 17:47 | 只看該作者
請問樓主解決了嗎?我也遇到了同樣的問題,怎么辦啊?
