#include <AT89X52.h>
#define uint unsigned int //宏定義
#define KEY P3_7 //定義畫面切換按鍵
uchar KY; //KY作用在后面說明
uchar disp; //顯示漢字指針
uchar pic=0,num=0; //pic為按鍵次數;num為中斷次數
uchar code love[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F,
0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00,
0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10,
0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20,
0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/
uchar code loveyou[] = {
0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F,
0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00,
0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*心形圖案*/
uchar code hehe[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20,
0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00,
0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10,
0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*呵呵o(∩_∩)o圖案*/
unsigned char code hanzi[] = {
0x40,0x08,0x44,0x08,0x44,0x04,0x44,0x04,
0x44,0x02,0x44,0x3E,0x7F,0x49,0xC4,0x48,
0xC4,0x44,0x44,0x44,0x64,0x42,0x54,0x42,
0x4E,0x40,0x44,0x70,0x40,0x00,0x00,0x00,/*"老",0*/
0x00,0x40,0xFC,0x27,0x00,0x10,0x00,0x0E,
0xFF,0x01,0x00,0x00,0xF2,0x0F,0x12,0x00,
0x12,0x00,0x12,0x00,0xFE,0xFF,0x12,0x00,
0x12,0x04,0x12,0x08,0xF2,0x07,0x00,0x00,/*"師",0*/
0x10,0x80,0x10,0x43,0xF0,0x22,0x1F,0x14,
0x10,0x0C,0xF0,0x73,0x80,0x20,0x82,0x00,
0x82,0x40,0x82,0x80,0xF2,0x7F,0x8A,0x00,
0x86,0x00,0x82,0x00,0x80,0x00,0x00,0x00,/*"好",0*/
0x00,0x00,0x00,0x00,0x00,0x00,0xF0,0x5F,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",0*/
0x20,0x22,0x30,0x23,0xAC,0x22,0x63,0x12,
0x10,0x12,0x40,0x00,0x20,0x00,0x50,0x7E,
0x4C,0x42,0x43,0x42,0x44,0x42,0x48,0x42,
0x30,0x7E,0x60,0x00,0x20,0x00,0x00,0x00,/*"給",0*/
0x00,0x00,0x80,0x00,0x80,0x00,0x40,0x00,
0x20,0x00,0x10,0x00,0x0C,0x00,0xE3,0x7F,
0x04,0x00,0x08,0x00,0x10,0x00,0x20,0x00,
0x60,0x00,0xC0,0x00,0x40,0x00,0x00,0x00,/*"個",1*/
0x10,0x08,0x61,0xF8,0x06,0x07,0xE0,0x00,
0x04,0x00,0xA4,0xFF,0xA4,0x08,0xEF,0x07,
0xA4,0x14,0xA4,0x08,0xE4,0x07,0xAF,0x44,
0xA4,0x88,0xA4,0x7F,0x24,0x00,0x00,0x00,/*"滿",2*/
0x80,0x00,0x40,0x80,0x20,0x40,0x98,0x20,
0x87,0x10,0x82,0x0F,0x80,0x00,0x80,0x00,
0x83,0x20,0x84,0x40,0x98,0x3F,0x30,0x00,
0x60,0x00,0xC0,0x00,0x40,0x00,0x00,0x00,/*"分",3*/
/*****函數聲明*****/
void display1_ltor(void);
void display2_ltor(void);
void display2_rtol(void);
void display3(void);
void display4(void);
/*****n(us)延時子程序*****/
void DelayUs(uint N)
uint x;
for(x=0; x<=N;x++);
/*****中斷服務程序*****/
void intersvr0(void) interrupt 0
KY=~KY; //每個搖動來回水銀開關會在擺幅兩端分別產生下降沿中斷,只提取其中一次(從左向右搖才顯示)
if(KY==0)
num++; //計算中斷次數
switch(pic) //選擇畫面
case 0:{display1_ltor();}break;
case 1:{display2_ltor();}break;
case 2:{display3();}break;
case 3:{display4();}break;
default:{display1_ltor();}
/*****顯示子程序1(漢字)*****/
uchar i;
if(num>10){disp++;num=0;} //每中斷10次切換
if(disp>1)disp=0;
DelayUs(5200); //此處延時時間依各硬件差別而各不相同,試著調整使得顯示內容居中即可
for(i=0;i<64;i++)
P0=~hanzi[disp*128+i*2];
P2=~hanzi[disp*128+i*2+1];
DelayUs(100);
/*****顯示子程序2(LOVE)*****/
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P0=~love[i*2];
P2=~love[i*2+1];
DelayUs(140);
/*****顯示子程序3(心形圖案)*****/
void display3(void)
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P0=~loveyou[i*2];
P2=~loveyou[i*2+1];
DelayUs(120);
/*****顯示子程序4(呵呵o(∩_∩)o圖案)*****/
void display4(void)
uchar i;
DelayUs(4000);
for(i=0;i<64;i++)
P0=~hehe[i*2];
P2=~hehe[i*2+1];
DelayUs(120);
/*****主函數*****/
void main(void)
IT0=1;
EX0=1;
EA=1; //開中斷,下降沿中斷
KY=0;
while(1) //主程序中只檢測按鍵
if(KEY==0) //畫面切換鍵按下
DelayUs(10000); //按鍵去抖
if(KEY==0);
pic++;}
if(pic>3)pic=0;
/*****END*****/
